Question about GE lectric Slimline 1Way VHS Rewinder 85201
Top doesn't pop up (open) at end of rewind - GE lectric Slimline 1Way VHS Rewinder 85201
Top doesn't pop up at end of rewind
Open up the unit and clean the belt to remove the gloss. Use a cloth moist with rubbing alcohol to remove the gloss.
Feb 07, 2014 | GE lectric Slimline 1Way VHS Rewinder...
Open up the unit and clean off the belt. Scrub it with a cloth moist with rubbing alcohol. Also clean pulleys.
Film rewind button stuck
Try cocking the shutter with the camera back open, if that does not pop up the rewind button the camera may need service and lubrication.
Dec 02, 2013 | Pentax Program Plus 35mm SLR Camera
This is kind of embarassing... i received an old nikon f65, and i don't know how to remove the film properly without burning it...
The film should rewind automatically at the end of the roll. If it doesn't, press the two film-rewind buttons simultaneously for about one second. The film rewind buttons are maked with a red film icon; one is also the exposure compensation button to the right of the LCD control panel, the other is the auto exposure bracketing button to the left of the viewfinder.
Once the film is rewound, turn the power off. Slide the release lever on the left end of the body, and the back should pop open a little.
You can download the manual from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Aug 23, 2010 | Nikon F65 35mm SLR Camera
Opening the back of camera
Pull UP on the knob on top of the camera (the rewind knob).
The back will pop open.
Hope this helps!
Sep 08, 2009 | Vivitar V3800N Zoom 35mm SLR Camera
My Nikon N2020 will not open to insert film
life up on manual film rewinder to release the the back to load film
Jul 29, 2009 | Nikon N2020 35mm SLR Camera
I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Jun 07, 2009 | Garden
Rewind!?
If it is an SLR, there is a recessed button on the bottom of the camera that you push, then you flip the little handle out of the supply rear on top and crank clockwise, after the film is rewound and the real spins real easy, lift the supply real with the little handle and the back will pop open.
Feb 05, 2008 | Photography
Pwr cord rewind reel
You have to pop the grey button off for the cord rewind. There is one more screw under there. You have to be very careful, because you can break one of the tabs that hold the button on. In fact, it is almost a garuntee. There are three tabs that stick off the button that hold it in place on the orange hood. There's a long tab about 3/4 inch long on the inside corner of the button you need to be careful of. Good luck!
Jan 08, 2008 | Hoover S1361 Bagged Canister Vacuum
Hope you can help!!!!
there should be a small but long narrow window on the back of the camera that should tell you if theres film in ther or not. to open the camera, flip the rewinding crank (located on the top left) and pull up until the back pops open.
Apr 09, 2007 | Kalimar K-90 35mm 35mm Point and Shoot...
GE lectric Slimline 1Way VHS Rewinder 85201 Logo
620 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
