Question about LG 32LF2510 32 in. HDTV LCD TV
Lg 32LF2510 dark image - LG 32LF2510 32 in. HDTV LCD TV
I have a LG 50LA6200 LED TV, about 3yrs old. While watching it, the screen suddenly went black, the audio is fine.
In the dark with the set on do you see light if you look through the vent holes in the back?
Oct 19, 2017 | LG Televison & Video
Faded LED TV Image
It's the T-con board. You can get one from these guys: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 08, 2017 | LG Televison & Video
Lg ku990 flash will not fire when i take a photo in the darkness.
my lg viewty flash doesnot work therefore image is always dark.......please suggest a solution
Nov 18, 2010 | LG KU990 Viewty
LG Plasma screen just went nuts
It could be any of 4 boards, either take it in for service or get a new set.
Nov 16, 2017 | LG 42PC3D 42 in. Plasma Television
Tv has died
When the TV is on, if you look at the screen and can see dark images, then you will need to replace both the inverters. The inverters drive/power the back light inside the LCD to show the images. You may have to try and different channels and or inputs to truly see if you can see dark images while the TV is on. If you are hearing audio from a channel or an input then you should be able to see the dark images if just the inverters are bad.
If the screen is dead black without any dark images, then typically your LCD screen/module is bad.
If the TV powers up (power supply is good), you have audio and the remote will work with the TV (the main board is good), the only parts left is the inverters or the LCD screen/module.
I can get you LG part numbers if you need them.
May 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Screen just suddenly went dark!
If you can see a faint picture with streaking you most likley have a defective Zsus module Part Number 6871QZH036B Description PWB(PCB) ASSEMBLY,DI List $226.14 Please rate my info
Feb 20, 2009 | LG 50PX4DR 50 in. Plasma TV
Dark picture on lg dlp tv
Did you use a generic replacement? Many TVs have a dark picture after replacing the original lamp with a generic. The other issue I've encountered are TVs that have been exposed to cigarette smoke will develop a dark, discolored picture over a relatively short time.
michtech
Feb 19, 2009 | Samsung HL-R5668W 56" HDTV
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
LG 32LF2510 32 in. HDTV LCD TV Logo
