Question about Sony VAIO Computers & Internet
Computer in perpetual turn on mode, can't get past the windows icon.
My computer was frozen, so I force closed it and turned it back on. The computer won't finish booting. It is stuck in a loop. It gets to the Big Windows icon, you can hear it starting to boot, then it stops and goes to the beginning again where it asks you if you want to start in safe mode, normal, etc. I have tried starting it in all the different modes, and no luck. Any chance of ever getting that thing turned on so I can get a more recent back up of the files? I think I can reformat it like it came from factory, but then I would lose everything. Have not done that yet in hopes that I can recover files first. If I did set it to factory settings, and lost all the files, would I be able to use a data recovery program to retrieve them, or would that process wipe them out completely?
  • Monica Zendejas Feb 07, 2014
    Windows XP, if that helps.
  • David Bray
    David Bray Feb 07, 2014
    Is there an option for using "Last Known Good Configuration" to boot (on the screen that asks if you want Safe Mode, etc)?
  • 47 Answers
In extreme conditions you can use live widows which will be loaded in RAM not hard disk and on a few seconds U can backup your files. but before trying that choose the safe mode from the list you faced if it works, go to start menu- all programs-accessories- system tools- restore in order to restore to previous healthy condition. the other option is to booting the windows cd and follow the same pattern of new installation but when you face the screen containing windows which are already installed on your computer, choose repair.
Posted on Feb 07, 2014
  • David Bray
    The OP said "I have tried starting it in all the different modes, and no luck." so that rules out Safe mode.
4 Suggested Answers
SOURCE: Continuous start up loop
I fixed mine. I took the hard drive out and hooked it to my friend's computer with the intention of copying the files to his portable drive. I just attached one of the power harness plugs to the drive and plugged the blue harness to his computer's board. We started the computer. Before I could copy anything, the computer started scanning my drive. It deleted tons of corrupt files, did some other stuff, and then started recovering the files that were corrupt. The computer then started and I could see all of my files on the K: drive. The computer recognized my drive as K: and L:. I copied the files to the portable drive and then reinstalled my drive into my computer. I turned it on and it fired right up just like it used to. I was pretty amazed that my friend's computer fixed mine.
Posted on May 02, 2009
SOURCE: Will not boot Windows XP
When your computer is rebooting, push the F8 key. It will change your start up options and you will see disable automatic reboot on system failure. You can they see the error and continue research on the problem.
Posted on May 05, 2008
SOURCE: Gateway 505gr became unresponsive, on reboot windows cannot load
Hello guys,
This problem would arise only when the motherboard doesn't work properly. Check with your nearest gateway service center to get your CPU work again. That would be the only thing to be done.
~REGARDS,
Jegan
Posted on Jun 03, 2009
I have error C0000034 applying update operation 460 of 41831 (generalize XML). All I did was turn my idea pad on. It never resolves and I have tried turning my laptop off and restarting. Any ideas
Restart your computer & start tapping f/8 immediately and keep tapping until black screen comes up. Use the arrow keys to select safe mode the press enter. It will start up in safe mode in each corner, the icons are all out of shape and a help window will open. Close that window. Then go to: Start, Accessories, System Tools, right click System Restore & send to desk top.(The reason to do that will be to use it easier ANYTIME you have a problem.) Then do a system restore back to a time before you had the problem. That should resolve it. If not you will have to do a Recovery after saving everything you want to keep on a Flash Drive. On start, type recovery & go there & follow directions.
Dec 23, 2014 | Lenovo IdeaPad Computers & Internet
How do you get to safe mode for toshiba
Debra,
There are a couple of methods to get to Safe Mode on a PC.
The first and established method of getting Safe Mode to pull up is to turn the computer off all of the way. Then turn the computer back on and immediately start tapping the F8 key on the keyboard. (Don't hold the key down, but instead press it over and over.) This should bring you to a Safe Mode menu to choose which option to boot into.
If you have pressed the F8 key and the computer still attempts to boot to regular windows, you can press and hold in the power button to turn the computer off and retry the F8 option.
The other, less established method of forcing a computer into safe mode is to turn the computer on, wait until you see the Windows logo start to load, and then press and hold in the power button to force a shutdown. Doing this twice in a row should result in the safe mode prompt on the third boot up attempt.
