Question about Sony CDP-CE375 5-Disc CD Changer
The cd will not spin (it did then it quit) and it says NO DISC. where the cd gets held to the motor the front part that holds it in place is loose,Its round and the the cd sits between it and the motor. Is it suppose to be loose.
2 Suggested Answers
  • 6771 Answers
SOURCE: cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Posted on Apr 15, 2012
My Sony DVP-CX995V quit playing DVD's. I was listening to a CD, stoped it, went to menu, picked a DVD and bow it say's " Cannot Read Disc " On ALL of My DVD's. All CD's & DVD's are storebought. I've had...
does the spindle motor even try and spin the disk? Pop the top (8 screws) and watch the loader grab a disk and place into transport. The disc should immediantly start to spin and the little laser should scoot back and forth looking for something. If the disc never spins but the laser is moving, you may have a bad motor, or a bad pickup (transport mechanism includes motor and laser pickup). A replacement for this model is about $125 but you can get the same part out of a cheap DVP-S360 for about $20 on ebay. Just make sure you ask if it works before you buy it on BOTH CD and DVD as its 2 different lasers in that part.
Sep 09, 2013 | Sony DVP-CX850D DVD Player
Cd wont spin
Apr 14, 2012 | Sony CDP-CX300 CD Player
RCA RP 3755 Clock radio: CD player will not spin
Hello
Check the voltage at the terminals of the sled motor. If it is found OK, replace the sled motor. Sled motor do spins the disc inside for any CD players. See the picture of its position.3_1_2012_3_05_08_pm.jpg
Feb 29, 2012 | RCA Audio Players & Recorders
The CD player will play some purchased CD-s but will not play others. The ones that it will not play do NOT iniate the disc motor but a click is heard and the display reads NO DISC. I have cleaned the...
If you can disassemble the CAP(disc holder) and place it on the disc while it is on the spindle and at the same time push the (hidden)lid switch you will see the lazer"s lens move up and down while trying to focus on the disc. If the lazer see's the disk it will tell the motor to turn. If it dosn't see the disc it will not turn the motor. Some model will kick the disc to spin a little while trying to see the disc. This type of player can be tricked into seeing the disc if you spin the disc a little by hand when the lazer's lens is moving up and down. At that point in time it might see the disc and take over the motor and spin up to normal speed. If the disc is an illeagal copy sold as a original the quality of the disc could be the cause. If the player is very clean (no small hairs stuck to the glue that holds the lens in place) (never clean with a cotton swab, use a shammie swab with rubbing alcohol or isopropal 99%) the problem could also be that the lazer is just not strong enough and the whole lazer-motor assemble should be replaced. Older units could use 1 drop of light motor oil on the motor shaft at the bearing to help start the motor when the system kicks the disc to spin. If the player reads the disc at the time you manually spin the disc maybe a good cleaning and oiling is all that is needed. The disc spins clockwise. if the disk spins counter clockwise replace the whole assemble. Maybe simpler, just give the disc a good clockwise spin and quickly close the door and push play while the disc is still spinning. if it starts, there you go. Don't use caned air on the lazer assemble. it will blow the dirt further into the lazer mechanism under the lens and make matters worse! Good luck!!
Oct 29, 2010 | Sony CFD-G50 Cassette/CD Boombox
Disc wont play, when starting up player sounds like its running then gives cant read disc error
it could be one of 2 things, either ur laser is on its way out or the motor in the dvd drive has run out of lubricant. the latter is quite obvious as the drive will be noisy when spinning!!!, if ur tech savvy and are capable of doing so, remove the drive from the xbox and open up the drive casing, the motor is situated under where the disc sits on the little black disc. there are 3 screws holding the motor in place, remove them and with gentle pressure pull the black section from the motor, clean thoroughly then place a couple of drops of wd40 or 3 in 1 oil onto the shaft. re-assemble and that should solve the problem..
