Question about Sagem Televison & Video
Sagem iad84 hd - Sagem Televison & Video
Sagem axium hd-l32t/1 Display Problem??!!
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 05, 2014 | Televison & Video
Service mode tv lcd sagem axium l32
To know more about this, check the site linked here. It has details about entering, adjusting and exiting service mode to many popular TVs. Pull up older posts.
Nov 27, 2013 | Sagem HD-L26-TP 26 in. HD-Ready LCD TV
Connecting blueray to sagem tv no sound
make sure the RED and The WHITE RCA plugs are hooked up to the TVon AUDIO IN
THE YELLOW is for VIDEO only
Sep 27, 2012 | Sagem HD-L26-TP 26 in. HD-Ready LCD TV
My sagem hd-l32 will not switch on unless i remove and reconect the mains plug.
You may have powerline glitches that stopped loading the firmware when you turn on the TV.
Nov 21, 2010 | Sagem HD-L26-TP 26 in. HD-Ready LCD TV
How do i activate my usb port on my sagem DTR94 HD Freesat
Can you please activate my usb port on my sagem DTR94 HD
May 12, 2010 | Televison & Video
Sagem Axium HD D45F TV Bulb needs replacing - any ideas of a local repair in the Stoke on Trent Area
http://www.ascolti.co.uk/blogs/robsblog/files/sagemaxiumbulbreplacement.html
or
http://robertleather.wordpress.com/2007/09/09/replacing-the-bulb-on-a-sagem-axium-hd45-hs-dlp-television/
Nov 16, 2009 | Televison & Video
Can't connect ps3 through hdmi or scat keeps saying no signel
check your local retail store for correct ps3 cable. this is only the cable type.
Oct 30, 2009 | Sagem HD-L26-TP 26 in. HD-Ready LCD TV
NEED COLOR DISC RED GREEN BLUE CAN YOY HELP
You can use a samsung colour wheel on the Sagems (Part no.BP96-00250AT) and remove it from the Samsung mounting. There is a black 'flag' on the motor body that tells the TV where the colour wheel is. This is different on the sagem but you can just peel it off and draw a mark with a permanent marker pen in the same position as the old unit. I've replaced mine on HD-D45 recently. Works perfectly
Mar 12, 2008 | Televison & Video
Tv codes
ok codes look up online what model tv u have so i can help u get yours
Feb 03, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Televison & Video Logo
90 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
electracon
ka4iup
ka4iup
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
