Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
How do I set to scan BPR 40
I have 8 channels and want to hear all at once
  • Motorola Master
  • 1,654 Answers
This is only done through use of the programming software and cable. Your radio would need to be reprogrammed.
Posted on Jan 08, 2015
3 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: We purchasedn 3 bpr 40
Your new radio is likely not programmed the same as the others. A continual tone indicates a channel which is not programmed (doesn't have a frequency installed).
The other thing which can cause a tone, is a low or uncharged battery. You might try switching one of the known good batteries to the new radio to see if it will work. If you still have the same continual tone with a known good battery installed, you have a programming issue. If the battery swap solves the problem, then you need to investigate why your battery isn't charged up.
Either way, contact the dealer where you purchased the BPR40, they should provide programming free, or a warranty replacement battery for free. If you ordered online or by mail, and you just received the radio within the week, you should request they provide return shipping for you.
Best regards.
Posted on Sep 14, 2011
eradiostore
  • 1654 Answers
SOURCE: my bpr 40 all time have a green light on in a scan mode how i can block the scan mode
In order for your radio to scan, it would need one of the side buttons programmed to scan. Usually the top side button is programmed for monitor/sticky monitor, and the bottom button can be programmed to any of a number of features, one of them being scan. These buttons have both a long press selection and a short press selection. All this being said, it is possible the bottom button is programmed for scan. Try pressing it a short press and/or a long press and see if it shuts off your scan. To remove scan completely from your radio it would need ot be reprogrammed by an authorized Motorola dealer.
Best regards.
Posted on Jun 18, 2012
How do I stop it from running the auto scan
Once the unit finds the channels it will stop scanning.
Jan 13, 2015 | Apex Digital Apex LD4088 40 Class LCD HDTV...
What do the buttons on the bpr 40 do?
Both buttons have a short and a long press function. The button right below the PTT button is typically programmed to short press Monitor, long press Sticky Monitor. The bottom button comes from the factory on scan/nuisance channel delete. The buttons can be custom programmed when the dealer is programming the radio, so these are just a general guess based on the factory default setting. Other options include repeater talkaround, high/low power, volume set, and maybe tight loose squelch.
Best regards.
Oct 07, 2012 | Motorola Mag One BPR40 Two Way Radio
My bpr 40 all time have a green light on in a scan mode how i can block the scan mode
Best regards.
Jun 17, 2012 | Motorola Mag One BPR40 Two Way Radio
We purchasedn 3 bpr 40 and we justed ordered another, when we turn the bpr on to the channel of the 3 others that are in use, we just get a low continual tone, i tried a radio check on channel 1 with no...
Best regards.
Sep 14, 2011 | Motorola Mag One BPR40 Two Way Radio
How can I program my remote with scan
Hello
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Mar 24, 2011 | One For All URC-4021 Remote Control
Dear you! When i scan the channels i get them all over from ch 1 to 100 but i only have 40 channels.. my question is how to put them from 1 to 40 in a row? greetings
Hello, probably you did an automatic channel scan, to define a particular station within a particular channel. You need to scan channels manually. You click on the menu and go to the part of the scan channels. There are usually guidance by stages. Let me know if success, good luck!
Mar 03, 2011 | Televison & Video
I have a cobra 29 wx nw st withwilson little wil entenna. I am having issues with a no swr reading on channel one even if I turn my swr cal all the way up. My 40 cal reads on the swr at .5 no matter how...
first of all you are going about it wrong. To set your SWR you check it on channels 1 , 19 , and 40. If you reading is higher on 1 than on 40 you have to shorten your antenna . if its higher on 40 than on 1 then you have to lengthen it. before you do any adjustments to it ,loosen the set screws and let the antenna fall to the bottom then bring it up 1/4 " and tighten the screws. You should also use an external SWR meter not the one on the radio. Thats good for making checks every once and a while. With the meter you key the mic and have the needle go to set then put it on for and key the mic to obtain you reading . Anything under a two is good .
Dec 16, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Lost manual and cannot program scanner bc145xl
Try these instructions from Wiki.answers
Turn on unit.
Press MANUAL button.
Press MANUAL button again to select the channel you want to program. Note the channel in the display. If there is a hyphenated symbol in the upper left corner the channel has been locked out. Press the LOCKOUT button once to remove the symbol or press the LOCKOUT button to lock a channel out. To find out if there is a frequency programed into that channel, press the PREVIEW button. Each digit of the frequency that is stored in memory will be displayed in the LED display. To program a new frequency into that channel, simply press the digits of the frequency you want, including the decimal point. Press the "E" keypad key to enter it into memory. If you get a "E" displayed in the LED display, the frequency was entered wrong, is not a valid frequency or is out of range for the scanner. Last but least, the scanner is not working properly. If the channel is active, (communications going over it) set SQUELCH to higher number, until you hear the communications or just noise. To set the SQUELCH, select a channel that has only noise and turn it down to the point the noise disappears. You make have to readjust it to your liking. Once you have the channels programed you can select the SCAN button to listen to all the channels or select the MANUAL button to listen to just one channel. If there are channels that you don't want to hear during the scan mode, go to MANUAL and select the channel you don't want to hear and press LOCKOUT button. Then press SCAN again it will only scan channels you want to hear.
Hope this helps.
Sep 07, 2009 | Radio Communications
After the dreaded "Switch" I lost nearly all free HD channels. Prior to the "Switch" I got roughly 40 HD channels. Now I have 2 that work. Can anyone not named Dubya explain this?
I had a similar experience. The way I solved was to go back to the set-up and have the channels get re-scanned in. Even though I had gotten channel 22-1 originally the frequenciy must have slightly changed with the switch over because once the television rescanned it in it worked just fine.
Jun 29, 2009 | Westinghouse SK-26H590D Television
HT 1000 Set Scan mode
First, your radio must have one of the side buttons programmed to be scan on/off. You will need to experiment while one or more of the channels is active and press the side button to see if it puts you in scan mode.
If it is, most likely a short press turns on scan, and a long press would be nuisance channel delete. This feature will temporarily eliminate a channel out of your scan list for the time your have your radio turned on. Once you shut the unit off and turn it back on, it would return to the original setting.
The only way to have a button programmed for scan/nuisance channel delete, is to us Motorola propritary software available to dealers and certain businesses and governement agencies. If you are needing to turn on scan or change a scan list, you would need to have the radio reprogrammed. This typically will cost between $25 and $40 at more dealerships.
Oct 03, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
74 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
