Question about Electrical Supplies
MY GENERATOR IS VERY HOT WHAT WE DO - Electrical Supplies
    New Friend:
    Problem Solver:
  • 10 Answers
Air cooled? water cooled? inside a room? any genset needs ample air flow and venting,(rad and emissions exhausting away from unit)
if its water cooled and you have ample air-flow, replace thermostat.
Posted on May 07, 2014
Buffalo tools 7000 watt 13hp ohv 4 stroke valve clearance
if you cannot get the specs from on line or from a service agent , generally the following apply:-
water cooled engines
inlet hot .010"--exhaust hot .012"
for air cooled engines inlet hot .012"-- exhaust hot .014"
Aug 30, 2015 | Buffalo Tools Electrical Supplies
When a generator is heating after a few minutes what could be the cause
not enough information to answer. gas or propane?. if new,generator by it's very nature generates energy,and thereby heat. even coiled wires can get warm. what part is hot?
if you've owned it a while, and it is inordinately hot as compared to prior uses, is it lubricated ? running normal otherwise?
Jan 21, 2015 | Electrical Supplies
Honda gx160 petrol generator,gets very hot on the muffler,then starts to backfire and flames come out of the exhaust on the muffler
You need to get the exhaust away from the generator (heat shield) because it is getting to hot and this will cause it to backfire
Dec 31, 2014 | Motorcycles
Stator got hot on my generator
Stators can get hot, but not too hot? how much are you talking. This is indicative of a short in the output wires, and / or overloading with inductive loads. Compressors, motors, fans etc
Apr 10, 2013 | Coleman Powermate Powermate 5000W...
Gnerator not producing ac power
I recently had a similar problem during "Sandy". I forgot to turn off the hot tub before starting the generator and the house lightswhere barely lit, dim, and flickering under the load. I quickly shut itoff andthe hot tub, but not before frying half of my generator. It will only produce 110now, not the 220 usual adn I need to get it fixed. I imaging you may be experienceing the same thing if you can't reset it. My generator has two reset buttons right next to the outlets on the unit itself.
Nov 03, 2012 | Electrical Supplies
The engine runs fine and the generator produces electricity but shortly after start up the generator head gets hot and starts to smoke. What could be the problem or solution? thanks jeff Joyce
If you really mean the "generator head", which I understand as the outer bearing cover of the generator, your problem may be a bad contact or worn out brush-ring assembly, or a bearing problem (not very much believable).
Jul 02, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
I have a yamaha 3000isb generator. checking
That sucks! Maybe it's because your a fireman! LOL
May 08, 2010 | Yamaha EF2400iS Portable Generator
Generator wirring
The generator output hooks to the transfer switch. It senses the power from gen or land power and switches accordingly to allow power into the breaker panel.
Jun 21, 2009 | Honda 6370C - Parallel Power Kit For ...
Electrical Supplies Logo
26 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
