WFW9400SW01 WILL NOT DRAIN IT IS CLOGGED
    Problem Solver:
  • 8 Answers
Determine first if you hear any noise when it is trying to drain. If you do, the drain pump is getting power. Unplug the washer and remove the access panel below the door. There are screws across the bottom. With the panel removed, you will see the drain pump sitting on the floor on the right side. There is a cap on the front of the pump that can be unscrewed. Be careful as there could be a sunstantial amount of water that drains onto the floor. Have plenty of bath towels ready. Sometimes by tipping the washer back against the wall will cause the water to flow to the back of the tub minimizing the amount of water that will leak onto the floor. Now unscrew the cap and remove it. Look for any debris in the trap and around the impeller area of the pump. After cleaning it, reassemble everything but the front panel and try draining it again. If it works you are all set. If not, you may need to replace the pump as it could have burnt out
Posted on Feb 07, 2014
How is the snake cable attached to the drum
Robert if your talking about a snake for cleaning sewer pipes, there is normally a thumb ***** or bolt that you tighten.
How to use Drain Snake Plumbing Snake
How to use sewer snake to unplug clogged drain pipe
Clogged Drain
SNAKE CLOGGED SINK DRAIN PIPE
Mar 19, 2016 | Home
Where is the a/c condensation drain on a 2001 buik regal
a clogged ac drain will prevent the system from performing properly.
With a clogged drain \,ice tends to build causing the system to have ineffective cooling.The drain hose is located on the firewall,passenger side of vehicle
Jun 12, 2014 | 2000 Buick Regal
Self diagnostics
this sound like defective boards or the boards are not being hoked up correctly causing them to short/melfunction
Oct 22, 2013 | Whirlpool Washing Machines
WONT DRAIN PROPERLY
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 08, 2011 | Tecnik TKL9260 Front Load Washer
It will wash but when its time for the first draining out the water to spin it stops
Three things to inspect are:
  1. Clogged drain hose - cause water to back up to the pump and shut down
  2. Clogged drain tube - usually occurs when the drain hose is attached to a drain tube that empties out into the homes sewer system. Just like a clogged drain, water will back up all the way through the drain hose into the pump and shut down.
  3. Clogged or bad drain pump - Many times, debris left in pockets will work it's way into the drain pump. Over time, enough debris (paper, coins etc) could lodge itself into the pump. When the machine tries to empty or spin out, the pump becomes overwhelmed and shuts down. Sometimes, you may even see a puddle of water appear under the washer due to a clogged pump. This can also happen if the pump itself is worn out and no longer working up to specifications.
Best of luck with your repair.
Greg
Jul 20, 2011 | Kenmore Washing Machines
IT WON'T TAKE THE WATER OUT WHEN SPINNING?
The most common causes for water not draining are:
  1. Clogged drain tube
  2. Clogged drain hose
  3. Clogged drain pump
Removing the drain hose from the tube and inspecting it should give you an idea right away if the hose is clogged. The problem is most likely in the drain pump. Many times, items left in pockets will find their way into the pump and become lodged there.
May 12, 2011 | Washing Machines
I have a Roper washing machine and it will not drain the water?
Most common causes for a machine that won't drain are:
To diagnose, remove the drain hose from the drain tube and look for water in the tube. A clog will force water back into the machine. If this is clear, some debris could have worked it's way into the drain hose itself. Check this by removing the hose and inspect for a blockage. If both are fine, the problem is most likely in the drain pump. Many times, a piece of paper left in a pocket will work it's way into the drain pump and get lodged.
Mar 31, 2011 | Roper RAS8445KQ Top Load Washer
My portable GE dishwasher is clogged and wont drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 13, 2011 | GE Profile 24 in. Built-In Dishwasher...
Do you have instruction how to replace the whirpool duet door seal (boot)? modal number is wfw9400sw01. ser#csu2405380
Hi
Please see this video link to replace the door seal on your washer---
Please post for further assistance. Hope this helps...
Daniel
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
