Dgnet ram warranty check
It doesnot work properly
2 Suggested Answers
  • 124 Answers
SOURCE: i have dgnet ram of 1gb but it is showing only
certain hardware devices reserve a block of memory for themselves - eg a pci express card reserves 256k - which could well be what you are seeing
Posted on Dec 04, 2009
Dropped xbox
kindly check if the memory or RAM is properly plug-in, turn off the xbox, remove the RAM, turn on the xbox and have the RAM back in its place once you see the start screen, if still not working, your RAM or memory is dead, you can buy a new one or have it repair if it still under warranty.
Jan 02, 2014 | Video Game Consoles & Games
My sigma 24-70mm f2.8 doesnot work on my d7000
Could you be a little more specific about "does not work"? Does the lens not fit? Can you not view through the lens when it's attached? Does it not autofocus? Does it not meter the exposure properly?
Feb 15, 2013 | Sigma 24-70mm f/2.8 EX DG IF HSM Lens for...
Power supply is ok but mother board doesnot power on. pressing power button pc doesnot on.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket
hope this helps
Aug 10, 2011 | Intel D845GLVA (KD845GLVALPAK10)...
My Dell Inspiron E1705 PC Notebook two light just blinks and doesnot boot
make sure the ram is properly installed just remove ram and check it give the beeps if it gives the beep that means board is ok clean the ram with pencil eraser and fix it again.
Have a nice day and do not forget to rate please...!
Dec 27, 2010 | Dell Inspiron E1705 Notebook
I have dgnet ram of 1gb but it is showing only 786MB why is it so? is ram available in this size also????
Dec 04, 2009 | Computers & Internet
IBM intellistation 6849 will not turn on subsequent to cleaning.
As you have opened the cabinet and cleaned, the ram might be loosened i suggest remove the ram blow out the dust in the ram slot and fix the ram properly in the ram slot and then to if the system doesnot power on check the front panel connections whether you have connected properly.
May 09, 2009 | IBM IntelliStation M Pro 6849 PC Desktop
I canot add another ram with the exist one
Try to use only the new one. if it works, then try combination of slots using two rams. And..1024MB, not KB ;) thanks
Apr 04, 2009 | Biostar Computers & Internet
Repeating sound after reinstalling ddr ram, and doesnot boot
The ram is either not installed correctly or it got corrupted by static electricity..the beeps are the computers BIOS message saying something is wrong with the RAM..in most cases its just not seated properly. Take the ram out and push it down firmly intil the snaps on each side of the ram sticks sit snug into the slots.
That should fix it..
Please rate this solution.
Mar 30, 2009 | Computers & Internet
My compaq optical ps/2 mouse doesnot scroll
get the screw's out and check the support of you're scroll, and if the scroll button didn't move from its position. if is new take it to warranty for repair's.
Dec 15, 2008 | Compaq PS/2 3 Button Optical Mouse...
Flash doesnot work how does one charge the flash on a Sony cybershot DSC-H3
Some of the popup flashes seem to be defective on this product. Mine is. I am returning mine under warranty.
May 03, 2008 | Sony Cybershot DSC-H3 Digital Camera
Computers & Internet Logo
David Payne
David Payne
