Question about Pioneer PD-F605 CD Player
Reads no disc and doesn't spin
The player will say "no disc" and it will not spin the cd either. I cleaned the lens but didn't help. My daughter sent it thru the mail. HELP
5 Suggested Answers
SOURCE: ERROR-11
yeah i knw...it hap wid ma playerz also ....i showed many electricianz...then ma self ...i removed da player ........n throwed in da dustbin...n bought a new one... u can also do da same thing ;) enjoy
Posted on Jul 29, 2007
  • 1153 Answers
SOURCE: help!!
take out and take top off and look down in it and see if there is a foreign object inside maybe broken disc or paper, remove and clean eye put back together.
Posted on Mar 04, 2008
  • 613 Answers
SOURCE: why does it seem everything
sounds like the lens is dirty buy a disk cleaning kit around 8 bucks this sholuld fix the problem lens is dirty
Posted on Sep 25, 2010
  • 146 Answers
SOURCE: My cd player don't read
try opening player and very very gently try cleaning optic on player with a Qtip and rubbing alcohol
that should help
Good luck
Posted on Mar 13, 2011
When a disc is inserted it spins about 3 revolutions & stops then the message says "NO DISC". So appears to not read or see the disc.
Hi Robert,
First of all, thank you for posting your question here at Fixya.You may try the steps below to resolve the issue.
Assuming that the disc is good.
1.Clean the lens. -Sometimes because of dust and any fine foreign objects the optical lens can'tread any disc. If you have a CD Lens cleaner, play it to the unit. If this isnot available you may manually clean the optical lens. Open the cover andgently clean the eye of the lens by smooth,clean,soft cotton buds. Be carefulwhile doing this, just a gentle stroke only.
2.Check the ribbon - Checkthe ribbon connected to the lens from the main board for scratch, damage. Once it has anopen line then of course the lens can't read the disc, this is because of themovement of the optical lens back-and-forth. Also try to erase the contact by pencileraser. If you've done the steps above and the symptoms still there then thenext step requires you a little knowledge in soldering technique and readingthe ohmmeter.
3.Check the spindle motor -Check the spindle motor that spin the disc with an ohmmeter. You can test itusing the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and itwill spin. Bad motor-reading will drop to low resistance and will not spin or spin slowly.
HopeI helped you.
Have a nice day!
Thanks for using Fixya.
Jan 21, 2012 | JVC XL-MV303 CD Player
Sony boom box model# CFD-So1 serial# 2813391 The CD part says there is no disc in. I tried several DISC WITH NO LUCK. Please help
This error "disc error", "no disc present" or " can\'t read cd". This all error are related to lens problem. If the lens is dirty or if the lens is got cracked or if the lens is getting blocked then it can happen. The lens is very thin glass material. You can say the lens is the "eye" of the unit. If the eye is dirty then it will not see the object. The unit needs to be opened carefully and this lens has to be checked. If any dust is collected clean it. Using the cd lens cleaner helps, but if the dust is got stuck hard or if its any other internal part then the lens cleaner will not help. If the lens is got cracked then the lens assembly has to be replaced.
You can use dry tissue to clean the lens. once the unit is opened. ------------ ------------- In most of the cases, this problem is not related to cd.But still get the cd checked in any other player too, this will confirm the fault. Also try other various cds in the boombox cd player and confirm. But if the cds not playing in other player too then its faulty cd.But this is very rare. Most probably the fault is related to boom box cd player. In the boom box cd player unit there are two main parts. One is cd spinning motor and other is cd reading lens(its also called "EYE" of the cd player).But many times the cd spins internally and does not play. If you can hear the noise of cd spin inside then its lens problem and not the motor. But if there is no spin noise in the unit then both lens and motor are to be checked. The motor is not spinning because its short/blocked or its connections are got loose. It has to be checked. The lens is not reading the cd, because its got dirty or its got cracked and faulty. The boom box cd player lens is made up of thin glass and its very delicate. Many a times dust gets collected on the lens, so the lens stops reading the cd and it do not play. Some times there is no dirt on lens but it gets cracked, if by mistake any pressure is applied on the unit or up-side down cd is placed in the tray or internal short circuit has occurred. These are few possibilities of lens not working. But in most cases its dirty lens causing this problem. SO open the tray by pressing the eject button, then unplug the unit from main power outlet, by keeping the cd tray open. Then take air blower and blow air in the unit. Please remove, if there is any cd in the tray while blowing air. Just blow air for few minutes. Then take a dry tissue and clan the cd placing tray externally and then reconnect the power and see, if that is helping or not. If the problem is same as before, then disassemble the unit and clean the lens manually by hand using dry tissue paper and then see if its helping. But take care while cleaning the lens with dry tissue you doesn't apply too much pressure on lens or any other parts. Also before removing any screw to disassemble the unit. Take a marker with you ready. Just mark the position of parts and screws before removing. If you have a cell phone with web cam in it then take a photo of the internal parts before moving any parts. Disassembly is not very hard but reassembling is not easy. So this pictures and marks with help you for reassembly. ----------But if lens is cracked internally then the lens assembly has to be replaced. If motor wires are loose then you can easily get it re-soldered by soldering machine. You can get it replaced from local cd /dvd player repair center. They have these parts with them. --------------- This should help. Thanks. Helpmech.
Aug 06, 2011 | Sony Boom Box With CD Player & Cassette...
Its says no disc when I have a dvd in it?
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Yours sincerely.
Elect_Comp.
May 16, 2011 | Sanyo DVW-6100 DVD Player/VCR
I bought a bush portable dvd player for my daughter in nov 2010 but didnit even take it out the box until december and now it keeps saying loading then no disc when she trys to use it, i dont have the...
I suspect the laser (lens) of the player. I think the laser (lens) is dirty that's why it cannot read data/files on DVD discs. Dust might be on the surface of the lens and this will not make it load disc and will end up showing "no disc".
Yours sincerely.
Elect_Comp.
May 15, 2011 | Televison & Video
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    My technics sl-p770 doesn?t recognize the loaded CD.A cd is alway spin but not any track in audio cd.
    Try cleaning the lens with a cd/dvd lens cleaner disc. Another thing of note....some cd players simply will not recognize homemade cds, or dics that are not audio discs, or if they were made on a computer.
    Apr 15, 2010 | Technics SL-PS770D CD Player
    Stopped reading cd's
    its means that your CD player cannot read data. actually the problem is in your lens. try to clean frist by cd cleaner disc with liguid and try. same problem change CD OPTICAL LENS.
    Jun 07, 2009 | Audio Players & Recorders
    Pioneer cdj 200 wont read discs
    Hi, try cleaning the lens with a cleansing disk. if this doesn't produce results, it will confirm a major issue within the lens assembly. you will need to replace the lens assembly in this case. it is unable to track or read in this damaged sate.
    May 19, 2009 | Pioneer CDJ-200 CD Player
    Memorex dvd player 2040..disc won't stop spinning!
    This is due to faulty DVD lens/head. Try cleaning it with DVD/CD hed cleaning CDs.If still the problem persists, contact near by service center for replacing the faulty Lens.
    Mar 13, 2009 | Televison & Video
    Won't read disc
    The laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
    Dec 04, 2005 | Aiwa NSX-A115 Shelf System
    Pioneer PD-F605 CD Player Logo
    Top Pioneer Audio Players & Recorders Experts
     Grubhead
    Grubhead
    John
    John
    T-Comtech Repairs
    T-Comtech Repairs
    Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
