Question about Panasonic Workio DP-3030 Printer
Panasonic DP3030 Workio copier - won't feed document on top ADF
Documents will start to feed through the top ADF and then stop and show a "jam" error with a code of J72. How do I fix?
  • Panasonic Master
  • 783 Answers
Hi p Hinkle,
Go in to function mode (function + original size + 3 at the same time). Go to F7 for counters, find the fuser web counter and set it to 240,000 to reset it. Set any other counter alarms that go off to 0. The maintenance period is supposed to be 240k copies, but from the factory it comes set as 120k so you can change that if you want.
Still having Problem Then follow Us For Panasonic Printer Support
Posted on Feb 07, 2014
Testimonial: "Pressing function + original size + 3 at the same time does nothing except make the machine beep. Are you sure that's the proper way to get into Function Mode for a Panasonic DP-3030 Workio?"
MitchSchaft
  • 25 Answers
SOURCE: Req: Panasonic Workio DP-4530 service manual
I work on those machines all day long. I have any and all panasonic/konica minolta manuals, etc. Shoot me an email: (edited out).That error, you can simply reset the counter for the fuser web. Go in to function mode (function + original size + 3 at the same time). Go to F7 for counters, find the fuser web counter and set it to 240,000 to reset it. Set any other counter alarms that go off to 0. The maintenance period is supposed to be 240k copies, but from the factory it comes set as 120k so you can change that if you want.
Posted on Jan 24, 2008
  • 163 Answers
SOURCE: Panasonic Workio DP-150PA Copier
there is high voltage or corona probleb in your copier contact any technical person
Posted on Sep 14, 2007
MitchSchaft
  • 25 Answers
SOURCE: getting J33 code on panasonic workio dp-2500
That's a registration sensor error. 9 times out of 10, the registration sensor's spring fell out of place and that sensor is not popping back. When you open the right door, you'll see a sensor flag (plastic flag) sitting in the middle of a rubber roller.
Posted on Jan 25, 2008
SOURCE: My Panasonic DP-2330 .... Is Showing Error Code E04-02
How enter to service mode in panasonic DP2330 copier.
Posted on Mar 15, 2009
SOURCE: driver panasonic workio dp-3030 for windows 7. Please help me
iw drivers widows 7
Posted on Feb 25, 2010
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
I have a Panasonic Workio DP3030 showing error code J93 paper misfeed in ADF. I have followed the manual and there is no paper jammed but I can't get rid of the error message.
Generally a paper misfeed is not a paper jam. The rubber pickyp rollers probably need a clean but turning the printer off for 10 minutes and turning back on should eliminate the message.
Nov 03, 2013 | Panasonic Workio DP-3030 Printer
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
  1. Press <Stop/Reset>.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Screen display 290 jam remove original
290/291/292 Scanner Jam
1 Open the ADF top cover.
2 Remove the jammed paper by gently pulling it straight out.
3 Close the ADF top cover, and then load the documents back into the ADF.
Note: To prevent document jams, use the scanner glass rather than the ADF for thick,
thin, or a mixed set of documents.
4 Press Start to resume.
Nov 12, 2009 | Lexmark X342n All-In-One Laser Printer
Documents will not feed from the ADF
Is there a more permanent fix in the meantime? I'm just tired of fiddling each time that I use the ADF
Jul 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Panasonic Workio DP-3030 Printer Logo
118 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
