Question about Jura Capresso Impressa S8 Coffee Maker, Espresso Machine
The coffee is not coming out of the coffee spout
Brand new machine only getting a few drops out of the coffee spout
    Loyalty:
    Visited the website for 30 consecutive days.
    Dedicated:
    Visited the website for 20 consecutive days.
I had a similar problem. I always religiously cleaned the machine when prompted but nonetheless I reached a point where coffee quit coming out of one nozzle. I tried the suggestion to stick a wire up the nozzle to dislodge any residue that was blocking the water. That helped a little and then it did not next time. So I USED A DENTAL WATER PICK on both nozzles and that cleared up the problem completely. MUCH BETTER than wire or paperclip.
Posted on Nov 09, 2016
4 Suggested Answers
SOURCE: leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Posted on Sep 15, 2008
SOURCE: The coffee started coming out the brew spouts to
I had this same problem and called Jura Capresso. They had me straighten out a paper clip and stick it up each spout as far as I could and jiggle it around (after bringing the panel with the spouts down as far as possible) Then they said to **** the panel containing the spouts up and down several times and then press the rinse button. Repeat this process several times. That did the trick for me. They said sometimes the spouts get clogged and just need to be cleared.
Posted on Dec 17, 2009
espressonist
  • 1711 Answers
SOURCE: when making cappucino coffee using
The problem
you describe it can occur if you don't perform the tablet cleaning as describe
in the user manual at page 30, (see link below).
http://www.capresso.com/pdf/inst_z5.pdf
The machine
changes the direction where the coffee will be delivered via a solenoid valve.
The coffee oils that remains inside this solenoid every time you make a coffee
they can dry out and after many coffees and if you don
Posted on Jan 09, 2011
My Nespresso U is sending the coffee out where the pod drops down not through the spout
YOU MUST CLEAN THE SPOUT TO MAKE WAY FOR THE WATER FLOWN PROPERLY TRY RUINING SOME WORM WATER FERST TO CLEAN UP AND MELT THE STUCK COFFEE
Oct 30, 2015 | Nespresso U C50 Espresso Machine...
No water is flowing from hot water spout or to coffee spout. Machine has been descaled when asked and infuser regularly cleaned.
You could try hitting us with a brand and model, either edited into your original question or as a new question
Jul 18, 2015 | Coffee Makers & Espresso Machines
When I turn on the steam function a steady stream of water comes out fow a few seconds and then diminshes to a few drops when the pumps comes on every few seconds , but no steam comes out nozzle. I ha
This is similar to my Saeco. i only drink black coffee so the steam function is very rarely used. When i went to use it recently got same as your description. this then set a 'blocked' code on computer which meant NO COFFEE! EEEKKK.
I used an old soft drink bottle as a resevoir to operate the machine with covers off so i could see an issues. I started at the filter , blew that out with compressed air. then hoses...do 1 at a time ...tank to filter, filter to pump, pump to heat exchanger, heat exchanger to spout (watch this one as it is steam!)
after a thorough strip and assemble i descaled and was good to go. now i make sure to use steam at least once a month.
Feb 11, 2014 | DeLonghi EAM3400 Espresso Machine
Nespresso U coffee does not come through the spout
There are two nozzles in front of the machine attached together, the nose of the bigger one on the top slides into the smaller one on the bottom. When it makes coffee, the spout outside the machine becomes lower so coffee can come out. When it is done making coffee, the spout goes up so water/coffee drips in the drip tray. If one of the nozzles breaks, the spout on the smaller one will not go down and the inside end is lower and coffee goes inside the drip tray. It has nothing to do with cleaning.
Jan 20, 2014 | Nespresso Coffee Makers & Espresso...
Hello, a question from the netherlands here: I have the Saeco Royal Digital about 10 years old (it did 27.000 cups) at 15.000 cups i had it restored, because of leaking & heatingproblem.\r\n Now it...
There are holes in the spouts where coffee comes out and they are getting plugged with coffee residue. Reach behind the spout and find the bumpy pin that is about 1/4" (8mm) and about 1" long and loosen it. Then pull the spout towards you and it will come out. When it goes back in after cleaning, the long end goes in first and connects to the pipe on the brew unit. Push the spout back into position (there is a notch that it slides into) then lock the pin down again.
Feb 02, 2011 | Saeco Royal Digital Plus Coffee...
The left sprout gives less coffee only a few drops how to solve it?
Hi
Spouts become plugged with dried crema and need to be cleaned. Try that.
Nov 10, 2009 | Bosch Benvenuto B20 Espresso & Coffee...
I cannot brew coffee from my saeco magic water keeps coming out of the wand ??? We have just descaled the machine and now when we brew an espresso we get mostly water from the steam spout and only a few...
The pins/valve in the steam valve needs to be replaced, it is not holding the pressure when making coffee. Try adjusting the grind coarser, to test machine about 2 numbers, if you still have the issue then either replace the whole steam valve or the valve pins.
Nov 10, 2009 | Coffee Makers & Espresso Machines
Jura capresso E8
Did it work before this?
Sometimes hard water can build up and cause blockages.
Try mixing hot water and white vinegar (50/50 mix) and try running it through the machine. If this works, run it through a few more times than run cold water through a couple times to get rid of the vinegar.
Good Luck.
Apr 10, 2008 | Jura Capresso C1000 Espresso & Coffee...
Jura Capresso Impressa S8 Coffee Maker, Espresso Machine Logo
274 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
