Question about Black & Decker PartyMate Work Top Blender
Charging memory do i need to fully discharge batteries before recharging?
The power light on the Ninja Blender flashes and will not turn on.
Make sure the pitcher lid is assembled properly aligning the arrow on the lid with the arrow on the handle. Press down firmly on the handle until you hear a slight click to ensure it is fully engaged. The Ninja will not run if the lid is not assembled correctly & the handle is not fully engaged.
Sep 28, 2014 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Weak battery
then the rechargeable battery is dead. take it to Batteries Plus to have them replace it
Jan 15, 2014 | Waring Wwo100bj Pro Wwo100pc Professional...
Can't unscrew drive socket on vitamin super 5000 yo replace it
The hex wrench only fits in one position, there is a groove in the lip in the top housing and you need to turn the coupling until the hex screw head lines up. The groove is normally plugged with a dob of white silicone. The hex screw is not tightened fully tight on reassembly, the coupling needs a bit of slop.
Aug 23, 2013 | Vitamix 5000 Work Top Blender
How to disassemble blender drive clutch gear
Apr 16, 2013 | Vitamix Blender Driver Clutch Gear Super...
Does not work
Suspect that the battery has died. If still under warranty, take advantage. A new battery is otherwise fairly expensive. Good luck!
Jul 03, 2010 | Coleman 850-870 Single-Speed Blender
The coleman rechargable blender not blending
Subject: Rechargeable Portable Blender Model No. 850-870
I was given one of these blenders for Christmas. I charged it through 3
cycles, used it once and the battery was dead. Charged it through another 5
charge cycles and used it once only to then have another dead battery. I
have put it through at least another 8 charge cycles, and it indicates a
DEAD battery. I have managed to blend two (2) 3/4 full pitchers in total. On
trying to start it now the green light 'flickers' quickly on and shuts down.
This is a totally useless device.
I would like to return it for a full refund, including shipping.
Dec 21, 2009 | Coleman 850-870 Single-Speed Blender
Black & Decker PartyMate Work Top Blender Logo
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
