Bosch vision have a code of E27 want to take it offf
  • 3 Answers
SOURCE: How do I clear code
I had to call a certified bosch repair center. They sent someone out who entered some sort of code to put the washer into diagnostic mode. Once it was there, the code cleared and my washer worked again.
I asked for the code, and the repairman wouldn't give it to me.
Posted on Sep 29, 2010
  • 3 Answers
SOURCE: i'm getting an error message
I had to call the repairman. He said it was an overheated solenoid in the door lock. The "repair" is to let the washer cool for about 10 minutes (unplug it), then try again. If you're still getting the code, you'll probably need to call a repairman like I did. Though once he put it into diagnostic mode the code "cleared" and it works again. The final fix is to replace the lock.
richroth
  • 9472 Answers
SOURCE: Have a BOSCH 300/500 series washing machine.
The door locking mechanism has malfunctioned and/or is overheating. It is recommended that remove power from the appliance (unplug it) for 30 minutes and try again. If the problem persist, you will need to replace the door lock assembly.
Posted on Nov 26, 2010
rickead1
  • 1998 Answers
SOURCE: Bosch vision 500 clothes washer:
Error code 27 is a bad door lock try opening and closeing the door to try and make the error go away if this does not work then try unplugging the unit for 7 minutes and then replug the unit back in. If the error code still does not go away you would need to replace the door lock assembly unit on the machine this machine also has a 1 year warranty. If the door is locked on your unit you can remove the lower panel and there is a white plastic that hangs down by the drain filter pull this cord in order to open the door of the unit. The issue says that it is either from the connection of the door lock assembly to the contol board, the door lock assembly itself, or the control. If your unit is warrantied I would call for service and if you have any further questions message me them back Thanks again
Rick
Posted on Jun 24, 2011
Macmarkus
  • 2605 Answers
SOURCE: I have a Bosch Vision 500 with a few error codes.
Hello, welcome to FixYa.
Based on your post I understand you have a Bosch WFVC5400 "Vision" series washer. Hopefully the info below will supply you with the assistance you require.
I will start by letting you know though the E27 & E95 error codes are not common nor are they listed in the service manuals, they are known to be associated with door lock and communication errors. These can be due to the door lock mechanism failing and/or is overheating. It is recommended that you unplug the appliance for 30 minutes and try again.
The E01 error indicates a door lock error directly. Though again this can manifest from an improper draining and not necessarily a lock problem.(drain time exceeded).
If the unplugging the uit fails to rectify the errors, you will need to first check the pump/drain lines and if all else fails replace the lock assembly unfortunately....but that's getting ahead of ourselves.
Try this first...
The next step is as follows,
Following this ( or in reverse order it's your call if you think there may be substantial water still present ) I'd do this step first...checking the pump filter. It may be a good plan to have towels close by, or a wet-dry shop vacuum.
It's as follows...
Then the filter removal...
That should resolve the problem, As I also alluded to before, there is a possibility the lock itself is faulty, but not likely.
Thanks for choosing FixYa and good luck. Let me know if you need further assistance or if any of this is unclear.
**NOTE:too much "He" detergent or the use of non-He detergent can also cause too many suds which are opposition to proper operation of these machines and can and DO cause all kinds of error codes**
Once the issue is resolved I recommend running the unit through the hottest temperature possible on the longest cycle possible and add some product called "washer fresh" or "Affresh".
Both are designed to remove residule soap buildup inside the tub assembly and prevent errors associated with soap suds, which usually manifest in errors with the pump and lock.
Regards,
Macmarkus :)
Posted on Aug 28, 2011
How to clear error code e27 on bosch vision 300 washer
1. Set the knob to off.
2. Hold down both the Spin Selector button and the Allergy Rinse button simultaneously.
3. While holding these two buttons down, rotate the knob one click to the left, to the "cold" position.
4. At that point, the display will show a diagnostic code and the unit will enter a self-test mode. In my case, the solenoid latch started clicking repeatedly. I pressed the Spin Selector button once or twice, which resulted in the display of new codes and then the release of the latch.
5. I set the knob back to off, and the washer now appears to be operating.
6. You're done.
Feb 08, 2016 | Bosch Vision 300 Series 3.3 cu. ft....
How do I fix an error code?
The problem it's reporting is a door latch fault. It may be a faulty latch, or you MAY just be able to clear it if it was a hiccup. Try the following six steps to clear the code, then see what hppens:
·Turn the appliance knob to the off or reset position, 12 o'clock.
·Turn the knob to the 6 o'clock position.
·Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position (One click clockwise).
Continue holding the spin button for about 5 seconds
·Release the spin button
·Immediately turn the knob to off
When your turn it back on it should have cleared the error code
Dec 24, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
How do I find the codes on my washer bosch 500
On http://www.onlineonderdelenshop.nl/blog/storingcode-fout-code-bosch-siemens-wasautomaten-wasmachine/ you can find some Bosch codes in Dutch with some explanations.
Oct 19, 2014 | Bosch WFVC540SUC Vision 500 Washer in...
HOW TO RESET E27 CODE ON A BOSCH VISION 300/500/DLX CLOTHES WASHERS
You first of all need to check the pump filter. This is located at the bottom front right of washer. Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean. Of course be prepared for a lot of water and junk. The pump itself is directly behind the filter housing, check there to see if anything is stuck in the plastic blades. It should turn freely. Your washer door will not open if there is water in the washer, just some kind of precaution, so don't force the door.
Pl click helped, if helped
Mar 03, 2013 | Bosch Dishwashers
Front load washer Bosch Vision 300/500/DLX will not drain getting a code of E27 can you help. Can't find the code # in the booklet that came with it.
A code E27 means a problem with the door lock. Try unpluging the machine for an hour and see if it resets the lock.
If not remove the cover on the lower right corner you will see a white plastic pull cord. Pull the cord and pull open the door. If that doesn't reset the door lock you will need to replace the lock.
Nov 22, 2012 | Bosch WFK 2401
E:27 error on bosch 500 series washer
turn the dial to the off position. Hold down both the delayed start and spin select buttons and turn dial to the left one click (cold position). you should then here the door unlatch. let go of the buttons. you will see some other codes p 01, p 02. turn dial to off. it should work fine after this. it worked for me. this should be in the manual.
May 15, 2012 | Bosch WFVC6450UC 500 Series Vision Front...
E-27 blinking
The E27 code isn't often listed in Bosch manuals but relates to the washer door lock.
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
You may need to replace the door lock assembly on the washer.
Jul 20, 2011 | Bosch WFVC6450UC Front Load Stacked Washer...
Just got a brand new Bosch series 500 DLX and it is giving me E12 and E27 errors.
Just fixed the E27 error code. Just turn dial to off and hold down delayed start button and spin selector button and turn dial to the left one click (cold). It should then click and open. open the door and turn back to off. Everything should go back to normal.
Oct 14, 2010 | Bosch Washing Machines
How do I clear code E27 from my Bosch washing machine?
Aug 31, 2010 | Bosch Logixx WFT 2806 Front Load...
I'm getting an error message "E27" on my bosch vision machine but can't fine it in the manual
Mar 23, 2010 | Bosch Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