Mar 11, 2010 | Sony PlayStation 2 (PS2) Console
I have a pioneer 6 disc changer that won't spin the disc, thus giving the error of no disc. I took the cover off and it doesn't look like the laser eye is on. and the spin motor doesn't engage. Any...
pioneer cd players have the common problem of losing their laser lens due to the glue that holds it in place going brittle over time. try shaking the player from side to side and upside down to see if you can hear the lens rattling about. if you recover the lens, very carefully slot it back in place and apply a tiny drop of glue (NOT SUPERGLUE) to the outside edge of the lens taking care not to get any on the focus area and leave to dry. all should be well after this. i find UHU GLUE in the yellow tubes do a lasting fix but don't use SUPERGLUE as the fumes will coat the lens.
hope this helps?
Sep 26, 2009 | Pioneer PD-M603 6-Disc CD Changer
MY CD PALYER DOES NOT WORK. ''DISC NOT FINALIZED'' IS DISPLAYED.
If your CD player has been working for many hours and cleaning the lens didn't help, then the next thing to do is changing the spindle motor (the one that spins the disc), since the brushes and the commutator get dirty/oxydized with many hours of performance.
The motor can also be cleaned, but it's kinda complicated and delicate to do it, so you might want to change it instead.
The same holds for the slide motor (the motor that changes the position of the laser pickup).
To clean the motor you need to desolder/remove it and open it up (you need to bend out the clamped parts on the motor housing to release the cover - also, mark the position of the cover so you can put it back in place in the same position as it was prior to opening it - some motors have an indentation so that the cover fits in place in only one position).
Then you need to remove the cover (this is a delicate procedure as you can easily damage the brushes).
You can clean the brushes and the commutator using a long pointed scalpel - gently scrub away the brownish/black residues on both the brushes and the commutator.
Now you need to put the motor back together, taking care not to damage the brushes when you put the cover back in place (kinda tricky but it can be done).
After closing it, see if it runs smoothly, you may want to try and run it on some 3 volts - it must run quite silently, with no more than a gentle humming sound.
If it runs ok, you should use a tiny flat screwdriver and a small hammer to bend the housing edge back onto the cover to fix it in place (basically, you need to rehammer back in the clamps that held the cover in place, this is also a bit tricky and delicate thing to do).
Now reinstall/resolder the motor back in place (motors on some brands/models can be worked without removing them).
Well, i've just told you how i repaired quite some CD drives which were virtually dead, i'm actually still using a yamaha which is more than 15 years old (i myself have been using it for at least 10 years now), i got it as a scrap piece, it returned to life after the above described procedure and it actually works perfectly up to date.
Anyway, i guess the easy way is to simply replace the motors (they need to have the same axis dimensions and mount holes as the original ones, also they need to run on the same voltage - things to keep in mind when you are looking for new motors).
Hope you can get it working...
good luck
3rq8 (Triarcuate)
Jul 21, 2009 | Audio Players & Recorders
I works mechanically, but doesn't play the CD
try cleaning the lens first use a lint free swab and GENTLY clean the lens. don't use any liquid on this. if that doesn't work then load a disc and gently spin the disc when it lifts into load posistion. if begins to spin on it's own then replace the spindel motor. if it still does not spin, replace the optical pickup, the EF sensors inside the pickup no longer have the ability to read (see) the disc.
Feb 03, 2008 | Teac PD-D2380 5-Disc CD Changer
Washer is not spinning
The motor coupler could be worn. This is accessed by removing the front of the cabinet. The upper console 1s held on by 2 screws at the base of the upper control at the back corners. The console slides forward then rotates up. Benearth the upper console is 2 gold spring clips which have to be pryed out with a screwdriver, The power cord will have to be disconnected at this time. The whole cabinet will tip forward 45 degrees leaving the base and tub assembly stationary. The cabinet then can be slid out of the way. In the front at the bottom is the pump and motor. Pry off the 2 spring clips that hold the plastic pump in place and pull it out of the way. You do not need to disconnect the water lines. The motor is held in place by 2 spring clips which are fastened to the motor by a 5/16 hex bolts. Remove these bolts and pry the clips out of the way they both will pop off of the motor, do not let the motor drop. Pull the motor out of the way revealing a black rubber disk with a white coupler on the motor shaft and one on the transmission shaft. this whole assembly will likely be damaged and will need to be replaced. The coupler should only cost about $10 at any appliance parts store.
Mar 13, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Sony CDP-CE375 5-Disc CD Changer Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
