Question about Vehicle Parts & Accessories
Strange idle issues
I have a 97 Chevy cavalier. The original motor broke a timing chain, so I replaced it with a newer motor with less than 50k miles on it. It ran great for the first 1,500 miles, then started idling funny. At times it won't start unless I feather the throttle, then it dies when I let off the throttle. Other times, when I first start it, it wants to idle around 2,500 - 3,000 rpm's. THEN, other times it's fine. What could this be?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
First of all u should have worked onthe original motor,where in during timing chain failure u have only valves bent ,which could be repaired easily.
now in this engine check the iacvalve (idle air control valve )which is responsible for irratic idle
Posted on Feb 07, 2014
  • Seth Yates
    Seth Yates Feb 07, 2014
    A compression test on the original motor showed two bent valves. Rather than tear into an engine with almost 170 k miles, I chose to replace it with one with less than 50k. Price was right, so it was a no-brainer
95 caviler died while driving, now it will not start. Trying to start, it cranks real rough & catches hard. Any ideas?
If it has the 2.2L engine, and its has more than 60K miles on it, you may have had a timing chain jump. The tensioner for the chains breaks and allows the chain to jump time. They only last about 60-80K miles before this happens, and when it does, it usually bends valves in the head since it is an interference engine. GM knows about this and has done nothing to correct it. You need to do a compression test to confirm the problem. If it shows low compression on one or more cylinders, plan on a replacement or rebuilt head and a new timing chain set. Then either get rid of the car or plan to replace the chain tensioner every 50K miles to prevent it from happening again.
I speak from personal experience here, having had it happen twice on my daughter's 1997 Cavalier.
Oct 25, 2015 | Cars & Trucks
I have a 1989 Chevy Cavalier Z24 2.8 motor how to tell if the timing chain slipped?
If it has a timing chain and its slipped then there will be all sorts of trouble. It may not run, there will be lots of noise and basically you are in for a major rework. Timing chains in a well maintained engine will do upwards of 200k miles. The timing chain is kept tight by spring tensioners and oil pressure. Why do you think there is a problem? You don't say what the symptoms are? Are you sure its got a chain and not a belt?
Aug 15, 2014 | 1989 Chevrolet Cavalier
Driving and it stoped runing
If you have the 2.2L 4 cylinder engine, and the vehicle has more than 50000 miles, the most like problem would be a failure of the timing chain tensioner. This is a known problem and commonly occurs. Problem is, if it happens at highway speed, chances are you are going to have to replace the timing gear set, chain, tensioner, and the cylinder head as there will be bent valves. The only way to avoid this is to replace the timing chain tensioner every 50K miles or get rid of the car.
Oct 24, 2013 | 1997 Chevrolet Cavalier
97 chevy cavalier timing chain diagram
http://www.youtube.com/watch?v=TlwB_yYMZXE
Feb 21, 2013 | 1998 Chevrolet Cavalier
How many miles for a tune up 2005 chevy trailblazer
Most of the car dealers recommend to perform Maintenance services scheduled at 30K, 50K, 90K and so on.
At 30K they mostly inspect all the systems, and replace fuel filter.
At 60K they inspect systems and flush must of the fluids, transmission oil and filter, coolant, brake fluid, differential and transfer case fluid, and replace the air filter. Some replace the spark plus at 60K some at 100K.
At 90K all timing belts are replaced, and the status of the timing chain checked. A deviation of more than 5 degree means, there it is the time ayes on the timing chain.
At the Owners manual for 2005 Chevrolet Trailblazer recommend:
Inspect all the systems at 25K, and replace fuel filter.
Replace engine air cleaner filter, automatic transmission fluid, automatic transfer case fluid every 50K.
Replace spark plugs every 100K.
Maintenance Services for your car are scheduled at 25K, 50K, 75K,100K and so on. All are tune ups but they are not the same.
The only concern for GM is the GM Dex-Cool antifreeze. There are some complaints regarding this product. I recommend to flush the cooling system every 50K to 60K.
Nov 11, 2010 | 2005 Chevrolet Trailblazer Ext
My chevy cavalier runs find at high speed but won't idle The mechanic said the timing chain needs replaced
You have a device called the idle air controller. This controls the idle speed. You can clean it out with spray carb cleaner. This may cure your problem. Also replace the PCV valve.
Sep 28, 2010 | 1998 Chevrolet Cavalier
Rough idle timing chain? 2004 chevy cavalier
Sounds like a 2.4 Quad four engine? If so the chain has either different colored links marked links that have to be aligned with the marks on the cam gear[s] and the crank gear.A chiltons book will show you how.
Apr 17, 2010 | 2004 Chevrolet Cavalier
How to replace water pump on 2.4 chevy cavalier
This is a job for the dealer or cerified mechanic. The front cover and timing chain needs to be remove to access the water pump mounted behind the engine. The pump is driven by the timing chain and timing will need to be reset using special tools.
Jul 20, 2009 | 1998 Chevrolet Cavalier
Does a 2001 chevy cavalier have a timing belt?
You have a timing chain, don't have to change it like you do a belt.
May 21, 2009 | 2001 Chevrolet Cavalier
Check engine light comes on
sounds like a clogged converter
Mar 11, 2009 | 1987 Chevrolet Cavalier 4 Door
Vehicle Parts & Accessories Logo
93 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
