Philips mcm204 When I put a CD in it, it keeps reading..
Recording
The No OPC message means that the unit can't record. The laser power calibration for the burner failed the internal test with that disc. Was the disc a blank disc? Make sure that you use a clean CD-R or unfinalized CD-RW. Try a different lot or brand of CD-Rs or CD-RWs. If the problem persists, then the laser on the recorder is damaged. If the unit is under warranty, contact Philips. However, based on the date given on the manual, this may not be worth finding a shop to fix the unit. DVD/CD burners for computers are fairly cheap but I'm not sure of the specs for a replacement CD burner for inside this unit.
The manual is available from Philips here: www.p4c.philips.com/files/c/cdr765bk/cdr765bk_dfu_eng.pdf . The trouble-shooting information is on page 21 (page 23 of the PDF).
I hope this helps.
Jul 11, 2013 | Philips CDR765 2-Disc CD Recorder
DBB (Dynamic Bass Boost) is allways on :-(
It doesn't mention it in the manual. However maybe it stores the DBB position when you first set up the radio. If so try resetting the radio. But make certain the DBB is off before you do.
This is how to reset:
In standby mode, press and hold?? on the
system until "AUTO INSTALL - PRESS PLAY"
is displayed.
Press ?? again to start installation.
All previously stored radio stations will be
replaced
Jun 08, 2017 | Philips Audio Players & Recorders
Philips CDC3 Disc changer keep getting error check CD
Sorry, not a solution but I have exactly the same error.
Hope someone can give us a fix - I'm on my third CDC3 changer already..... Not very reliable are they?!
Jan 06, 2010 | Philips Audio Players & Recorders
My philips cd recorder is not recording
the recorder philips cdr-778 put my 80 min sony cd-r audio in it start recording 20 second on track 1 go to track 2 for 20 second then stops goes to update some times it reads no disc when installing the disc we have been recording at the Church for the past 2 years
from clyde
Mar 02, 2009 | Philips CDR778 2-Disc CD Recorder
PHILIPS CDR 606 RECORDER. I was useing the above machine till yesterday without any problem at all. Today i keep getting message "insert CD" after i have put a cd in.. I have tried differnt...
Either the optics have failed or the lens is dirty. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Basically the unit can not read the disk and is requesting that you insert one. If the cleaning fails to resolve the problem, you will need to have the optics replaced.
Dan
Jun 13, 2008 | Philips Audio Players & Recorders
44 people viewed this question
 Grubhead
Grubhead
