Question about Easy Ampe A76 Fashion Version Tablet PC 7 Inch Android 4.0 8GB 2160P White
A76 usb driver - Easy Ampe A76 Fashion Version Tablet PC 7 Inch Android 4.0 8GB 2160P White
USB not recognizing USB keyboard
Update the driver! It should work.
Either from original manufacturer CD or install Driver Booster Software. It will automatically search and install the missing drivers.
Nov 13, 2015 | Tablets & eReaders
How do I connect the keyboard? it goes into the USB port but does not respond or type letters on screen.
normally when you attack a usb device the computer will automatically look for drivers for that machine. What you describe indicates a missing driver for what is attached to the usb lead. Go start ---click on devices click on the new device- double click on the device and then click on properties tab across to drivers and open click on install driver.
Oct 23, 2014 | Tablets & eReaders
I need some drivers for i craig tablet usb cord driver
If you plan is to do Android Programming, you just need to download adb, or a rooting kit like RootThat. If you plan to just transfer files to it, BEFORE plugging in the USB connector, go to SETTINGS, scroll down to USB, and turn off "HOST MODE".
Now plug in; the tablet & the computer should recognize each other.
Mar 14, 2014 | Craig CMP741d Tablet
How to root nextbook nx007hd
  1. Google and download Cydia Impactor (First result on Google) Extract it (desktop, wherever you prefer)
  2. Enable USB Debugging on your Tablet (Settings > Developer Options > USB debugging)
  3. Plug up your Tablet via USB, do not turn usb storage on, let windows try (and most likely fail) at installing drivers.
  4. Launch Impactor and select USB Driver Scan from the top menu (under USB). Let it do it's thing, reboot your PC after.
  5. Verify your tablet/android device is showing up on the start-bar as being plugged up/in (bottom right area)(this may not be needed depending on your setup)
  6. Relaunch Impactor (if rebooted ) and hit the Start Button
  7. Let it do it's thing.
  8. You should be rooted now go install SuperUser!
Dec 17, 2013 | HTC PG41200 EVO View 7in LCD 4G Tablet
Usb wireless mouse driver works
The INF is the driver information file. It's missing the driver file. If I remember correctly, windows 95 does not support USB. I thought USB was first supported with Windows 98.
Dec 14, 2013 | Sharper Image Tablets & eReaders
Sanei a76 tablet more pattern lock attempt. how to remove unlock my tab please help.
Here is the trick to unlock your Sanei 76 tablet pattern and Gmail :
1) Download Android SDK and install Drivers
2) Open ADB in Command Promt (cmd)
eg : my adb file is stored in this directory
c:\android sdk\sdk\platform-tools\
so to open adb inside this director i use the command
cd c:\android sdk\sdk\platform-tools\
7ac56502-9b5e-40ad-a42e-02deb0a64701.png 071aa9ed-d87b-43b7-aaf9-a53a9c9c27c3.png
3)type the command adb devices to check wether your device/tablet is connected to your PC
(if your device is connected you will get some thing like this : 727ab014-596a-4066-9df4-dbb8eb522e6a.png
4) Then type the command adb shell.
you will get some like shown below
5)if you got symbol rounded in the above screen shot download this file and run it.(if your device is not rooted)
http://downloads.ziddu.com/download/23715300/root.rar.html
6)The type su in adb shell
you will get super user privilages
7)Then type the command below
wipe data
8)the type command reboot
9)Now you are done you are successfully removed your Gmail and Pattern lock.
Oct 06, 2013 | Tablets & eReaders
I have a disgo 6000 running android 2.2, but there are no drivers in the box, and I cant connect it to my pc via either mini usb ports, anything you can suggest?
Android devices doesn't need any drivers since they will act as a USB storage device once you plug it in a PC. All android device comes with mini USB from your DISGO and a standard USB plug on the other end of the cable.
Sep 13, 2011 | Compaq tc4200 Tablet PC
I can't transfer picture from camera to my compter
which dell tablet? what operating system? are you using usb port? have you tried more than one usb port?
if so usb port drivers get corrupted in windows xp and xp media center alot. my suggestion is reinstall the chipset driver.
May 21, 2010 | Dell Tablets & eReaders
Gateway Pen Drive .... not recognized on Windows XP
@Enquiry: It's a USB 2.0 pen drive, which might not backwards support USB 1.1 without drivers. Many computers have USB 1.1 out one end of the case (back) and USB 2.0 out another (front).
Nov 22, 2008 | Gateway M275 Tablet PC
Easy Ampe A76 Fashion Version Tablet PC 7 Inch Android 4.0 8GB 2160P White Logo
Top Easy Tablets & eReaders Experts
Are you an Easy Tablet and eReader Expert? Answer questions, earn points and help others
