Question about Panasonic KX-TGA600B Cordless Expansion Handset
Has 16 vertical lines and L1 L2 VE and battery symbol across the top.
I have an old air compressor that I have replaced the motor magstart and pressure switch on the motor is a 220 / 240 volt 5 horsepower motor it also has a low pressure oil cutoff switch does anybody have a...
Control: L1-SS-P-O-OL-OL-M-L2 In series, L1 is line 1, SS is start/stop switch, P is pressure switch, O is oil switch, OL is overload contact, M is magnetic coil (solenoid), L2 is line 2.
The voltage of M must be rated for the control voltage, across the line voltage (240V) or of a control transformer voltage, e.g. 240v/24v. A control voltage would be wired across the line, to L1 and L2.
Power: L1-T1-OL-M1, L2-T2-OL-M2. Line one to Line 1 on contactor, T1 on contactor jumpered to OL (overload heater) and out the overload heater terminal M1 to the motor terminal 1. Same for line 2, Line 2 to L2 on contactor, T2 on contactor jumpered to OL (overload heater) and out the heater overload terminal to M2 motor terminal.
The heater overload relays needs to be chosen by the motor full load current, a chart is given with a motor starter on selecting heater size. If no chart is available, go 115% of the motor FLA (full load amps) to select a heater size. E.G. 25 FLA motor at 115% is 28.75a. Sorry, no schematic available now, draw your own from this info. If using 3 phase, add the third line as duplicating one other line1 or line 2
Mar 10, 2015 | Air Tools & Compressors
Ps2 gta cheat codes san
Here is a list of cheat codes for Grand Theft Auto: San Andreas on the PlayStation 2.
$250,000, Full Health And Armor
Cheat code: R1, R2, L1 , X, Left , Down, Right, Up, Left, Down, Right, Up
Aggressive Drivers
Cheat code: Right, R2, Up, Up, R2, Circle, Square, R2, L1, Right, Down, L1
Aggressive Traffic
Cheat code: R2, Circle, R1, L2, Left R1, L1, R2, L2
All Cars Have Nitros
Cheat code: Left, Triangle, R1, L1, Up, Square, Triangle, Down, Circle, L2, L1, L1
All Pedestrians Are Elvis
Cheat code: L1, Circle, Triangle, L1, L1, Square, L2, Up, Down, Left
All Taxis Get Nitro + Jump Up When You Press L3
Cheat code: Up, X, Triangle, X, Triangle, X, Square, R2, Right
Junk Car Traffic
Cheat code: L2, Right, L1, Up, X, L1, L2, R2, R1, L1, L1, L1
All Traffic Lights Stay Green
Cheat code: Right, R1, Up, L2, L2, Left, R1, L1, R1, R1
All Vehicles Invisible Except Motorcycles
Cheat code: Triangle, L1, Triangle, R2, Square, L1, L1
Always Midnight (Time stays at 00:00)
Cheat code: Square, L1, R1, Right, X, Up, L1, Left, Left
Andrenaline Mode
Cheat code: X, X, Square, R1, L1, X, Down, Left, X
Blow Up Vehicle
Cheat code: L1, L2, L2, Up, Down, Down, Up, R1, R2, R2
Attracts Prostitutes With *** Toys
Cheat code: Square, Right, Square, Square, L2, X, Triangle, X, Triangle
Black Traffic
Cheat code: Circle, L2, Up, R1, Left, X, R1, L1, Left, Circle
Nearest Pedestrian Called to Get In Car
Cheat code: X, Square, Down, X, Square, Up, R1, R1
Cars Float Away When Hit
Cheat code: Square, R2, Down, Down, Left, Down, Left, Left, L2, X
Cars Fly
Cheat code: Square, Down, L2, Up, L1, Circle, Up, X, Left
Cars On Water
Cheat code: Right, R2, Circle, R1, L2, Square, R1, R2
Chaos Mode
Cheat code: L2, Right, L1, Triangle, Right, Right, R1, L1, Right, L1, L1, L1
Clowny Themed Area
Cheat code: Triangle, Triangle, L1, Square, Square, Circle, Square, Down, Circle
Commit Suicide
Cheat code: Right, L2, Down, R1, Left, Left, R1, L1, L2, L1
Destroy Cars
Cheat code: R2, L2, R1, L1, L2, R2, Square, Triangle, Circle, Triangle, L2, L1
Bikini Themed Area
Cheat code: Up, Up, Down, Down, Square, Circle, L1, R1, Triangle, Down.
