Question about mapmyrun.com
Unable save route
Having mapped out a route on my lap-top the site says saving but won't save. The routes will save on someone else's lap-top
  • 3 Answers
Go to the forgotten password and enter ur mail or phone number then u reset ur pasword from e-mail or phone number with given a security code which sending from +3266 and chnge ur paswrd nd enjoy facebook...
Posted on Feb 07, 2014
HOW DO YOU CONTINUE ON A SAVED ROUTE AFTER YOU HAVE MADE THE FIRST STOP? I WENT BACK TO THE ROUTE AND STARTED IT AGAIN BUT WHEN I PROCEEDED, IT JUST TOOK ME IN A CIRCLE BACK TO WHERE I JUST WAS. ALSO,...
When you reach the first stop on a saved route the satnav should automatically set the next stop as it's destination. If it doesn't it's possible that the spot you saved as your first stop was not exactly right i.e. you didn't drive to where it's marked on the satnav. If this is the case you need to mark the spot by driving to it and pressing the car (which shows your location on the satnav) and this gives you an option to save present location. Save it and use it instead of the one you entered by address. Then when you're setting your route you'll find it in your favourites and add it from there.
To get back to the map go back to the screen which shows WHERE TO and VIEW MAP. Press VIEW MAP and it will bring you back to your map and should continue with your route.
Aug 01, 2011 | Garmin nuvi 1490T GPS Receiver
Loses map disply
You might have configured it to save battery. One battery saving feature involves turning off screen between instructions and another always turns off screen. See Screen capture from the manual (Go 730)
Jul 21, 2010 | Tomtom ONE GPS Receiver
How do I transfer routes to my Garmin nuvi 250
The Garmin Nuvi 250 does not support loaded routes. You'll have to load the waypoints, and then just go from one to the next, to the next. You can transfer the waypoints to the GPS unit with a USB cord.
Jan 31, 2010 | Garmin nuvi 250 GPS Receiver
Transfering Routes to GPS device
Once you have transferred it using mapsource it won't automatically be in the custom routes. You still have to "import it from a file". Unplug your garmin from the computer then go to "Tools" then "My Data". That's where you should find the "import route from a file" button. It won't import if you already have 10 custom routes saved so you'll have to delete one.
May 03, 2009 | Garmin Nuvi 550 GPS Receiver
NO DETAILED MAPS FOUND TO SUPPORT ROUTING
You need to unlock the unit. I had the same problem with one that I have. Try this:
The No Detailed Maps Found That Support Routing message could be due to the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message No Detailed Maps Found That Support Routing disappears.
  • If you get a Can't Unlock Maps message following this error remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file.
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device.
Retrieving your unlock codes:
  1. Log into your myGarmin account: https://my.garmin.com/mygarmin/customers/myGarminHome.faces
  2. Select myMaps.
  3. Select Manage Maps.
  4. Select the device from the drop down menu.
  5. The unlock code is located under the "Maps installed on this device" section.
Creating an unlock code file:
  1. Plug your Garmin device into the USB port.
  2. Double-Click on My Computer or Computer located on the desktop.
  3. Double-Click on the Garmin or nüvi drive.
  4. Double-Click on the Garmin folder.
  5. Right-Click in a blank space in this window.
  6. Move your mouse over the word New.
  7. Select Text Document.
  8. Press Enter / Return on your keyboard.
  9. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad.
  10. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces before or after.
  11. Select File.
  12. Select Save As.
  13. Change the Save As Type to All Files.
  14. Type gmapprom.unl in all lower-case letters for the File name.
  15. Select Save.
  16. Close the Notepad window.
  17. Delete the New Text Document file.
  18. Disconnect the GPS device from your computer.
*nuvi x70 owners with transatlantic mapping will need to follow the Creating an unlock code file instuctions above for their U.S. mapping and then create another unlock file for their European maps:
  10. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces before or after.
  11. Select File.
  12. Select Save As.
  14. Type gmapprom1.unl in all lower-case letters for the File name.
  15. Select Save.
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen.
  2. Touch Settings.
  3. Touch Map.
  4. Touch Map Info.
  5. Select the checkbox next to the maps to be enabled on the device.
If you continue to receive the No Detailed Maps Found That Support Routing message after completing these steps please contact Garmin Support: http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Feb 03, 2009 | Garmin nuvi 260W GPS Receiver
How to load maps from google to garmin
This solution works for more than the 760. i think it will work for all 6xx and 7xx series.
a simple solution to convert Google maps to Garmin routes and is found here:
http://www.elsewhere.org/journal/gmaptogpx/
In essence, you create your route in Google maps and then click the recommended url bookmark.
Save the GPX file to the Garmin device and from "My Data" (under Tools) convert the file to a route. You are done.
hope this helps pls appreciate by rating as fixyaa thanks
Nov 23, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Unable to send and open data sent to my Garmin GPS from Anquet map. I planned a route on my Anquet map software with wayponits etc but was uable to send it to my gps. I have enquired with Anquet and they...
Currently, the POI Loader only supports CSV files because that is the format that most data vendors support. POI Loader may support additional formats in the future.
MapSource only supports .mps, .gdb and .gpx files. You can save files as .txt files if you wish to use this data in other applications.
Sadly Garmin does not produce any software which can convert .txt files.
However, this maybe possible with GPS Utility. Please note GPS Utility is not Garmin software and Garmin does not support this. Click on the following link for more information:
www.gpsu.co.uk
Oct 13, 2008 | Garmin GPS
Audio turn by turn instructions not functioning -Magellan Roadmate 2000
I am having this same problem. My Magellan was frozen on an old route. I had to completely reset it. This deleted all of my old saved information. Since I did this, it has been mapping correctly, but there is no audio. The volume is turned all the way up. Can you help me fix this problem?
Dec 27, 2007 | Magellan GPS
Route calculation error
I was having the same problem and contacted Garmin support.
What I had done was turned off the Basemap that came with the unit. I only had the mapsource map street map on which I had purchased separately.
The technician basically said the unit needed the basemap to "locate itself". Somehow the basemap supports any maps you purchase separately. That seemed odd but once I turned the Basemap back on it calculated the routes and the error message went away.
If you have the Basemap off, try turning it on from the Map Setup - Information window.
Hope this helped.
Oct 01, 2007 | Garmin GPSMAP 60CSx GPS Receiver
mapmyrun.com Logo
66 people viewed this question
Top mapmyrun.com Computers & Internet Experts
David Payne
David Payne
Are you a mapmyrun.com Computer and Internet Expert? Answer questions, earn points and help others
