Adata nobility nh92
It don't come up. it appear like it coneccted but i don't have access to files
I cracked the screen somehow and now I cant shut it off nor use it as far as touch screening but my alarm clock still works and the battery isnt discharging unsure what to do
Posted on Feb 07, 2014
2 Suggested Answers
smkumarpandi
SOURCE: When i plug adata Nobility
When i plug adata Nobility NH92 USB, it doesn't work and a msg appear which says must be formatted !! What to do ?
Posted on Jul 20, 2012
I just got an error this morning that says I need to format this external hard drive before I can use it. I can't do this because it has all my files one it. I can I fix it?
You need to go to computer management in control panel and storage to see if the drive is initialized, if it is then it may be corrupted, if it is not then you need to try that. The initialization wont damage the data on it.
Sep 27, 2015 | ADATA A-DATA Nobility Series NH92 640 GB...
How to I clean out adata nobility nh92 so I can start updates again?
Check in "Properties" i if your external hard dreive is really full. If it is full, check entries; probably about half of your hard drive is useless backup. Delete unnecesary files and folders so it might continue backing up.
Aug 24, 2014 | ADATA A-DATA Nobility Series NH92 500 GB...
It can't be initilized
All I can suggest is to check the connections of your USB and Power Supply. If everything is ok, you should find someone specialized in recovering data from Hard Drives with access problem.
Jun 17, 2014 | ADATA A-DATA Nobility Series NH92 500 GB...
File system lost?
I recommend SpinRite from grc.com. It is the most diligent utility I have used for this. Explore and understand the explanation of what it does on the website.
Jan 12, 2014 | ADATA 1TB Classic CH11 Black External Hard...
Adata nobility nh92
you always have to format a new drive when you get it. Open control panel/Administrative Tools/Computer Management.... Disk Management. In the top or bottom locate the drive (windows will likely ask if you want to format it before you hunt it down). If windows does not ask right click the drive and choose format
Nov 08, 2013 | Microsoft Windows 7 Professional for PC
System not recognizing external device
I understand by "external device" is that your none of your USB ports work and you can't use your CD/DVD burner
Get a Hard Drive to USB connection, they are cheap and you can get one in any computer store, remove your HARD DRIVE from your Compaq and connect it through USB to your new computer. You can copy all your data and still continue using your old herd drive as an external drive.
Sep 28, 2013 | ADATA A-DATA Nobility Series NH92 500 GB...
MY NH92 ADATA External HDD detected very bad and slow some times it doesnt setected i changed my windows and test it on anothers computers but didnt change in it working. please guide me what should i do?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 19, 2012 | Computers & Internet
I was downloading to an adata 32gb micro sd card. It froze and now I can't do anything. I don't need the data--just the card. I tried to format it in my pc but I get a message that says the...
You will probably have to format the sd card with the latest format from Microsoft called exfat. You can download it from Microsoft, and you shoulf find it can now access the card.
Jul 28, 2011 | Computers & Internet
Nov 09, 2010 | Computers & Internet
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
