Question about Honda Air Tools & Compressors
Which oil in mk200
Oil must be changed what oil is suitable
I have a 2007 Lexus is 350 what is the best engine oil to use for this car
20w-40 grade ( thinner oils would not be suitable because of the wear factor of the components)
brands are immaterial
if you change oil on a regular basis (5,000 miles) mineral oil is the most economical
synthetic oils still need changing as the additives used to neutralize acids , hold water in suspension and prevent wear are all consumed and do not last for ever
Nov 14, 2017 | Lexus Cars & Trucks
How often do I change oil and plugs
if it is an EFI controlled engine then change the plug/s to platinum plugs and forget changing again
if a normal ignition system then around 50.000 miles or when there is indication of misfires
the oil should be the correct type for the engine ( some vehicle engine oils are not suitable for the bike engine )and then as per the service schedule or every 5000 miles
Oct 16, 2015 | Motorcycles
Need to know if it is ok to run syn oil with the 1.8 turbo
yes perfectly ok ,i would use a turbo diesel oil thats suitable for diesel and petrol engines and the cheapest one at that then change oil every 6000 miles with a oil filter every third oil change ,Do not spend money on expensive boy racer market oil use what the trade uses something like shell rotella and do not be fooled by fancy adverts like liquid engineering and all that stuff these fancy long life oils cause more engine failures than any cheap oil which is changed at regular intervals to prevent a build up of internal clagg inside the engine
Mar 04, 2011 | 2001 Volkswagen Beetle
What type of oil is best for my car when I go to change the oil?
Most common oil used today is sae 5W30 this usually is recommended by manufacturer.However when you take your car in for an oil change most garages apply to that unless other wise advised.I think 5W30 is most suitable.
Jan 01, 2011 | 1999 Volkswagen Beetle
Changing engine oil every 5000 KM or every 2500?
The service duration is affected by many things.. If you are driving in a dusty atmosphere or doing a lot of high RPM but low gear driving, change the oil every 2500kms. if you do mainly highway driving with low rpm but top gear, change the oil every 5000 kms. As a rule, I always replace the oil filter at every oil change even though toyota says you dont have to.
Apr 02, 2010 | 2003 Toyota RAV4
Changing oil in a troy bilt squall 5521
To change oil in a lawn mower you will need to acquire a fluid evacuation pump. Remove the dipstick and with the pump evacuate the old oil into a suitable container. Check your owners manual to determine how much oil to put in DO NOT overfill or the mower will not work. Make sure the old oil gets recycled.
Oct 27, 2009 | Troy Bilt 5.5hp Self Propelled Mower
How do i change the oil pan gasket
  1. Buy or make a suitable new gasket and enough oil to do an oil change, it is a good idea to change the filter too.
  2. Ensure you have the correct tools.
  3. Drain the oil and dispose of the oil responsibly. Undo the fastenings.
  4. Drop the oil pan/sump.
  5. Clean the adjoining surfaces and ensure they are not damaged. Lightly grease the gasket and fit to the oil pan/sump.
  6. Replace the fastenings to the correct torque.
  7. Replace the oil with the correct quantity.
Sep 27, 2009 | 1995 Dodge Intrepid
Hi there ... I have a 1998 Mercedes-Benz S500, and I want to change the spark plugs but I lost the operator guide. What's the suitable and the factory installed spark plugs should I use? The other...
BOSCH Super Platnum Plugs
Oil Change EVERY 3,000 MILES RELIGOUSLY
Most Owners Do NOT REALIZE that Oil CHANGE is the LIFE of the ENGINE it is VERY IMPORTANT
Sep 04, 2009 | 1998 Mercedes-Benz S-Class
Oil filter replacement
you'll need a hand-driven Oil Filter Wrench, suitable for most oil filters and new oil filter as well.
see the procedure
http://www.gigasize.com/get.php?d=rclnw3dbvof
Aug 04, 2009 | 1989 Peugeot 405
Air Tools & Compressors Logo
66 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
