Question about dealeurstore.com WS-A8 Mini Portable Music Loud Speaker with FM Radio TF Card Support
HOW TO CONNECT MY WS-A8 TO MY IPAD
CONNECTION PROBLEM WITH MY WS-A8
How do I connect a Epson l355 printer to wifi with a iPad?
Oct 29, 2015 | Epson L355
My ipad says ipad disabled connect to iyunes
You should try to connect the iPad to your computer, open iTunes and see what it need to do. You probably need internet connection, and should back up if possible.
Aug 16, 2014 | Apple iPad 32 GB 3G Tablet PC
If my computer does not have internet can i still connect to netflix
Can your computer connect to the internet? If it can, it just means that you have a wired internet connection and not a wifi connection on the computer, which means your iPad is just connected to your home network via wifi. If your computer can't access the internet or you know you don't have internet service at home, then you either have cellular service (3G/4G) or your iPad is connected to some other available WiFi from someone else's service.
Aug 15, 2014 | Apple iPad Tablets & eReaders
My IPAD 2 will not connect to the internet, ir picks up the router but will not communicate
In settings go to reset, network settings.. Make sure your router IP leases rent all assigned, set them for a 24 hour lease time.
reset your router with a 30 second unplug. imthemobile guru
Aug 07, 2014 | Apple iPad 2 Wifi 16GB
Why wont Nikon coolpix s6800 connect to Smart device?
What smart device?
To connect it to a computer, you first have to install software and a driver, so the computer knows what camera you connect and what it should do.
When you have a camera connection kit for the iPad, you can connect the Nikon Coolpix S6800 direct to the iPad and it will ask you what to do with the pictures. You direct can access the pictures, download them on the iPad and deleted them in the camera, if you allow the iPad to do so.
I think other devices also should have connection tools and / or apps.
Next time, please also give us the device name and OS it is running.
Jul 27, 2014 | Nikon COOLPIX Cameras
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
May 05, 2014 | Kensington Folio Case Stand for iPad,...
How do you connect a casio privia px 330 usb to ipad 2
Casio don't supply PX330 drivers for IPAD.
Get a Windows 8.1 tablet or connect PX330 to a desktop PC and use IPAD to Remote control that PC.
Apr 27, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Manual for WS-A8 mini portable music loud speaker with fm radio
pretty simple, turn it on for radio, hold mode utton for 2-3 seconds to switch to speaker mode. if u turn it off and turn it again on, it will always start in a radio mode! thats all
Jun 16, 2013 | dealeurstore.com WS-A8 Mini Portable Music...
I have installed Connectify on my Windows 7 laptop. The Connectify network shows up for the ipad and it says it's connected, but no data flows. iPad does not have a working internet connection (using the...
If you want to use the same connection from at&t ..you have to download and install the AT&T communication manager for windows & ..and after that make the connection ..
Here is the link ..
http://www.wireless.att.com/businesscenter/solutions/wireless-laptop/communication-manager/index.jsp
If you have the AT&T on a wireless router ..use the wifi .card to connect to the router ...by ..enabling the wifi ..than click on the card icon ..and scan for networks ....When the router is found by name ...click connect ..and thats all..
Dec 26, 2010 | Computers & Internet
dealeurstore.com WS-A8 Mini Portable Music Loud Speaker with FM Radio TF Card Support Logo
37 people viewed this question
Top dealeurstore.com Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a dealeurstore.com Audio Player and Recorder Expert? Answer questions, earn points and help others
