Question about Riso Office Equipment & Supplies
Riso MZ1070E Keeps showing Master Loading Error!
3 Suggested Answers
  • 5 Answers
SOURCE: Error Code T14 on Riso GR3770
press reset .. is drum in home pos. ?
Posted on Feb 09, 2009
  • 55 Answers
SOURCE: riso 390U error code p19
Error P19-208
Error type P19: Thermal-pressure motor lock Error point 208: TPH pressure sensor does not go ON within 2 seconds after the thermal-pressure motor activates in the decompressing direction.
Hints: Check mentioned sensor. Check mentioned motor.
Posted on Apr 29, 2011
Riso cr1610 cannot cut master and it shows me e25 error code, what must i do to clear code
Replace light absorbing sheet (Black strip) on Drum screen sheet & also clean master position sensor , master loading sensor
Jun 19, 2014 | Riso Office Equipment & Supplies
Riso ez 200 the code A02 -509 continue to come up
It means that
"Master-loading sensor was OFF when the master was checked at a specified drum angle during the master-loading operation."
Sep 24, 2013 | Riso RZ220 Duplicator
Riso Rp3700 won't print from computer
We suffer the same issue. Have you find the solution?
May 02, 2013 | Office Equipment & Supplies
Error code A-01 -201
Which model of Risograph?
Error type A01: Master mis-feedError point 201: Master-positioning sensor does not go to ON even after the write pulse motor is activated durcing the paster-positioning, master cut, or master-loading operation.
Try this:1) Pull out mastermaking unit and rewind master roll, then re-set master in place.2) Check write pulse motor and its gear
Sep 18, 2012 | Riso Office Equipment & Supplies
Riso printer 390 u a01 -211 error message
I found a small sliver of a cut master inside the master feed assembly. Once it was removed, the machine worked fine. It was hard to locate,but if you remove 2 gold screws from the top of the master feeder you can gain access to the area.the screws are just below the coil springs for the master assy. lid.
May 03, 2012 | Riso Office Equipment & Supplies
Riso 390U error code p19 208 .... doesnt seem to be loading the master roll correctly, any suggestions?
Error P19-208
Jan 06, 2011 | Riso RZ220 Duplicator
I have the d17 error message. I did try to reset it but it still shows the error.
D17
236 - incorect master roll
237 - master roll undetected
238 - master roll communication error
239 - wrong master roll detect
241 - detected a mismatch in master roll information
you must stop the machine and remove the cable from the print drum PCB and check that there is no ink on the connector or the PCB.
If there is no ink try to enter in test mode and activate 0890 test.
If it dose not work call for tech from Riso.
Dec 01, 2010 | Riso RZ220 Duplicator
I have a problem error fo115 of riso rz-220
F01-115 means no master on drum at start of printing. Make sure you make a master before trying to print.
Jan 20, 2010 | Riso RZ220 Duplicator
Machine error Riso RZ 37 EP
Make sure you have taken all the master out the dispsal box, also make sure the senser is clean and there is no pieces of master stuck around the wheels inside the unit.
Nov 17, 2008 | Riso RZ220 Duplicator
Riso HC5500 System Error - Restart!
I need help with the error code. s04-307 in my riso hc 5000
Oct 22, 2008 | Office Equipment & Supplies
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Igor Studennikoff
Igor Studennikoff
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
