Question about Preh Ergoguys Wow-pen JOY Optical Mouse
Wowpen joy optical mouse buttons work won't scroll light not on
I have a logitech 3 button mouse, installed batterys, and pluged in usb. vista installed drivers and device maneger sayes its working. small green light on bottem is on but not the light on top or the red...
It may be a simple comunication problem between your mouse and the computer itself. However, you might want to install an updated driver from the logitech site and try to install the mouse again. after that, restart your computer and see what happens
make sure that nothing intefers with the reception of signal between your mouse and pc
if you need anything else, please let me know
Jan 11, 2010 | Logitech 3-Button Cordless Optical Scroll...
I have a dynex wireless optical mouse but my laptop will not recognise it
Have you installed the driver for the mouse? Did you install it before actually attaching the mouse's USB receiver? The driver should be installed first. You can download it here:
http://www.dynexproducts.com/productSearch.html?query=wireless+optical+mouse&mainSearchButton=
Scroll down to "Dynex Wireless Optical Mouse" and click on "English" next to "Driver:" in order to download it.
If you've already installed the driver and your computer still won't recognize the mouse, press the Connect button on the receiver, wait for the light to flash, and then press the Connect button on the mouse. The light should stop flashing and the mouse should be ready to use.
Nov 23, 2009 | Dynex Wireless Optical Mouse
Logitech v220 cordless mouse - worked fine for 6 mths - recently changed battery. worked fine. today, would not move cursor when on a white / light surface (although it has previously just fine). It...
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
Jun 17, 2009 | Logitech Cordless Mouse
IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Jun 02, 2009 | IBM Optical Travel Mouse 2224P0480
Wireless keyboard and optical mouse
Thanks! I fixed the problem by installing a USB mouse and using fn+f9. That unlocked the mouse so I could use the pointer leaving just the keyboard problem. I then tried reconnecting the wireless keyboard (by using the button on the receiver and under the keyboard) Hey Presto!!
Feb 02, 2009 | Logitech Wireless Access Duo Optical...
My PC cannot see my mouse. please help.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 07, 2009 | Chic Technology Office RF keyboard and RF...
My compaq optical ps/2 mouse doesnot scroll
get the screw's out and check the support of you're scroll, and if the scroll button didn't move from its position. if is new take it to warranty for repair's.
Dec 15, 2008 | Compaq PS/2 3 Button Optical Mouse...
Mouse prob.
Apr 13, 2008 | Micro Innovations Optical Scroll Mouse
OPTICAL MOUSE FACING GARBAGE CAN IF IT DOESN'T WORK RIGHT
it sounds like the mouse needs repair but if you could get same mouse or another optical mouse and see if it does the same make sure the area you are using it on is clean and the sensor has direct contact with mouse the model of optical keyboard and mouse i use is a4 tec model the model youv'e got does not last as long the mouse lots of problems with the micro swich buttons after a while they go. if same happens on new mouse then operating system needs re-installing. hope this goes well
Aug 11, 2007 | GE Jasco® 98446 (030878984454) Keyboard...
Preh Ergoguys Wow-pen JOY Optical Mouse  Logo
64 people viewed this question
Top Preh Computers & Internet Experts
David Payne
David Payne
Are you a Preh Computer and Internet Expert? Answer questions, earn points and help others
