Question about Whirlpool Washing Machines
Reverse washer door whirlpool Duet WFW9400SW01
IS THE WASHER DOOR REVERSABLE
5 Suggested Answers
  • 1314 Answers
SOURCE: Whirlpool Duet Sport Washer Door Reversal
well as far as a work around goes you can go to lowes and get longer hoses and cords and swap them around the door on the washer is not reversable because of the door lock how ever the drier door is hope that helps
Posted on Jan 22, 2008
aborcass
  • 2651 Answers
SOURCE: Door reversal for Whirlpool Duet
there is no reversing the door on the washer. the door on the dryer can be reversed and with the execption of a few of the earlier models no kit is required(even then was just a trim kit). is switching theposition of the 2 appliances an option?? as far as wsher vibrating through house heres a new product receiving great response http://www.keshakeaway.com/servlet/StoreFront
Posted on Mar 13, 2008
  • 3 Answers
SOURCE: My Whirlpool Duet Washer, model number WFW9400SW01 will not turn on. The button lock is off and does light up indicating power to the front panel/unit. Any ideas?
if you are mechanical and are not afraid of small wires you can try this. I had the exact same problem on my machine. i very slowly diasssembled the machine. not hard to do. removed the top. unscrews from the back and slides to the back to come off. remove the door. unsnap the plastic plate that goes around the door.it is held on by small snap clip that pop off if you use a small flat screw driver to pry it out. remove detergent tray. and screws that attach it to the inner box. now the hard part. remove the face plate. it unsnaps similar to large door plate.very carefully unclip the circuit boards. they are held in by plastic clips around the outside and white plastic clips in the middle. you must gently pry up and release these clips one at a time. a second person is helpful, so are small needle nose pliers. clean both circuit boards very gently with isopropyl alcohol and qtips. mositen the qtips and clean every inch of the boards. be very careful not to bend or crack anything. you must get all the yellowish flux and any other corrosion growing on the board off. there is one more board that must be cleaned. the power supply board. it is mounted on the top right side near where the face plate wire come through. this is not hard to remove it is held in by small clips. the tricky part is the wires. they are all designed so they cannot be plugged in incorrectly but i have seen what people are capable of. make a map. number them with a sharpie so you know where they go. remove this board and clean it the same way. this on will probably be the worst offender. i cleaned all the boards reassembled and it works like new. below the door is a panel that should also be removed. there is a removable drain filter that should be cleaned out. i found pens and toys in mine. the machine could not pump out the water fast enough and would shut down and trigger f70 and f 20 codes.
Posted on Jun 20, 2009
SOURCE: is door reversible on duet model GHW9100LW1
The way my laundry room is set up I have to have the washer door open on the right. There is not way to switch it. My w/d are stacked and the door to the laundry room is on the left; if they open to the left it will always block the door when it is open. My dryer opens to the right which is the way I want both of them.
Posted on Oct 16, 2012
To reverse the door opening do I need a kit or can it be done just so.
These units are made to have doors to open on the left or right. You just have to look at the hook up now and repeat it on the other side to reverse the door opening.
May 15, 2011 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
How to change doors from right to left on Whirlpool Duet
Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
Apr 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do I reverse the door on my Duet WED9400 dryer?
It's mechanically reversible, but requires a right-hand hinge cover plate (not included with basic purchase) in order to fit properly. The RH hinge cover is part number W10181197. The reversal instructions are supplied by whirlpool when you order the door reversal kit.
If you can't find the hinge cover or whole door reversal kit, or just don't want to buy it; you could trim the LH hing cover by hand, or leave it off and cover the hole into the interior with some tape or something
Mar 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Can the Duet doors be reversed?
The dryer door can be with the purchase of a door reversal kit but the washer door cannot be reversed.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Do you have instruction how to replace the whirpool duet door seal (boot)? modal number is wfw9400sw01. ser#csu2405380
Hi
Please see this video link to replace the door seal on your washer---
Please post for further assistance. Hope this helps...
Daniel
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Can the door be reversed? ie open from left to right-----hinge on right side If so do you have instructions on how to do it?
Due to the shape of the washer door, and how it seats against the control panel, the door cannot be reversed on the Duet washer. There are no cut outs along the door opening to accommodate the door hinge screws and the door latch on opposite sides. The Duet DRYER, on the other hand, CAN be reversed. This may be an alternative configuration for you. Let me know if you want to know how to reverse the dryer door.
Jun 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Is door reversible on duet model GHW9100LW1
The technician informed that we cannot reverse the door on the washer.
Apr 09, 2009 | Whirlpool Washing Machines
I want to change the way my doors open on the washer and dryer
washer door can't be reversed on matching dryer best bet buy longer hoses for washer and longer vent and cord for dryer and reverse their locations
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mar 13, 2008 | Whirlpool GHW9400 Duet Washer
Jan 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
