Question about RCA Televison & Video
RCA VCR no power - RCA Televison & Video
    Problem Solver:
  • 9 Answers
Have you checked for fuses on the board? the power supply board and also check your household 120v outlet with a lamp or a radio
Posted on Jul 06, 2014
How do we hook up VCR to TV
  1. 1
    Turn off all of your components. This will help prevent any accidental damage while connecting.
  2. 2
    Connect the RF/COAX Out port on the VCR to the RF/COAX/ANT In port on your TV. Use a coaxial cable.
  3. 3
    Connect your antenna to the the RF/ANT In port on the back of your VCR (optional). This will allow you to watch over-the-air broadcasts through the VCR.
  4. 4
    Turn on the VCR.
    • Make sure that the VCR is plugged into the power outlet.
  5. 5
    Set the VCR channel to Channel 3 or 4.
  6. 6
    Turn on your television to the same channel that your VCR is set to.
  7. 7
    Start playing your tape.
or check this site:
How to Hook Up VCR to TV
May 19, 2016 | Televison & Video
We have a RCA VCR Model VR622HF Manf. 9-18-98 that suddenly won't turn on manually OR with remote. I am an experienced Electronic Tech with 43 years @ ATT. I measured the resistance at the AC Plug and read...
If front display lit up when vcr plugged in that means power supply is working and issue is in system control section, and if front display remains dark while vcr plugged in wall socket then power supply is defective.
As you know its an old model vcr so I do not think spare parts would be available any more, I found good option for you to fix this vcr.
Click eBay.com link to get same vcr in working order for $40 that can be used to obtain either power supply or any other board/ parts to repair your vcr.
Hope these info will help you.
Thanks.
Dec 14, 2010 | RCA VR622HF VHS VCR
I was wondering some codes for a RCA tv/ vcr combo
have a old rca television with a build in vcr. connectec a cable box remote works only for volume and channel but power button does not work, with remote was set and stop working call cable company and was told to contact rca to recieve codes for television
Sep 30, 2009 | Philips Universal PH301S Remote Control
RCA TV from 1989 will play VCR
check rca jack maybe some wire cut. check also vcr head maybe dirty.
May 30, 2009 | RCA F20TF10 20" TV
RCA VCR makes high pitched whining noise when it's on...
The power supply is starting to fail. There are a number of capacitors in the power supply that need to be replaced. A local repair shop should be able to fix this easily. Figure on $10 max for parts.
Dan
May 05, 2009 | RCA VR508 VCR
How to hook up vcr and dvd together ?
|DVD| -> |VCR| -> |TV|
1. Connect your VCR to your TV. (Using Antena cable or RCA cables.)
2. From your DVD player, choose the AUDIO VIDEO OUT. Then, connect that to your VCR's LINE IN jacks.
(*)Your DVD player has 3 jacks coming out. Yellow-video, White- Audio Left and Red- Audio Right.
If you VCR does not have the RED jack. Go to a radio shack and tell on of the sales person taht you need to connect 2 RCA audio outs to 1 RCA audio in. (He/ She will give you a "2RCA Male to 1RCA Female" splitter)
3. Finally, play your DVD, put your VCR channel in TV and most important select the LINE channel in your VCR. (This channal may called as L1, Line,... etc)
You should be seeing the DVD in your TV now.
If you want to play the VCR, just put the casset and play.
Important- The VCR needs to be powered on in order to the DVD signals to go to the TV.
Cheers!!!!
Feb 27, 2009 | TruTech TT1620 DVD Recorder
Not able to connect Sharp Model 25h-M60 to Laptop or DVD player
Use a VCR as a A/B switch. Run Cable signal into VCR. Run coax cable out of VCR into television. Connect DVD to VCR (line in) using RCA cables. To use DVD, set VCR channel to L1 or L2 or AUX, depending on VCR type. Set VCR to channel 3 or 4 to watch television. VCR must be powered up to watch DVD.
Apr 10, 2008 | Sharp 25H-M60 TV
RCA big screen TV
Replace splitter RCA #205064, Q4101, U4101, C4102, C4118, C4108
Jan 02, 2008 | RCA P52937 52" Rear Projection Television
My rca control is not working I already change the batteries but nothing happens.Can you help me?
I held down the "VCR" button in the top row and while holding it down I entered the code. Then I released all buttons and pushed power and LOW AND BEHOLD it worked.
RCA- RCR450c universal remote and a Orion VCR
Dec 09, 2007 | RCA RCR450 Remote Control
Televison & Video Logo
79 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
