Question about Vivitek D510 Projector
Cannot start unit
Projector initially was slow to turn on. After it came up it would last maybe 5 minutes before lamp began to flicker and them the unit stopped projecting. Start button blinked blue. Told problem may be ballast.
Projector posted error, "replace bulb" Projector
Your projector need replacement of lamp unit if you don't want yet you just reset the lamp counter
procedure:
Power on projector
press MENU key
Press right arrow key to select Option
Press down arrow key to select lamp Hours
Press and hold down the ENTER key 5 second (lamp hour counter show red)
press POWER button to turns off the projector
now you power on your projector and no error displaed and no itself turn off after 15 minutes
Apr 13, 2011 | Panasonic PT-L785U Multimedia Projector
Sanyo plc-xt16 Projector After the projector is turned on and the countdown finishes on initial start up the projector shuts itself off within 5 seconds. The fan runs for 1 minute and then the projector...
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Magoo
Mar 09, 2011 | Sanyo PLC-XT16 Multimedia Projector
Casio xj-s41 lamp and temp light amber blinking
FIRST LOCALIZE THE UP/ DOWN/ LEFT/ RIGHT AND MIDLE BUTON- ON FUNCTION CONTROL
OK...
KEEP PRESSD FOR 10 SEC
INPUT / MIDLE BUTTON FROM FUNCTIONS/ AND RIGHT ARROW
RELEASE THOSE BUTTONS
NOW YOU SHULD GET THE ERROR RESETED.
NOW YOU HAVE TO INITIALIZE THE UNIT:
POWER OFF UNIT( FROM POWER BUTTON)
POWER ON
PRESS AGAIN: INPUT/ MIDLE BUTON/ RIGHT AROW TILL SHOWS A SERVICE MENU ON SCREEN
CHOSE INITIALIZING AND RESEAT UNIT.
GOOD LUCK...GO CANUCKS
Nov 30, 2010 | Casio XJ-S41 SuperSlim DataProjector ...
My projector (viewsonic pj452) started flickering. When it started it would flicker once in around 5 minutes but now it happens many times in a minute. I tried resetting it from the menu and through reset...
The power supply needs to provide a constant current flow
to the lamp. Any small change or in the current will be seen as flicker
in the lamp and projected onto the screen.
Problem could be with low voltage power supply, the ballast or the
lamp it self is beginning to wear out.
Jul 15, 2010 | ViewSonic - PROJECTORS - PJ452 1500 LUMEN...
Liesegang dv 560 flex projector with a pulsating image
Ordered a new lamp at dealers cost ($140). Let's see if it was a malfunctioning bulb.
Oct 08, 2009 | Liesegang dv 560 flex LCD Projector
Power problem with infocus lp70+ projector
It seems the power supply board problem. shoud be checked by the trained technician only.
Feb 03, 2009 | InFocus LP70+ Multimedia Projector
Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
Won't piwer on
Tried to turn it on? Sounds like you need to replace the lamp. However, I got an additional week out of my unit. Although poorly dimmed and the red Lamp light blinked constantly for that one week, at least it gave me enough warning to seek out a replacement. But so long as you're not mistaking the Power/Standby or Timer light for the Lamp light then I would have to agree with you. http://store.l-f-l.com/prod/A-1606-034-B Includes shipping to the United States and no sales tax outside of California.
Aug 16, 2007 | Sony XL-2100U Projector Lamp for...
Vivitek D510 Projector Logo
Top Vivitek Office Equipment & Supplies Experts
Miguel Luiz Martins
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
