Question about GE lectric Slimline 1Way VHS Rewinder 85201
Top doesn't pop up (open) - GE lectric Slimline 1Way VHS Rewinder 85201
    Sergeant:
  • 458 Answers
Open up the unit and clean off the belt. Scrub it with a cloth moist with rubbing alcohol. Also clean pulleys.
Posted on Feb 27, 2015
Where can I find the imei # without typing *#06# cause that doesn't work.
Open the dialer and press *#*#4636#*#*
Wait for a menu to pop up and choose phone information, it should be right at the top of
the screen.
Sep 17, 2012 | HTC Wildfire Cell Phone
Dryer died after 2 seconds of operation. Timer motor doesn't not make any working sound. Power is being supplied to the unit.
check for an open thermal fuse located on the blower housing located inside unit,first unplug dryer,then pop top cover up by prying upward on cover,and lay back against wall to keep from breaking wires,now remove 2 screws inside on front panel near the top left & right corners,remove door switch plug and pull outward and toward yourself and then upward now the blower housing will be there and the thermal fuse will be on the back side of this housing,you can bypass it for testing,if it then runs replace this fuse,before closing unit up make sure its clean and the vents are free of lint as if not it will open up the fuse again soon due to heat buildup
Feb 07, 2012 | Whirlpool Dryers
The hand wheel is very stiff and the foot control cannot electrically move the needle up and down either...just humms. The machine looks like it has had very little use. From the 70's and I just...
The top cover just pops open which is why there are no screws. Just push up from the front side and it should open. On older machines, this may take a little bit of force. :)
Aug 26, 2011 | Kenmore Sewing Machines
The freezer door pops open when the refrigerator door is closed.
You're going to need to adjust the hinges on your frig and/or freezer doors.
Your cost: $zero.
There's one hinge at the top of each door & one at the bottom. The hinges at the top are
covered by a triangular shaped piece of plastic that pries up easily with a screwdriver or tack
puller - remember to put down a thin piece of cardboard (as from a cereal box) to protect the
finish on the appliance.
These screws take a 5/16ths inch socket.
Check the screws holding the top hinges first, since they're easier to get to. If the hinges on
either door are loose, you've found the problem - align the doors so the frig door doesn't also
pop open the freezer door and you're done.
If the hinges at the top of the doors are secure, then your problem is with one (or both) of the
hinges at the bottom - probably best to adjust them after emptying the door(s).
These hinges also take a 5/16-in tool, but it'll have to be a combination wrench with a flashlight,
and you'll have to lay down on the floor to adjust these hinges.
Jul 15, 2011 | Maytag MSD2732GR Side by Side Refrigerator
Doesn't start after filling with water - model 110.15962401
check the lid switch,your lid switch is under the top console,open the lid and close it a few times you should hear a clicking sound,open the lid and stick your hands in the back above the tub,there's two clips one on each side that holds the top console down,or you can use a putty knife and stick it under the console and pop the clips,you'll see the lid switch on the left side,part number 8318084 and it's around 20 dollars.
May 09, 2011 | Kitchen Ranges
My front lid pops open when I blip the central locking to unlock the car, and when I am driving and get to a junction it pops open?
I had the same problem, and mine turned out to be a jammed switch. I wiggled, the switch, and the problem went away. The other symptom was that the hood would pop 10s after I started to drive away.
If wiggling the switch doesn't work, look to have it replaced.
Jan 21, 2011 | 2003 Porsche Boxster
I can't open my hood on my 93 9000 cse saab, i pull the latch but the hood doesn pop up at all, please help
The hood release cable could be stuck or came loose.If you use a flashlight and look carefully through the top portion of the front grill you will see two little hooks.One to your left and one to your right.They are kind of between the lip of the hood and the top of the grill.The one on your left is near the top left of the grill and the one on your right is near the top right of the grill.Sorry if it sounds complicated.Another option is to use a thin flat screwdriver,fit it between the lip of the hood and the grill and slide it from left to right against both hooks.Both hooks move to the right to unlock the hood.
Oct 06, 2010 | 1993 Saab 9000 Hatchback
Bottom freezer popping open on its own
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Sep 21, 2009 | Refrigerators
GE lectric Slimline 1Way VHS Rewinder 85201 Logo
729 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
