Question about ASUS Computers & Internet
S.M.A.R.T. status Port 0: ST9320325AS
2 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: What's your problem?How to unfreeze the Port 0 Disk Status in the setup utility for a Aspire 5251-1513?
If the issue is that it does not see the hard disk on the 0 port ...and it gives you blue screen memory error ..it means it does not have the ahci driver installed ..you need to instal it as a 3rd party ...or ..go to bios settings (press f2 on start ) .select the hdd and under the settings for it ..disable the ahci for sata ..and select ide or ide compatible ..or sata as ide..depending on choices..
save settings with F10 and restart ..It will make the port functional ..
If you want to install with the advanced host controller interface ..than press f6 I think ...when it asks for 3rd party driver ..and try to load it from a usb device by browsing for it ..(in normal mode you need a floppy drive ) ..but it may work ..be sure the usb is enabled in bios..
if it does not work ..than make a boot-able usb memory ..with the operation system ..and use it and insert the driver disk in the dvd drive ..and will work ..This way .when it asks for 3rd party drivers..you will load the raid driver and the ahci driver ..and go on with the installing ..
Posted on Dec 06, 2011
Drive replacement and rebuil ding Raid 1 on a Dimension XPS Gen 2
Hmm,tricky, I think your best bet would be to save old drive and do a complete new programme install hopefully you have the discs, then once setup and running, connect old drive as a backup and transfer data you require, there may be a better way, this is what I would seriously consider.
Mar 07, 2014 | Dell Dimension Computers & Internet
Firmware update
Hmm, specialised disk data recovery person needed here www.data365.com.au
Dec 12, 2013 | Seagate Momentus 54006 ST9320325AS 320 GB...
Sata port 0 st9320325AS
You need to be more specific about whats going on.
Jun 29, 2012 | Lenovo G560 - 15.6 - 500GB - Black -...
Dec 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Portforwarding stopped working
OK, when you set up port forwarding, you have to tell the router to forward such and such a port (or range) to such and such a system.
Most people allocate their IP addresses on their home network, by using a DHCP server, and most home routers have one - so that they can make sure that all the systems are on the same network.
But the DHCP server does not try to insure that the same address is given to the same system every time. In fact, people don't worry about that, they use a scheme of telling nameservers which ip address they got this time.
Generally they TRY to assign the same system the same address every time, if it is available, but in some cases you will go to renew and get a different address.
The point is that port forwarding set up today might not work in an hour when the address expires.
Those are opaque messages but I am gonna take a guess. The server starts up, and starts a port. Then it says, "This is a slow (late) network" and it has waited for 38 seconds for a response. Finally it gives up.
He is not on satellite or trying to use a cellphone internet provider, is he? 38 seconds is not completely unusual for those guys. If he is using regular DSL or cable, you are probably right.
So, back to DHCP. There is no guarantee that you will get the same local address whenever you log in to your local network, unless you have configured your router to always associate your system with the same IP. When you first set up port forwarding, it works, and then, wow, it fails because you got a different IP address from the DHCP server in the modem.
Your local IP address will be 192.168.1.something, most likely. These addresses are in a special range that everyone uses for private addresses.
On a vista box, if you go to "Network Connections", then right click on the entry representing your hardware connection (might have one for wired, one for wireless, one for bluetooth) and then look for Status, and click that. then look for details, it will tell you your IPV4 address. Most windows systems will have some similar thing.
Now insure that your port forwarding in your router is pointing at that IP address. That should work.
Of course, if a parent set up port forwarding, they might have taken it out. They all think you play too many video games. :-)
No one installed a firewall on the system that is running this program, did they? And the program is listed as an exception in the windows firewall and was not updated since it was so listed? That is the next thing I'd look at if the IP address has not changed. From another system on the same lan, try telnetting to the target port and see if it connects at all. Just thoughts, but I think the most likely thing is that it failed because the address changed.
Jan 06, 2009 | Zyxel P-334WT Router (91003155003)
Security code for my nokia mobile 1650
IMEI number: * # 0 6 #Software version: * # 0 0 0 0 # lub * # 9 9 9 9 #
Simlock info: * # 9 2 7 0 2 6 8 9 #
Enhanced Full Rate: * 3 3 7 0 # [ # 3 3 7 0 # off]
Half Rate: * 4 7 2 0 #
Provider lock status: # p w + 1 2 3 4 5 6 7 8 9 0 + 1
Network lock status: # p w + 1 2 3 4 5 6 7 8 9 0 + 2
Provider lock status: # p w + 1 2 3 4 5 6 7 8 9 0 + 3
SimCard lock status: # p w + 1 2 3 4 5 6 7 8 9 0 + 4
1234567890 - MasterCode which is generated from IMEI
Oct 23, 2008 | Nokia 1600 Cellular Phone
I have nortel phone ip 2002 i want use for my own carrier i need to reset
1. Reset the phone by disconnecting and re-connecting power.
2. When the Nortel logo appears, press each of the four soft keys in sequence.
3. If no other configuration changes are required, press OK repeatedly until the “PC
Port? 1-ON 0-0FF
” option appears.
4. Press 1 to enable the PC Port or 0 to disable the PC Port.
5. Select OK to confirm the change.
6. Restart the IP Phone.
When the IP Phone is restarted, the firmware sets the PC Port status accordingly
Apr 20, 2008 | Nortel 1140E
I can not get two print servers to work on my network
I would suggest that you set a higher Ip address then 9-10 as it is possible that your router/switch is possibly using one of these for DHCP, I have one of these myself, I had to put mine a little uprange to prevent my router / switch from interfering with it.
Jul 26, 2007 | D-Link DP 301U (DP-301U) Print Server
Computers & Internet Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
