Question about Elite Kitchen Appliances - Others
Main burners wont light
Pilot on main burners wont light
SOURCE: Pilot Light
i had this trouble with a different fryer. We had lpg instead of natural gas. check youre using the correct gas.
Posted on Oct 20, 2008
  • 125 Answers
SOURCE: Imperial deep fryer IFS40 pilot lights, turn on
Hi there, it sounds like your thermopile, for the pilot, is failing during use, when this happens, the small DC voltage it generates is less than the gas valve requires to stay open, and shuts off the pilot, which shuts off the main burners. Another thing that could be happening, is the hi limit is opening prematurely, instead of shutting of the pilot at 450 deg. it now is opening at 325, or 225 or 250. Sometimes the sensing bulb gets broken where it pass's through the oil tank causing this symptom. If you temporarily bypassed the hi limit to test this also, and it still goes off, you need a thermopile. If it stays on, check your temp with a reliable thermometer, and see if it reads fairly close to your setting, if so, then you need a hi limit.
Hope that helps, and thank you.
Posted on Feb 21, 2009
  • 30 Answers
SOURCE: SR24
It could be a faulty high limit, you can also check the high limit probe to insure it is mounted securely against the through tube wall in the grease. Also check the burner, there are baffles that run through it and when they get old the flames don't move though the burner correctly and will cause the high limit to trip prematurely
Posted on Mar 07, 2009
Treefrog15
  • 127 Answers
SOURCE: Pilot light
Are you sure that the fryer is not shutting off on high limit? The high limit switch will shut off the main burner and pilot as well. The high limit will trip if the thermostat is defective or if it is out of calibration and does not shut off the main burner when the set point is reached within normal operating limits. In either case the oil gets too hot, ~425F. Check the oill temperature when it shuts off. The high limit may also defective. Check for continuity between the high limit leads immediately after it shuts off. If the leads show no continuity at normal oil temperatures, the high limit is defective. The high limit will automatically reset when the oil cools down, so it must be checked immediately after shutdown.
There are other possibilities such as a weak pilot, weak thermopile, loose or damaged wiring or connectors, ect., but in these cases the fryer will often go out randomly, not just when the main burner shuts off.
Posted on Jul 07, 2009
kebah
  • 684 Answers
SOURCE: My fryer model SRTG LIGHT THE PILOT BUT WON'T
check if the thermopile (cylindrical metal standing behind pilot assembly) receives enough heat from pilot flame. if it does, you need to replace the thermopile.
Posted on Mar 31, 2011
Electronic ignition clicks really fast wont light and finally shuts off What is the problem with our Duke E101GV
The ignition module is energized solely by the thermostat output. When the tstat satisfies, all power is removed from the module. The pilot and the main burners go out.
When the module trials for ignition, it must prove pilot flame and then turns on the main burner. If it doesn't sense the pilot for some reason, it also disables the pilot solenoid valve.
If the pilot comes on and stays on, but main burner doesn't come on, there's several possible problems:
  • Faulty ignition module
  • Faulty main burner solenoid valve
  • Faulty wiring between the module and valve
  • A gas blockage at the main burner
All this under the assumption that the main burner is correctly installed.
https://techtown.partstown.com/thread/1710-i-have-a-duke-e101g-convection-oven-that-is-not-firing-not-sure-what-the-problem-is-it-takes-a-long-time-to-get-to-temp-but-when-food-is-put-inside-it-seems-to-never-make-it-to-temp
Apr 20, 2018 | Cars & Trucks
I have a magic chef furnace, armstrong series if the pilot light and ignightor both work but the burners wont light is it possible the thermocuppler bad?
The thermocouple keeps the pilot light on. If the flame blows out it shuts off the gas to the pilot lite only the board that has the igniter on it supplies power to open the main burner as long as the igniter is operating. Sounds like the gas valve is nor working.
Nov 19, 2014 | Magic Chef Refrigerators
I can get the pilot light to stay on but main gas burner won't fire up
If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
Nov 04, 2014 | RTO Suburban Rv Water Heater Dsi Gas Valve...
How do I clean or replace the pilot generator on a Jandy Lite 2 pool heater? The pilot will stay lit but the main burners will not come on. Jumpering the gas valve will ignite the main burners and the
if the pilot stays lit and main burners wont fire you don't need to replace the pilot generator! you have an open safety, poor electrical connection or a problem within the tstat controls
Aug 19, 2014 | Pool & Spa
Old anthes gas furnace with pilot light. burners will not light.blows cold air
Have to think that the thermocouple has failed if the pilot is on but the furnace main burner doesn't ignite
Apr 05, 2014 | Cozy (W352E) Heater
M# 640HORT4 s# H07A090378---MY Pilot Light wont
First thing is to replace the thermoscouple. When you light it you get it a bit hotter then normal. You turn on the main burner which keeps it hot. Then when it goes back to just pilot the flame is not hot enough to hold the pilot valve in.
Replace the thermocouple and you will be fine...
heatman101
Mar 26, 2010 | Water Heaters
Pilot relighting Garland Commercial range
The main burner valve is the oven valve. The pilot will be next to the burner and you either have to insert a long shiskabob stick ( lit) into the hole or lift up on the bottom of the oven (inside) and you will see the pilot.
Feb 09, 2010 | Garland H286 Gas Kitchen Range
The pilot light blows out every time the main burner shuts off. It will light, the main burner comes on, everything seems ok until the main burner shuts off, then the pilot light goes off also as if the...
it's the thermocoupler ( about $20 ) that is bad replace it. if that doesnt do it it is the box with the on/off/ pilot button ( about $175 ) I found a complete unit at www.americanrvcompany.com for $275 plus shipping ($300 total) and that is how i fixed the exact problem with mine.
Oct 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
Main burner too hot & 2nd burner pilot won't
Set t/stat to 250 degrees. If it does not shut off after about 5 minutes, replace t/stat.If shuts off, must be calibrated Pilot may be dirty, flame weak. If flame strong, replace thermopile(pilot generator). If weak, must remove and clean pilot orifice inside pilot.
Aug 29, 2009 | Keating Kitchen Appliances - Others
Pilot lights, main burner will not. Replaced gas valve, no change
I had a problem with the same stove,same model no. etc. Needed new valve. Will replace tomorrow, I will let you know how I make out.
Apr 06, 2009 | Vermont Casting VCS4017 (NG)
Kitchen Appliances - Others Logo
Top Elite Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ruth summersides
Andrew Taylor
Andrew Taylor
Are you an Elite Kitchen Appliances - Other Expert? Answer questions, earn points and help others