Faster Clock
Cheat code: Circle, Circle, L1, Square, L1, Square, Square, Square, L1, Triangle, Circle, Triangle
Faster Gameplay
Cheat code: Triangle, Up, Right, Down, L2, L1, Square
Flying Boats
Cheat code: R2, Circle, Up, L1, Right, R1, Right, Up, Square, Triangle
Foggy Weather
Cheat code: R2, X, L1, L1, L2, L2, L2, X
Full Weapon Aiming While Driving
Cheat code: Up, Up, Square, L2, Right, X, R1, Down, R2, Circle
Gang Members Spawn Much Faster
Cheat code: Left, Right, Right, Right, Left, X, Down, Up, Square, Right
Six Star Wanted Level
Cheat code: Circle, Right, Circle, Right, Left, Square, X Down
Hitman In All Weapons
Cheat code: Down, Square, X, Left, R1, R2, Left, Down, Down, L1, L1, L1
Improve Suspension
Cheat code: Square, Square, R2, Left, Up, Square, R2, X, X, X
Increase Car Speed
Cheat code: Up, L1, R1, Up, Right, Up, X, L2, X, L1
Infinite Ammo
Cheat code: L1, R1, Square, R1, Left, R2, R1, Left, Square, Down, L1, L1
Infinite Health
Cheat code: Down, X, Right, Left, Right, R1, Right, Down, Up, Triangle
Infinite Lung Capacity
Cheat code: Down, Left, L1, Down, Down, R2, Down, L2, Down
Insane Handling
Cheat code: Triangle, R1, R1, Left, R1, L1, R2, L1
Spawn Jetpack
Cheat code: Left, Right, L1, L2, R1, R2, Up, Down, Left, Right
Jump 10x Higher
Cheat code: Up, Up, Triangle, Triangle, Up, Up, Left, Right, Square, R2, R2
High Jumps on Bike
Cheat code: Triangle, Square, Circle, Circle, Square, Circle, Circle, L1, L2, L2, R1, R2.
Lock in Wanted Level to Current Star Rating
Cheat code: Circle, Right, Circle, Right, Left, Square, Triangle, Up
Lower Wanted Level
Cheat code: R1, R1, Circle, R2, Up, Down, Up, Down, Up, Down
Max All Vehicle Stats (Driving, Flying Bike, Cycling)
Cheat code: Square, L2, X, R1, L2, L2, Left, R1, Right, L1, L1, L1
Maximum Fat
Cheat code: Triangle, Up ,Up, Left, Right, Square, Circle, Down
Maximum Muscle
Cheat code: Triangle,Up,Up,Left,Right,Square,Circle,Left
Maximum Respect
Cheat code: L1, R1, Triangle, Down, R2, X, L1, Up, L2, L2, L1, L1
Maximum *** Appeal
Cheat code: Circle, Triangle, Triangle, Up, Circle, R1, L2, Up, Triangle, L1, L1, L1
Morning Sky
Cheat code: R2, X, L1, L1, L2, L2, L2, Square
Never Become Hungry
Cheat code: Square, L2, R1, Triangle, Up, Square, L2, Up, X
Night Sky
Cheat code: R2, X, L1, L1, L2, L2, L2, Triangle
Only Gang Members and Gun Fights in Streets
Cheat code: L2, Up, R1, R1, Left, R1, R1, R2, Right, Down
No Traffic or Pedestrians
Cheat code: X, Down, Up, R2, Down, Triangle, L1, Triangle, Left
Noon Sky
Cheat code: R2, X, L1, L1, L2, L2, L2, Down
Sunset Sky
Cheat code: Left, Left, L2, R1, Right, Square, Square, L1, L2, X
Overcast Weather
Pedestrian Attack
Cheat code: Down, Up, Up, Up, X, R2, R1, L2, L2
Note: This code cannot be turned off.
