Question about LG L1915S 19" LCD Monitor
Osd bloccato - LG L1915S 19" LCD Monitor
Technogym excite 500 bloccato Spia rossa allarme accesa nel circuito elettronico
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 02, 2016 | Exercise & Fitness
Technogym excite 500 bloccato Spia rossa a?larme accesa nel circuito elettronico
Nastro bloccato, messaggio di errore no ribbon, error
You probably have a riibon that is too apacque (dark)
Change the parameter to Ribbon noTrans in the printer parameters.
Or you may have the reverse situation. It is defined as No rans and you need to chage to Trans.
Apr 09, 2014 | Toshiba TEC B-472 Thermal Label Printer
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
Telefono bloccato non legge altre sim
esso può essere dovuto al blocco della rete, fornitore di servizi di contatto, altrimenti è possibile ottenere i codici di sblocco qui http://www.superunlockcodes.com/nokia-2680/rs12wp9/
è necessario specificare il paese e provider di rete
Dec 06, 2010 | Nokia 2680 Slide Cell Phone
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
plz do rate the solution if helped
Nov 22, 2010 | HP L1506 15" LCD Monitor
Show "OSD Locked".in that cause i-Menu is not working. what i do?
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD. Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum…
May 15, 2010 | Computers & Internet
OSD IS LOCKED AND WILL NOT UNLOCK! MODEL IS .....HANNSG HU196D
hey, to unlock osd press and hold the volume down "<" the volume up ">" and "menu" all at once then the osd will unlock
May 27, 2009 | Hanns.G Corporation HU196D (Black, Silver)...
What is the unlocking code for nokia 2626?
mi si e bloccato il cell con il codice di protezione par la tastiera ce qualchee codice di sbocco di reset?
Feb 16, 2009 | Nokia 2626 Mobile Phone
LG L1915S 19" LCD Monitor Logo
81 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
