Corrupupt file on my advent 8212telling me to start windows set up by using origanal set up cd-rom which I dont have is their any other solution to this problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
You need the cd sorry
Posted on Apr 16, 2014
Tip
How do I backup my files and folders in XP?
Windows XP comes with a backup tool called NTBACKUP (NTBACKUP.MSI from Windows XP CD-ROM). In Windows XP Home Edition, this tool has to be installed manually from the CD-ROM, whereas in Windows XP Professional, this tool is installed by default.
Double-click the Ntbackup.msi file in the following location on the Windows XP Home Edition CD to start a wizard that installs NTBackup: X:\VALUEADD\MSFT\NTBACKUP
X:\ refers to the CD-ROM drive-letter
Note: Usually, OEMs such as Compaq, DELL won't ship the Windows XP CD nor they include the NTBACKUP utility by default. You can download a copy of NTBACKUP.MSI here
Backing up your files using NTBackup Utility:
Click Start, Run and type NTBACKUP
Select Backup tab at the top
In the left pane, scroll to the file/folder which you want to backup and put a checkmark on it.
At the bottom, mention the output filename (the backup output)
Once set, click Start Backup button in the right, and again click Start Backup in resulting dialog
NTBACKUP does not have the ability to write to CDs directly. You will need to save the backup to hard drive, then transfer or burn it to a CD-ROM. Also, while backing up several files, make sure you backup the files in separate sets of each max 650MB (so that it fits on a CD-ROM)
See also FREE Windows Backup Software add-on for NTBackup
Enhanced Windows Backup uses Windows' built in backup engine called Windows Backup (ntbackup.exe) which provides state-of-the-art core backup technology. Enhanced Windows Backup substantially extends the capabilities of NTBackup, providing an effective integrated backup solution.
on Mar 24, 2008 | HP Compaq Presario V2000 Notebook
Netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair this file by starting windows setup using...
Put the original setup CD-ROM into your CD-drive.
Restart the computer.
Tell it to "boot" from the disk in the CD-drive.
Choose "repair an existing Windows installation",
and let it fix the problem.
Remove the CD-ROM disk.
Restart your (repaired) computer.
Oct 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
Advent 7113 laptop very slow would like to return it to factory settings but dont know how help
After researching all the information online, I have put up the maximum possible detailed steps to help you out:
Your Advent computer uses the latest recovery system that doesn't require any CDs or DVDs to restore your PC to it's original factory condition.
1) Restart your Computer.
2) Press F10 repeatedly until the message "Starting System Recovery" is displayed.
3)
The recovery will load and display a menu of options:
(a)
Non-destructive recovery: this option will restore Windows, supplied applications, and drivers. This option will not destroy your documents or programs. These will be backed up along with the registry. These are restored at the end of the recovery process.
To access the recovery options below that erase all data from the computer, click the Advanced button.
(b)
System Recovery - No format: this will reinstall Windows®, supplied applications and drivers. It will move your files to a folder called "My old disk structure". Any applications (except those supplied) will need to be reinstalled.
(c)
System Recovery - Quick format: this option will erase your hard drive including your personal files. Windows, supplied applications and drivers will be reinstalled.
4)
Select the Non-destructive recovery option and press Next.
5)
You will be informed about System Restore in Windows, click Yes.
6)
The recovery will begin. Once this is complete click Restart.
Here are some additional information:
a) Press the ALT and D keys at the Windows style recovery menu options to access a command prompt. This will allow access to C: drive.
b) The command prompt will default to c:\minint\system32 where you can run a variety of tools including CHKDSK.EXE.
c)
For more information on these options, please read the Advent recovery trouble-shooter.
Advent recovery trouble-shooter:
If a user is experiencing recovery problems on an Advent PC, then try to follow these steps.
Note: These steps will remove all personal data and all applications installed after the PC was purchased. Where possible ensure that all data and personal files are backed up BEFORE trying these destructive diagnostic steps.