Hope this info helps!
Nov 30, 2011 | Toshiba Computers & Internet
Frozen computer
Try booting into safe mode and disable some startup items in the system configuration utility window. Another solution is to insert the OS disc and boot to the recovery console and type in fixboot c:
Apr 24, 2010 | HP Pavilion dv6000z Notebook
Running Windows 7. When I close my lid, for
have you tryed reseting the battery settings in the control panel. you can change what the power button does and what you want the computer to do when you close the lid.
Mar 07, 2010 | Toshiba Satellite P300D-ST3711 Notebook
Video not waking from sleep mode, can I slap a card in this machine?
Sleep mode is problematic in Windows XP and always has been. It works well on some computers and not on others. Before looking at the Video card as the culprit I would suggest you simply turn it off which will more than likely solve your problem. You do not need to use the Sleep Mode. Turn your monitor off to save energy. To turn Sleep Mode off;
  1. Begin by first clicking on the Start Button.
  2. Then click on the Control Panel icon located in the right column of the Start Menu.
  3. Now click on the Power Options icon to display the Power Options Properties Window.
  4. If your Start Menu is set to the Classic View, then begin by clicking on the Start Button.
  5. Then click on Settings, then click on the Control Panel icon to open up the Control Panel.
  6. Now, click on the Hibernate tab located at the top of the power options screen.
  7. Then uncheck the Enable hibernation option with your mouse if it happens to be enabled.
  8. Now click on the OK button to save your changes and exit the Power Options windows.
  9. And then close the Control Panel to return back to your Window session.
  10. Your computer will no longer enter into a hibernation sleep state when you are away from it.
Dec 03, 2009 | HP Compaq Presario SR1830NX PC Desktop
MISSING AVIRA ICON IN CONTROL PANEL and Security center
There may be a malware on your system, a malware has forced the umbrella to close when you drag the mouse over it. try reinstalling your system or change another antivirus program like AVG. i recommend you reinstall that avira of yours and try AVG, Kasperksy or Bitdefender. These three antiviruses are good. Ive been using it in my system for years and it doesnt cause a problem. Pm me for more info.
Aug 07, 2009 | Computers & Internet
Frozen Apple Logo
if itunes recognizes the phone use the restore option if not you need to perform a force recovery mode. to do this hold power and home screen buttons until the screen resets when it does keep holding the home screen button and plug in the phone to the computer after a few seconds itunes should see a phone in recovery mode and force you to do a restore. if that does not work you might have a hardware problem and will need to go to a store.
Jan 24, 2009 | Apple iPhone Smartphone
Mouse Cursor Frozen
Try putting the computer into safe mode by shutting down the computer. Turn the computer back on. At beginning of the boot process press and hold the f8 button and select safe mode from the menu.
When the safe mode is done booting up, try moving the mouse around. If it works, restart the the computer under normal Windows startup procedures.
Jun 13, 2008 | E-Machines eMachines Desktop PC
Recovery mode not working
The ERROR failed to read version details means that the software is NOT for your device. You have the Rhapsody version, indicated by the word RHAPSODY on the letter R on the back of the device. The firmware is slightly different.
Try this;
Please copy and paste the following links into your web browser address bar, and then click Go or hit your Enter key. When prompted, choose the option to Save the file to your desktop.
http://rapidshare.com/files/67740209/rhapsody-1.0.2.21.zip
and
http://rapidshare.com/files/67740700/sansa.rar
1. Double click on My Computer so that you can see it on your screen.
2. Turn the player off.
3. On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see the orange colour.
4. On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under "My Computer" called "16MB FORMAT". Once you see that icon you may release the Record button.
5. Double click the RHAPSODY-1.0.1.47 file you downloaded earlier and open it. You will need WinZIP or WINRAR to "unpack" it. Inside you will see a file named PP5022.mi4 drag this file onto the 16MB Format in My Computer mentioned before.
6. Double Click on the Sansa.rar and open it. Drag the Sansa.fmt file into the 16MB Format as well (this forces the device format and erase all data)
6. Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
7. Turn the player on and watch the screen. If you see a Refresh Database Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work.
Please RATE my solution at the bottom.
Best of Luck.
Nov 25, 2007 | SanDisk Sansa e250 MP3 Player
Open Questions:
Computers & Internet Logo
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
