Question about Hauck Baby Gear
How do i take the back wheels off - Hauck Baby Gear
    New Friend:
  • 37 Answers
You don't say what model so it may be that they don't come off. I have had two pushchairs with removable wheels normally it's very easy to do. On one there was a button in the middle of the wheel that you push in while pulling wheel off and the other was a small metal bar that you pulled outwards while pulling the wheel off
Posted on Feb 17, 2014
I have a jazzy 1107 power wheel chair the back wheels are leaned outward i dont think the back wheels should be leaned outward i think this is what is causing me not be able to be able to turn properly....
Have some one check out that the section has not become loose or broken. IF the wheel rubbers are damaged then you will have trouble regardless of what you do. I consider it paramount that the chair is in top condition for your needs. Have the manufacturer's service agent fix it for you.
Sep 22, 2013 | Health & Beauty
Who do I put the rear wheel back on my mongoose bike
raise the back of the bike and put the wheel between the rear stays place the chain on the freewheel, and pull the wheel back and
then just tighten the wheel nuts.
Jul 26, 2013 | Mongoose 20-Inch Gravity Games BMX...
I've got all the wheel nuts incl locking nut off my Golf back wheel, but can't get the wheel off, what am I doing wrong?
At a guess, you've got alloy wheels, assuming so, this is a common problem.
1) Make sure its on an axle stand, not just a scissor jack, and give the inside of the wheel a good old whack with a mallet, if you don't have a rubber hammer/mallet. Hold a piece of wood against the wheel and hit that.
or
2) Put the wheel nuts back on, just finger tight, then roll the car backwards and forwards, with luck the weight of the car should do the work for you.
When you put you wheel back on, put some copper grease on the hub to stop it sticking again.
Jan 30, 2012 | Cars & Trucks
When pushing my quinny the back wheel starts to come of byitself
Hi Lisa - It could be that if there is dirt and debris on the wheel axel or inside the connection it would prevent the wheel clicking in properly. Remove both back wheels and give a wash in warm soapy water then dry thoroughly before putting back into place. Does the same side wheel fall off even if you swap the back wheels over? If this is the case it would indicate a chassis problem rather than a wheel problem. If it is the same wheel that always falls off it would suggest a wheel problem. Contact customer services on 01284 413 141 Mon-Fri 8.30-4.30 or e-mail to uk-customercare@dorel.eu for further advice
Nov 14, 2011 | Quinny Buzz 3 Stroller
Took chain off to remove wheel and am unable to get chain back on correctly. 2001 Magna oasis 26" 7 digit shifting speed. Unablew to locate manual...can you help?
Put the chain to the inside of the front cog wheel, beside the pedals, first but not onto it, so you have plenty of room for pulling the chain to the rear. Fit the wheel back into place and before tightening it pull down the spring loaded arm, with the small cog wheel beside the back wheel. This takes the tension off the chain and allows you to put it into place on the back wheel. Tighten up the wheel. When it's tightened fit the chain onto the top of the front cog wheel. Lift the back wheel off the ground and turn the pedals forward. The chain will click onto the front cog wheel when you have turned the pedals one complete turn.
If you need to see a picture of how it should look at the back you can see one at http://orangecounty.craigslist.org/bik/2409696114.html
May 29, 2011 | Cycling
How do you ajust rear wheel so it is alignedright?
1.loosen the bolts on either side of the bike at the rear of the frame. this is what allows the back wheel to be adjusted. aka wheel adjusters.
2.next loosen the wheel itself.
3.pull the wheel back until there is just a tiny bit of slack in the chain.
4.next tighten those wheel adjusters on either side of the wheel. To get the wheel dead centered count the threads visable and make them the same on both sides.
5.tighten the wheel back up as you pull it back against the wheel adjusters.
good luck and safe riding
Sep 14, 2010 | Harley Davidson FLHTC - FLHTCI Electra...
How do i adjust the hand brake on a e46 bmw
1st loossen up cable adjusters then remove rear wheels, remember safety 1st support car and through wheel stud hole you can turn adjuster star wheel with a small screwdriver till wheel locks then back off 4-6 clicks till wheel runs free next re adjust hand brake cable back up, again till wheels lock and again back of till free!
Apr 25, 2010 | 2001 BMW 3 Series
Evenflo Tandem stroller back wheels replacement
You may be able to remove the axle of the new front wheels and remove the wheel from the assemble, and then do the same with the rear wheels. Next replace the axle with a bolt and nut.
Dec 19, 2017 | Baby Gear
Baby Gear Logo
80 people viewed this question
Top Hauck Baby Gear Experts
ray gallant
Dorel UK
Dorel UK
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Hauck Baby Gear Expert? Answer questions, earn points and help others
