Question about Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Rheem furnace blower motor wiring - Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
    New Friend:
  • 46 Answers
Uh huh... and then ?
Posted on Feb 08, 2014
Is Aprilaire 500M suppose to turn on when furnace motor turns on?
The humidifier should turn on and off with the blower motor of the Furnace. This can be done by wiring the the humidifier to the HUM terminal on the furnace control board and then stepping down the power with a transformer. If the humidifier has it's own tarnsformer then a current sensing relay can be used by attaching it to the blower motors common wire.
Jan 13, 2013 | Aprilaire Humidifiers
Have a aprilair 550 for some time. Installed a new Lennox G61MP furnace and the technitions failed to reconnect the wiring that powers the humidifier. Need wiring schematic. Does humidifier transformer get...
Hello, yes the transformer will get a 120 volts from the Furnaces control board, there should be a terminal labeled HUM on the control board. You need to bring 2 wires one from HUM and one from a nuetral tap on the board to the line side of the transformer, this way every time the blower motor on the Furnace turns on the humidifier will aswell.
Aug 23, 2011 | Aprilaire 550 Humidifier
Instructions on how to install the current sensing relay i had my furnace serviced and the tech told me this is what i need but if i can do it myself id rather the part is $60
You take the current sensing relay and put the blower motors common lead thru it, usually will be the white wire going from motor to control board. Then you take one of the wires from the current sensing relay and attach to humidistat and then take the other wire from current sensing relay and connect to transformer. This way everytime the furnaces blower motor turns on the humidifier will turn on and when the blower turns off so will the humidifier.
Dec 17, 2010 | Aprilaire 50 Current Sensing Relay...
I would like to direct wire the humidifier to the furnace so evey time the furnace goes on so does the humidifier no humidistat I have a Heil NUGM100EHA1
connect a 24 volt,20 va transformer to the wires supplying power to the indoor blower motor of furnace, connect the primary wires to heat speed of furnace motor, then connect the two low voltage wires to the secondary side of transformer, good luck.
Feb 15, 2010 | Aprilaire 700 Humidifier
I dont know how to remove the blower motor
Hi, I need to know what type heater you have. If you have a furnace, gas fired in the garage or a closet, kill the power.Remove the panel to expose the blower motor. Mark your wires as you will have 3 to 4 for different speeds.There is a hex screw at the front corner of each side to remove.Grab the blower housing and slide it out of the furnace. To take the motor out of the blower wheel, loosen set screw on shaft. Use rust buster on 1/2 shaft. Loosen belly bracket on motor, and tap the shaft end until the motor falls out. If you have something different, please let me know what you have and I can help you.
Sincerely,
Shastalaker7
Dec 04, 2009 | Humidifiers
I have a carrier furnace, humidifier valve popped fuse
hook up the new transformer to the white (common) from the blower motor, and the lead from the blower motor hooked up to the heat term on the board. (just cut the wires and wire nut all three together)
Nov 18, 2009 | Honeywell HE360A1027 Whole House...
Furnace blower blows cold air
It is possible that you did not set the new blower on the proper speed. Black wire is high. Blue is medium. Red is low. If the fan is operating to slow it can run to hot and trip the high limit control. Make sure the filters are clean. When the old motor went bad, the problem might not have been discovered rite away your high limit control might need to be changed.
Also anytime you work on a furnace you can kick up some dust. Always clean the flame sensor.
Good Luck
HVAC Teacher
Mar 08, 2009 | Honeywell Power Humidifier: Furnace...
How do i hook up my humidifier using a seperate transformer
If you chose to install this with an auxilary transformer. Turn the main power off to the furnace. Mount the transformer on the handi box to the furnace or inside the furnace cabinet. Wire the primary wires from the transformer to the main power coming into the furnace. Connect black to black and white to white. Wire the secondary side of the transformer in "series" with a #50 relay, the humidistat, the solenoid valve and back to the transformer. Determine which wire powers the blower motor for the heating speed. Clamp the #50 relay to the wire.
Good luck
HVAC Teacher
Feb 22, 2009 | Honeywell HE260A1010 Whole House...
My aprilaire 600 humidifier stays on when the blower shuts off
Make shure the 24 volts is hooked up to power that is only powered up when the blower is running. Some furnaces have a HUM terrminal on control (make shure the HUM is 24 volts some are 120 volts then you must use the transformer supplied with the AP 600). You can use a RP # 50 relay that senses current only when the furnace motor is running on the heating speed. Hope this helps
Oct 30, 2007 | Aprilaire 600 Humidifier
Humidifiers Logo
55 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
