How to divide 3.20 by .48 - Computers & Internet
Is 8 a prime number? And what are the factors for 20? And is 20 a prime number?
No it isn't as 1,2,4,8 can be used to divide it prime's are only dividable by 1 or itself only
20 is 1,2,4,5,10
Jan 23, 2017 | The Computers & Internet
5/6รท11/12=
5/6 divided by 11/12 is the same as 5/6 times 12/11 which is
10/11. 10 divided by 11 is___________.
Sep 24, 2015 | Cars & Trucks
How to divide 1 2/3 by 3
First make 1 2/3 into a mixed fraction and then divide it by 3.
To make 1 2/3 into a mixed fraction, multiply the whole number, in this case, 1, by the denominator (the bottom number) and then add the numerator (the top number). Thus, we get (1*3+2)/3 or 5/3. Now we have to take 5/3 and divide it by 3. I was taught that in this case, dividing by 3 is the same as multiplying by 1/3. 5/3 x 1/3 = 5/9.
If you have access to a calculator you can always check this. On the calculator, do 2 divided by 3 and add 1. Now take that answer and divide by 3. Write down this answer. Now take 5 and divide by 9. Write down this answer. They should be the same.
Good luck.
Paul
Mar 17, 2015 | Office Equipment & Supplies
I HAVE TO FIGURE OUT IF 52,63, 75,31,77,59,87 ARE PRIME NUMBERS OR COMPOSITE NUMBERS
Hi
Here we go
52 - can be divided by 2 - therefore NOT Prime
63 - can be divided by 3 - therefore NOT Prime
75 - can be divided by 5 - therefore NOT Prime
31 - cannot be divided by whole numbers - therefore Prime
77 - can be divided by 7 - therefore NOT Prime
59 - cannot be divided by whole numbers - therefore Prime
87 - cannot be divided by whole numbers - therefore Prime
Hope this is helpful, if so would you please register that with Fixya
Cheers
Mar 08, 2015 | Computers & Internet
How cani i solve "x divided by 9 and x divided by 9 equals 4
x divided by 9 and 9 divided by 9 equals 4, so x divided by 9 equals half of 4 or 2. 2 times 9 equals 18, so x equals 18.
To check, 18 divided by 9 equals 2. 2 and 2 equals 4.
Nov 30, 2014 | Summit Appliances Division Refrigerators
How to divide fractions using calculators?
To divide fractions proceed as you usually do with any number. Just make sure to enclose each fraction in parentheses. You may want to remember a simple rule: To divide a fraction by another, multiply the first one by the reciprocal of the other:
(a/b)/(c/d)=(ad/bc)
Sep 08, 2014 | Office Equipment & Supplies
How do you identify prime numbers
One trick I use is to add up all the digits and divide by 3. If the answer is even, (a multiple of 3), it's not a prime number.
57 = 5+7=12. 12 divides by 3 evenly (4), is not a prime.
59 = 5+9=14. 14 does not divide by 3 evenly, therefore prime.
999 = 9+9+9=27 divide by 3 = 9, not prime
997 = 9+9+7=25 divide by 3=8.3 not even and is prime
May 30, 2014 | Computers & Internet
How do i factor numbers on a ti-30xs calculator
This calculator does not have a key that you can use to find the prime factor of an integer.
You can however use the calculator to find the factors
1. If number is even divide it by 2
Keep dividing by 2, while keeping track of how many times you divided by 2.
If you divided 5 times by 2 before getting an odd number, then your first factor is 2^5
2. Now try dividing by 3, keep track of the number of times you divided by 3 before you could not divide by 3 any more. If you divided 0 times by 3, your second factor is 3^0, or 1 and 3 is not a factor.
If you divided 4 times by 3, your second factor is 3^4
3. Divide by 5, until you can't any more. Keep track of the number of times you divided by 5.
4. Divide by all other prime numbers 7, 11, 13, 17, 19, 23, 29, 31, 37, 41, etc. For each prime number, keep track of how many times you divided by it, until you could not any more.
Example: 23100
Division by 2
23100/2=11550 ---------> 1 division by 2
11550/2=5775 ----------> 2 divisions by 2
Note that 5775 is not divisible by 2. No more divisions by 2.
First factor is 2^2
Division by 3:
5775/3=1925 ----------> 1 division by 3
1925/3=641. 66667 Not an integer. No more divisions by 3.
2nd factor is 3^1
Division by 5 (number ends in 5)
1925/5 =385 -------> 1 division by 5
385/5=77 ----------> 2 divisions by 5 and no more (quotient does not end in 0 or 5)
3rd factor is 5^2
Division by 7
77/7=11 --------> 1 division by 7, and no more
4th factor is 7^1=7
Division by 11
11/11=1
5th factor is 11^1=11
Assembling the factors 2^2, 3^1, 5^2, 7, 11
Prime factorization of 23100 is
23100=(2^2)(3)(5^2)(7)11
Dec 18, 2013 | Texas Instruments TI-30XA Calculator
How do you adjust freezer basket dividers?
We have a similar, though not identical Maytag/Whirlpool refrigerator with bottom freezer. My comments refer to our specific freezer, it is possible that there is some variance in the freezer baskets. Although it LOOKS like you ought to be able to adjust the divider from side to side, with our basket, you CANNOT. the key is to look at the spacing of the wire pieces that make up the basket body. On ours, the spacing at the center, where the divider is factory mounted, is wider than all the adjacent wire pieces. This means that in locations other than the center, the divider does not fit. We just removed the divider to give more flexible placement of items. To remove the divider I suggest first pulling the entire basket out of the freezer. Take your food out so you can turn the basket sideways, and you will see the clip mechanism that is built-in to the divider itself. You need to use a flat screwdriver or similar tool to flex the inner part of the clip back and then wiggle the divider until it pops free of the basket. Repeat process on the other end of the divider.
Aug 10, 2010 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
