Question about Coby Electronics Corporation Coby TFTV4025 40"" 1080p LCD TV - 16:9 - HDTV 1080p"
Coby lcd tft service menu - Coby Electronics Corporation Coby TFTV4025 40"" 1080p LCD TV - 16:9 - HDTV 1080p"
Closed caption is on and neither the remote nor the menu setup options for cc are working. I tried resetting to factory settings but no help. Advice?
Search Results
    [PDF]Instruction Manual
    static.bhphotovideo.com/lit_files/62319.pdf
    TFTV1525 ... If this equipment does cause harmful interference to radio or televisionreception, ... The LCD panel used in this television contains millions of thin film transistors that ... 15. or cable system during a lightning storm or when it is left unattended and ..... There are four options lised under the Closed Caption menu.
    COBY TFTV1525 INSTRUCTION MANUAL Pdf Download.
    www.manualslib.com > ... > Coby Manuals > Flat Panel TV > TFTV1525
    COBY Electronics TFT LCD Widescreen Television Instruction Manual. ... Cobyelectronics 15" widescreen lcd hdtv/monitor specification sheet (1 page) ... Operation is subject to the following two conditions: • This device may not cause .... Direction &OK While working with the system menu, press the direction buttons to ..
Jan 13, 2016 | Coby TFTV1525 15 in. LCD TV
How do I set up a 19" coby TfT lcd TV
Plug it in to the mains plug, plug in your inputs and then power it up. If it says no signal or something similar, try scanning through every single input on the menu until something comes onto the screen.
Jan 02, 2016 | Coby Televison & Video
How do I copy mp4 files to coby mp625
I use the USB cable to connect my laptop to the tablet. Then find the correct music folder and drag them over.
Feb 14, 2015 | COBY-PERSONAL & PORTABLE Coby Mp620 4 Gb...
How can I get the sound on my Coby TV to work properly.
Are you trying to get sound from over the air channels or is it coming from a cable box or some other media device or input?
Sep 17, 2014 | Coby 20" Flat Screen TFT LCD TV Monitor
How do you reset the parental code for the coby 19" TFT LED 1926 tv??
If you don't know the current password you can't. If you do then find the LOCK menu under TV function.
Tochangethepassword,inputtheoldpassword-->inputthe Password
newpassword-->verifyagain.
Pleaserememberthepasswordsincethe player'sreset
functionwouldnotrevertthepassword.
The default password is "0000"
If you want to set it back to the factory default you can email Coby support at techsupport@cobyusa.com.
the phone number is listed as: 800 727-3592
Jul 26, 2014 | Coby TF-TV1901 19 in. LCD Television
My coby TFT LCD widescreen tv is really zoomed in. How do you reset it?
go to menu then look for options for factory reset and when you do reset it all recorded items will be lost
Mar 23, 2012 | Coby Televison & Video
Does this tv have a digital tuner or will I need a converter box?
Coby tf-dvd1540 tv
No ATSC tuner in this TV. You will need a converter.
Product Features
  • 15-inch flat-panel TFT LCD TV with built-in side-loading DVD player
  • Standard 4:3 aspect ratio, native 1,024 x 768 resolution
  • Plays DVD, CD and recordable MP3 music CD-R/CD-RW
  • Built-in NTSC TV tuner lets you switch between DVD and terrestrial broadcast viewing
  • Stereo speakers with 3 watts per channel; includes full-function remote control; onscreen display simplifies setup and operation
Technical Details
  • Brand Name: Coby
  • Model: TFDVD-1540
  • Display Technology: TFT active matrix
  • Display Size: 15 inches
  • Image Aspect Ratio: 4:3
  • is_hdtv_compatible: N
  • speakers_included_description: 2 speakers
May 13, 2009 | Coby TF-DVD1540 15 in. TV/DVD Combo
COBY TV TF-TV1514 15'' TFT LCD TV
Go into your menu and navigate to find Closed Caption then turn it off. That should do it!!!! Read your manual also, it's possible you might have POP picture in which it displays multiple channels when you change it. That feature should also be in your manual.
Feb 18, 2009 | Coby TF-TV1514 15 in. LCD TV
No image on the screen
missmai and guest, the ballast supplying the CCFL tube may not be working. PCB board is in the lid (Cover) where the LCD screen is mounted. Careful opening it...the membrane (loom) attaching LCD and PCB when stretch too much could render a blank or white faulty display.
If the store where you bought this player do not give service support and parts, you might just have to toss it and forget about it. There is nowhere to get it because the same model you have now is carried by another two (2) brand names plus Coby. Sorry...its the fact...i will let you know if there is a fourth brand.
Good Luck.
Jan 27, 2007 | Coby TF-DVD7107 Portable DVD Player
Coby Electronics Corporation Coby TFTV4025 40"" 1080p LCD TV - 16:9 - HDTV 1080p" Logo
53 people viewed this question
Top Coby Electronics Corporation Televison & Video Experts
Electro Med Services...
Are you a Coby Electronics Corporation Televison and Video Expert? Answer questions, earn points and help others
