Question about Motorola MC9500-K Handheld Mobile Computer
Operation timed out - Motorola MC9500-K Handheld Mobile Computer
  • Official Brand Answer
  • 1,623 Answers
Hello
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
Posted on Jan 31, 2015
Meaning
The most important program that runs on a computer. Every general-purpose computer must have an operating system to run other programs. Operating systems perform basic tasks, such as recognizing input from the keyboard, sending output to the display screen, keeping track of files and directories on the disk, and controlling peripheral devices such as disk drives and printers. For large systems, the operating system has even greater responsibilities and powers. It is like a traffic cop -- it makes sure that different programs and users running at the same time do not interfere with each other. The operating system is also responsible for security, ensuring that unauthorized users do not access the system.
Operating systems can be classified as follows:
  • multi-user : Allows two or more users to run programs at the same time. Some operating systems permit hundreds or even thousands of concurrent users.
  • multiprocessing : Supports running a program on more than one CPU.
  • multitasking : Allows more than one program to run concurrently.
  • multithreading : Allows different parts of a single program to run concurrently.
  • real time: Responds to input instantly. General-purpose operating systems, such as DOS and UNIX, are not real-time.
  • Operating systems provide a software platform on top of which other programs, called application programs, can run. The application programs must be written to run on top of a particular operating system. Your choice of operating system, therefore, determines to a great extent the applications you can run. For PCs, the most popular operating systems are DOS, OS/2, and Windows, but others are available, such as Linux.
    As a user, you normally interact with the operating system through a set of commands. For example, the DOS operating system contains commands such as COPY and RENAME for copying files and changing the names of files, respectively. The commands are accepted and executed by a part of the operating system called the command processor or command line interpreter. Graphical user interfaces allow you to enter commands by pointing and clicking at objects that appear on the screen.
    Apr 08, 2011 | Computers & Internet
    To run both operating system on the same computer
    Install both operating systems on seperate partitions. You will then be able to boot either one of the Operating systems at a time.
    If you want to run both the operating systems at the same time, use some virtualisatoin softwares like Microsoft Virtual PC or VMware workstation.
    Aug 08, 2010 | Computers & Internet
    Just installed a T101. Unit will not switch to on position works perfectly to off position. Can it be adjusted.
    Yes.
    Programming Instructions for the Intermatic T101 - 24 Hr. Dial Time Switch:
    1. TO SET ON AND OFF TIMES: Hold trippers agains edge of clock-dial, pointing to time (AM or PM) when ON and OFF operations are desired, tighten tripper screws firmly. For additional tripper pairs on CLOCK-DIAL order 156T1978A.
    2. TO SET TIME-OF-DAY: Pull CLOCK-DIAL outward. Turn in either direction and align the exact time-of-day on the CLOCK-DIAL (the time now, when switch is being put into operation) to the pointer. DO NOT MOVE POINTER.
    Operating Instructions:
    * To operate switch manually: move manual lever below clock-dial left or right as indicate by arrows (graphics) This will not efect next operation.
    * In case of power failure, reset clock-dial to proper time-of-day. See Programing Instructions (top lines).
    Good luck (reemmber rated this help).
    Oct 23, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
    I need to set time n date. I have no manual. How do I set time & date?
    power button on to left(camera). press the display button until the mode screen appears. press the up or down arrows to select menu then press the center of the operation button Press the operation button again and execute highlites press oper button again it goes to setting 1.Press arrow up to others 2 press oper button again. arrow down to settingand press oper button again THis gives you the month,press again for day and so on . arrow up or down to change year and time.
    Jun 26, 2009 | Sharp Viewcam VL-Z5U Mini DV Digital...
    After replacing the lamp in an XD480U projector, what are the 2 buttons needed when pushing the power button, to reset the Interval of lamp replacement time? The buttons to choose from are: Auto position...
    To reset the lamp operation time on a Mitsbishi XD480U:
    Plug in the power cord, turn on the lamp, and press the Left Arrow button, Right Arrow button, and POWER buttons on the control panel ALL AT THE SAME TIME, holding them all down for about three seconds.
    Notes:
    •Unless these three buttons are pressed at the same time, the lamp operation time isn't reset.
    • Make sure that the STATUS indicator is lit twice and the lamp operation time is reset successfully.
    • The projector doesn't turn on if the lamp cover isn't attached securely.
    • Be sure to reset the lamp operation time whenever you replace the lamp.
    • Do not reset the lamp operation time unless you replace the lamp.
    Dec 17, 2008 | Mitsubishi XD480U Multimedia Projector
    What 2 buttons other than the Power button
    Notes:
    Dear sir
    Because your computer can only operate one operating system at a time. You can add both partitions to your computer but your computer can work with one partition on your hard drive at a time.
    To run both at the same time you will need seperate computers. One for Windows and one for Linux, a network, and another computer with the desktop software so that you can access both systems.
    It's the same configuration that companies manage them on.
    Sep 01, 2008 | Microsoft Windows Server Standard 2003 for...
    Motorola MC9500-K Handheld Mobile Computer Logo
    94 people viewed this question
    Top Motorola Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
