Question about HP VP6311 Bulb
My projector shutts dawn after some few minutes working
Shuts off
My Sanyo plc su20n comes on but shutts off after a couple of minutes. Does not give a temp warning just ready indicator goes of and picture goes off. IF you wait a couple of minutes the ready light will...
check the physical nature of the lamp in the projector. around the filament of the lamp, you might notice dark corrosion building around it. this what normally cause premature shut off.
Sep 14, 2011 | Sanyo PLC SU20N Multimedia Projector
Projector cuts off after a few minuts of powering
i suspect the device has cooling issues. the shut down is done to prevent physical damage to the machine's delicate electronics. make sure that none of the airvents are covered and try to remove dust using a can of compressed air. if this does not help, you chould contact a local repair centre for maintenance.
Apr 20, 2010 | Office Equipment & Supplies
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Aug 22, 2009 | Eiki LC-XE10 Projector Multimedia...
Outdoor halogen light does not shut off
some can be reset by removing power for a few minutes.
It would help to have the owners manual for the particular light because I have had some that went into different modes of operation by turning the switch off and on a prescribed amount of times
hope this helps
Jun 04, 2009 | Regent Medical Regent& Painter's Halogen...
Zenith XBS444 shuts off
I just posted the fix for this problem under the post of davidlentz who is having the same problem. Problem is IC706 located on the audio output board Part number is KIA7805A.
Jan 23, 2008 | Zenith XBS444 System
Cinego Automatically shutts off after 15 seconds
had the same problem - replaced the lamp even though it only had 632 hours on it. seemed to fix the problem - 10 hours and 4 moves later still doing ok
Jun 12, 2007 | Radio Shack Cinego D-1000 Multimedia...
HP VP6311 Bulb Logo
43 people viewed this question
Seeker5211
Seeker5211