1)
Check the integrity of the recovery CD, or the update CD.
2)
It is possible to verify the integrity of the recovery CD, or the update CD from within the Recovery programme.
a)
Boot from the recovery C.
b)
At the ‘Press R to display system recovery options’, press ‘R’.
c)
Once in the System Recovery screen, press ALT + D to access the WinPE command prompt.
d)
Type in Xcopy D:\*.* /E /V C:\ and press Enter.
e)
D:\ is the CD ROM drive letter
C:\ is the HDD
/E copies everything
/V verifies the data with a CRC check
f) If there is an error with the CD, then you will get the message:
File creation error – Data error (cyclic redundancy check).
g) If there are no errors, then you will be left at a prompt again.
3)
If Windows® is accessible, then boot from the recovery CD.
4)
5)
Once in the System Recovery screen, press ALT + D to access the WinPE command prompt as below:
6)
Type COPYSI and hit Enter. This will unhide the user's smartimage (this may take a few minutes to complete).
7)
Return to Windows® & copy the contents of the C:\Update CD\ folder to CD (N.B. Do not copy the ‘Update CD’ folder itself). Ask the user to label this ‘UPDATE CD’.
8)
Start with the recovery CD ROM in the CD drive.
9)
At the ‘Press R to display system recovery options’, press CTRL + BACKSPACE to get the hidden menu as below:
10)
Choose option:4 (Clear the partition table of drive 0x80). Once you have selcted this, you will be returned to the Press 'R' screen.
11)
Choose option:5 (Erase the Master Boot Record of drive 0x80). Once you have selcted this, you will be returned to the Press 'R' screen.
12)
Choose option:7 (Create a primary partition on drive 0x80). Do not restart the machine during this process. Option 7 may sit for up to 10 minutes with a flashing cursor as it creates the partition. If the HDD LED is flashing, then you know that the process is proceeding.
13)
Once the HDD partition has been created you will be returned to the ‘Press R to display system recovery options’ screen. Press ‘R’.
14)
The recovery should go straight into a full destructive recovery, and will ask for the update CD which we have created.
Hope this Helps.
Please feel free to ask further questions.
Aug 15, 2010 | Advent Netbook
I have an advent 4211 netbook and am trying to load cds onto my itunes account using an external CD ROM but my computer (windows XP) wont recognise the device. Any tips?
hi
open itune click file and choose add file to library you seek in external drive and you selected the musics you want to add other than to import all the music you choose add folder.
Aug 02, 2010 | Computers & Internet
Laptop is saying file missing/corrupt
You can do it without using the cd, but you'll need another PC which is running properly with the same operating system. What you need to do is just copy the particular missing file and paste it in your hardrive windows system32 directory using command prompt, or you can connect your hardisk to another pc and copy/paste it.. Good luck..
May 12, 2010 | Acer Aspire 3610 Notebook
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
Windows setup using the original CD-ROM
you have to re install the copy of the file missing, if you do not re install this file. you wont be able to install windows. you need to re install this file to avoid this messages, you a have a windows installation disc have a copy install to your pc
Nov 25, 2009 | Toshiba Satellite Pro L300 Notebook
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
Apr 08, 2009 | Acer Aspire 5610-2328 Notebook
Hard drive compressed/bootmgr compressed
U DONT NEED A RECOVERY DISC TO FORMAT YOUR HDD ALL U NEED IS THE WINDOWS DISC U WILL USE TO LOAD WINDOWS THAN START YOUR COMPUTER UP BUT WITH YOUR CD ROM TO BOOT UP FIRST U WILL THAN HAVE TO VERIFY IF U WANT TO UPGRADE YOUR SYSTEM WILL CHECK IF WINDOWS WAS INSTALLED BEFORE AND ASK U DO U WANT TO FORMAT AND YOU WILL SPECIFY YES DELETING ANY OTHER PATITIONS
Feb 06, 2009 | Advent 4211c Notebook
Computers & Internet Logo
David Payne
David Payne
