Question about Kenneth Cole KC1639 Watch
Kc1639 battery replacement - Kenneth Cole KC1639 Watch
Finding and replacing the battery on my Zodiac sea dragon Z02270
  • Remove back
  • Locate battery. Note mounting arrangement for later battery replacement
  • Obtain replacement battery
  • Install battery
  • Check operation
  • Install back
  • Set time, etc.
Oct 19, 2016 | Zodiac Watches
Where can i buy kenneth cole kc1639 replacement band?
email to
aftersale@carmenco.com
you will have your strap
Aug 25, 2014 | Kenneth Cole Watches
The main button isnt working and now i cant use the touh screen or even adjust anything on the watch.
You have to visit your nearest watch repair shop. It is not possible to say what's wrong without close inspection.
May 18, 2011 | Kenneth Cole KC1639 Watch
I can't find a replacement battery, I have 2 3
Go to "http://relicbrand.com/pdf/Service_Form.pdf" and you will find an order form with prices for repairs and battery replacement.
It may seem expensive for a replacement battery but if you see the number of people who can't get their watches to go after battery replacement, you wouldn't hesitate to send them off.
Mar 17, 2010 | Relic 0504648FA
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Sekonda 3850 battery replacement
Hi, its Richard, after battery replacement before replacing watch back, there is a small hole in the movement near the edge if you look down it there is a metal plate at the bottom gently press this with a fine screwdriver, the display will then come on, it is a reset switch, regards Richard.
Aug 20, 2008 | Watches
Battery Replacement
I thought you are supposed to touch the neg side of the battery
Jun 01, 2008 | Casio DBC1501 Wrist Watch
Kenneth Cole KC1639 Watch Logo
52 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Gary Nitowski
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
