Question about MGE Galaxy 3000 UPS System
Cooling fault the cooling liquid level is low
Overheating/no heat
My first guess is the cooling system is low on liquid coolant. That would cause both symptoms. The radiator can be low even if the overflow tank is full. The cooling system can have air pockets.
Jan 24, 2014 | 2001 Chevrolet Malibu
Coolant container boiling water
Hi, Anonymous and the usual suspects are:
1. Low coolant level.
2. Restricted radiator air flow.
3. Faulty thermostat.
4. Coolant pump or fans inoperative.
5. Vent hose crimped.
6. Air in the coolant.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Ducati Cooling System
http://www.ducatimonster.org/forums/tech/119822-new-me-liquid-cooled-748-question-coolant-boiling.html
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 12, 2014 | Ducati Motorcycles
Peugeot 206 the "STOP" indicator is blinking and the "not enough cooling liquid" indicator is on . I have verified liquid level ;it's OK ! Can someone ,please help ?
sounds like your control module is going out..its expensive to replace but the dealer will do it and they can reprogram the language also..
Dec 08, 2013 | 2005 Peugeot 405
Water not going in moter ,white smoke blowing from rhe tail pipe
Hi, If water is Not going your cooling system, check : - cooling liquid level ( it should in normal level) - air lock in your cooling system ( You can run your ca for minutes then top up liquid to disable this problem) - water pump ( it should working normal and has no leaks on its seal)
White smoke blowing, please check : - Valve seals for leaks - Oil seals for leaks - Compression on your combustion chamber
You will need a basic knowledge of car system to do above tasks.
Dec 04, 2010 | 1995 Chevrolet Lumina
How do I check the coolant level? This is my first liquid cooled bike.
When the bike is cold remove the radiator cap and look in the radiator. If you see coolant at the top it's good. If it looks low or you can't see any at all you need to add coolant.
Aug 05, 2010 | 2001 Triumph Legend TT
Stops cooling
These are not my words but perfectly explains why. Your Refrigerator, while operating within a low ambient temperature is unable to complete this process because the air surrounding the Condensor and Compressor is so cold is is inhibiting the compressor's ability to raise the pressure and temperature of the refrigerant to the necessary level to promote it's change of states from a vapor to a liquid. Sea Breeze
Feb 19, 2010 | Kenmore 64802 Top Freezer Refrigerator
No heat
First check if there is air in the cooling line or cooling liquid leak or level of cooling liquid too low
Check if the engine thermostat works fine.
Check the waterpump
Check if the heater radiator is not jammed.
Dan
Dec 08, 2009 | 2001 Chrysler Sebring
Heater fan works in warm weather not in cold
Not very good with American cars, but a lucky guess... the fan works only after the cooling liquid has reached some temperature. So smth is preventing the engine to reach this optimal temperature in cold days - low level of liquid, water pump malfunction, thermostat not opening (if you have such mechanical thermostat at all), or just a sensor fault.
Nov 06, 2009 | Cadillac DeVille Cars & Trucks
2002 bmw 330i,coolant light
Hi there
Not familiar with this car, but all of these systems work using a liquid level sensor, which is just a reed switch in a pivoting assembly. 9/10 times the unit just needs a clean. if your hand fits into the water bottle then clean with hand, if not the sensor can be removed with cir-clip pliers and then cleaned.
If none of these work (ie sensor is broke then just short the connections to get rid of the annoying warning light.)
Apr 11, 2009 | Gigabyte COOLANT LIQUID IN BOTTLE (BLUE)
Computers & Internet Logo
80 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
