Question about HP OfficeJet 7310 All-In-One InkJet Printer
Cartridge 91 - HP OfficeJet 7310 All-In-One InkJet Printer
  • Ask HP
    Ask HP Feb 07, 2014
    Hi Barbara Cook, I want to help you with your problem, but I need more information from you. Can you elaborate on cartridge 91. Please provide the serial number of your officejet 7310 printer. Please be specific when describing your problem. Just add details in the comment box?
    Problem Solver:
  • 14 Answers
Hi I'm anil from Mumbai.tryit replacing caridges..my exp.dates. if not solve turn off printer.wipe out all golden points n contacts with clean soft cotton Cloth by iso propyl alchohal( medical spirit) then fix back n recheck. Or if ur print head is detachable by turning the release lever..take out head wipe golden contacts with eraser n make it shiny.
Fix back .good lu k
Posted on Feb 13, 2015
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
Regarding your recent inquiry about the HP 94, 95, 96, 97 or 98 ink cartridge error message/condition and inability to print to your HP OJ 7310 printer, this type of problem is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself. An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; this same failure can occur with a brand new ink cartridge*. While there are workarounds available, they are considered temporary in nature (and do not always work). Please execute the 'Tap 41' Diagnostics Test Report below to confirm which cartridge is actually causing the issue and to check the cartridge's overall electrical health (refer to Procedure C. below) or see our HP OJ 7310 support page: http://inkjet411.com/?page_id=1826
Please first verify the age of the ink cartridge(s)....look at imprinted date on front (or back) of ink cartridge. If this 'warranty expiration date' has expired, then potential cartridge failures can occur due to internal corrosion, etc.
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
PRINTER CLEANING / DIAGNOSTIC PRINTER TESTS:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
    B.Verify the carriage clip (metal restraining band) for the black cartridge stall is installed/present (if applicable for your printer model)....remove the color cartridge and look at the color clip/stall position for a direct comparison. If the carriage restraining clip is missing then you have a mechanical failure of the printer. Check your user manual.
    C.1. You can confirm the black and color ink cartridge's electrical health by running the 'Tap 41' diagnostics test (most Officejet models - see C.2. below for alternative procedure):
      a.Load Letter/A4-size paper into paper feed tray.
      b.Press the * and # keys simultaneously.
      c.Enter 124 (or 123 on some models) at keypad. The 'Underware xxxx' menu should be displayed (or 'Support xxxx' menu).
      d.Use the arrow keys to navigate to the System Menu (on certain Officejet models you may need to go to 'Reports Menu'). Select Ok.
      e.Use the arrow keys to navigate to the "print-mech button tap" menu. Select Ok. LCD screen should display "code = 0".
      f.Use the arrow keys to enter "code = 41" (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern should begin to print. Refer to 2nd video at link below on how to analyze the printed diagnostic pattern.
      C.2. Officejet 6200/6210/6310 Alternative Service Menu Access:
        a.Press the * and # keys simultaneously.
        b.Enter 124 (or 123) at keypad.
        c.Use the arrow keys to navigate to the System Menu. Select Ok.
        d.Use the arrow keys to navigate to the 'print-mech tap test'. Select Ok. Should display 'code = 0'.
        e.Use the arrow keys to enter 'code = 41' (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern should begin to print.
        NOTE: If nothing prints, then try entering 'code=43' (select OJ printer models leverage different test codes).
        REFERENCE: Tap 41 Diagnostics [HP Deskjet 6900 -use HP 93 thru 97 cartridges]:http://inkjet411.com/?page_id=1741
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). A good HP 93/95/97 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video above on how to read the printout.
        You can also test general printer performance by running the 'Tap 10' diagnostic test, use same procedure above and enter "code = 10". Both the 'Tap 41' and 'Tap 10' tests are 'forced print tests' - the printer will make every attempt to print the pattern whether the ink cartridges are good or bad...the patterns should be utilized to diagnose cartridge health. If 'regular' printing is still not possible then one or both of the ink cartridges is damaged.
        CARTRIDGE ERROR BYPASS PROCEDURE:
        It is possible to 'temporarily' bypass the cartridge error message (for emergency printing purposes only - REFER TO 3RD VIDEO). However, if the cartridge is determined to be electrically damaged it will eventually need to be replaced with a new one. http://inkjet411.com/?page_id=544
        NOTE:There are 2 main branches under the service menu, so finding the 'CHECKSUM' menu for your particular printer model may involve some exploring thru the various menus....
        1. Press the * and # keys simultaneously.
        2. Enter 123 (or 124, or 1234) at keypad. The 'Underware' menu should be displayed.
        3. Use the arrow keys to navigate to the Information Menu. Select Ok.
        4. Use the arrow keys to navigate to the 'checksum for relock data input' (or simply 'checksum'). Select Ok. LCD should display a 5-digit number after a few seconds.
        5. Press Cancel several times to completely exit out of service menu.
        6. Attempt to send a print job to printer.
        NOTE:with a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has internal micro-electronic damage and will need to be replaced.
        *Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used. The "Incompatible Cartridge(s)" / "Print Cartridge(s) Problem", "Refer to printer documentation", "Cartridge is not intended for use in this printer" / "Remove and check color/black cartridge" error messages are typically indicative of failed micro-electronics internal to the ink cartridge(s). Also, it is common to have a marginally performing ink cartridge (which was performing ok before) in the adjacent slot (i.e. color), then when a marginally performing cartridge is installed into the other slot (i.e. black), both of the ink cartridge(s) then get flagged with electrical errors. Running the 'Tap 41' cartridge health diagnostics test will confirm the active state of both cartridges.
        Customers who have questions regarding cartridge/printer problems can visit http://www.inkjet411.com or contact us directly at INKJET411HELP@GMAIL.COM
        -Thank you
Posted on Apr 19, 2014
E-91 epson error code
put four new cartridges and run the utility to change cartridge Epson.
In: config panel / hardware and printer / right click on your printer and go to print option and go to "utility (last tab)" and use "replace ink cartridge!
May 24, 2012 | Epson R245 InkJet Photo Printer
How to reset 73/91 Cartridges for Epson CX5500
SSC utility is used for resetting waste ink counter, not for ink level counter (chip at ink tank). If you wish to reset ink level counter (chip), you must use hardware resetter, or use CISS chip with autoreset function.
Oct 18, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Aug 08, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Can not change ink for epson c 91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head carriage to replacement position.
Jun 21, 2009 | Epson Stylus Photo 1400 Printer
Ink cartridge
Here is a link to the printer manual:
HP2575 Manual
Open it and go to page 91 for instructions for replacing cartridges.
Also save a copy of the manual to your computer for future reference.
Thanks for using Fixya.
Jun 11, 2009 | HP Photosmart 2575 All-In-One InkJet...
Black cartridge error
maybe the cartridge you buy is not same brand of your printer,, or try to remove printer driver using the ad and remove program, uninstall completely the driver and install gain
Jun 08, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Canon pixma ip4500
u should carry the printer to Canon Care Centre, they will check the case and if found that the Cartridge u r using is Genuine your Cartridge will be replaced.
Regards,
manoj joseph
+91 9352008418
Jun 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon printer feeds blank pages
Ink Cartridges are either empty or dried up, replace cartridges, if problem persists please revert.
Regards,
Manoj Joseph
+91 9352008418
Jun 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Red prints as "brown"
Either 01 of the ink from the cartridge is emptied or the cartridge has exhausted.
Warm Regards,
Manoj Joseph
+91 9352008418
May 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
319 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
