Good Morning Luca,
I understand your Frigidaire air conditioner, model# LRA067AT7, will not turn on. I also see that the wall outlet is good, so you are wondering if there is an automatic shut off if the filter has not been cleaned. Your air conditioner does not have an automatic shut off, if the filter has not been cleaned. Please start by cleaning the filter. You can do this easily with the following instructions:
The air filter should be checked at least once a month to see if cleaning is necessary. Trapped particles in the filter can build up and cause an accumulation of frost on the cooling coils.
1)Push the vent handle to the Vent Closed position (where applicable).
2)Open the front panel.
3)Grasp the filter by the center and pull up and out.
4)Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing
5)Or instead of washing, you may vacuum the filter clean.
Also, be sure your air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. Do not run your air conditioner without outside protective cover in place. This could result in mechanical damage within your air conditioner. Do not use an extension cord or an adapter plug.
The power supply cord contains a current device that senses damage to the power cord. To test
your power supply cord do the following:
1)Plug in your Air Conditioner.
2)The power supply cord will have TWO buttons on the plug head. Press the TEST button. You will notice a click as the RESET button pops out.
3)Press the RESET button. Again you will notice a click as the button engages.
4)The power supply cord is now supplying electricity to the unit. 4)
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