Pedestrian Riot
Cheat code: Down, Left, Up, Left, X, R2, R1, L2, L1
Pedestrians Have Weapons
Cheat code: R2, R1, X, Triangle, X, Triangle, Up, Down
Peds Attack with Guns
Cheat code: X, L1, Up, Square, Down, X, L2, Triangle, Down, R1, L1, L1
Ninja Pedestrians
Cheat code: X, X, Down, R2, L2, Circle, R1, Circle, Square
Pink Traffic
Cheat code: Circle, L1, Down, L2, Left, X, R1, L1, Right, Circle
Prostitutes Pay You
Cheat code: Right, L2, L2, Down, L2, Up, Up, L2, R2
Raise Wanted Level
Cheat code: R1, R1, Circle, R2, Right, Left, Right, Left, Right, Left
Recruit Anyone (with 9mm)
Cheat code: Down, Square, Up, R2, R2, Up, Right, Right, Up
Recruits Anyone (with Rockets)
Cheat code: R2, R2, R2, X, L2, L1, R2, L1, Down, X
Sand Storm Weather
Cheat code: Up, Down, L1, L1, L2, L2, L1, L2, R1, R2
Skinny
Cheat code: Triangle, Up ,Up, Left, Right, Square, Circle, Right
Slower Gameplay
Cheat code: Triangle, Up, Right, Down, Square, R2, R1
Spawn Monster
Cheat code: Right, Up, R1, R1, R1, Down, Triangle, Triangle, X, Circle, L1, L1
Spawn Parachute
Cheat code: Left, Right, L1, L2, R1, R2, R2, Up, Down, Right, L1
Spawn Rhino
Cheat code: Circle, Circle, L1, Circle, Circle, Circle, L1, L2, R1, Triangle, Circle, Triangle
Spawn Stretch Limo
Cheat code: R2, Up, L2, Left, Left, R1, L1, Circle, Right
Spawn Bloodring Banger
Cheat code: Down, R1, Circle, L2, L2, X, R1, L1, Left, Left
Spawn Caddy
Cheat code: Circle, L1, Up, R1, L2, X, R1, L1, Circle, X
Spawn Dozer
Cheat code: R2, L1, L1, Right, Right, Up, Up, X, L1, Left
Spawn Faster Cars
Spawn Hotring Racer #1
Cheat code: R1, Circle, R2, Right, L1, L2, X (2), Square, R1
Spawn Hotring Racer #2
Cheat code: R2, L1, Circle, Right, L1, R1, Right, Up, Circle, R2
Spawn Hunter
Cheat code: Circle, X, L1, Circle, Circle, L1, Circle, R1, R2, L2, L1, L1
Spawn Rancher
Cheat code: Up, Right, Right, L1, Right, Up, Square, L2
Spawn Tanker
Cheat code: R1, Up, Left, Right, R2, Up, Right, Square, Right, L2, L1, L1
Spawn Hydra
Cheat code: Triangle, Triangle, Square, Circle, X, L1, L1, Down, Up
Spawns Quad Bike
Cheat code: Left, Left, Down, Down, Up, Up, Square, Circle, Triangle, R1, R2
Spawn Vortex
Cheat code: Triangle, Triangle, Square, Circle, X, L1, L2, Down, Down
Stormy Weather
Cheat code: R2, X, L1, L1, L2, L2, L2, Circle
Spawn Stunt Plane
Cheat code: Circle, Up, L1, L2, Down, R1, L1, L1, Left, Left, X, Triangle.
Super Punch
Cheat code: Up, Left, X, Triangle, R1, Circle, Circle, Circle, L2
Traffic Is Country Vehicles
Cheat code: Triangle, Left, Square, R2, Up, L2, Down, L1, X, L1, L1, L1
All Country Vehicles
Cheat code: L1 L1 R1 R1 L2 L1 R2 Down Left Up
Unlock Romero
Cheat code: Down, R2, Down, R1, L2, Left, R1, L1, Left, Right
Unlock Trashmaster
Cheat code: Circle, R1, Circle, R1, Left, Left, R1, L1, Circle, Right
Weapons Pack 1
Cheat code: R1, R2, L1, R2, Left, Down, Right, Up, Left, Down, Right, Up
Weapons Pack 2
Cheat code: R1, R2, L1, R2, Left, Down, Right, Up, Left, Down, Down, Left
Weapons Pack 3
Cheat code: R1, R2, L1, R2, Left, Down, Right, Up, Left , Down, Down, Down
Cloudy Weather
Cheat code: L2, Down, Down, Left, Square, Left, R2, Square, X, R1, L1, L1
May 21, 2013 | Ubi Soft Entertainment F1 Racing...
What mean L1 and L2 for the connexion of the heater
L1 Means Line Voltage L2 means Line Voltage
If you have 220 as your supply voltage than one side would go to L1 and the other to L2.
Hope this helps if you still have problems post another post along with more information as to what voltage you have.
Jan 02, 2011 | Dimplex EF621C Electric Wall Mounted Panel...
Please give me cheat codes for the game GTA : Vice City
Weapon/Health Vice City cheats
aspirine - Max health
canttakeitanymore - Suicide
thugstools - Thug Weapons
professionaltools - Professional weapons
nuttertools - Heavy weapons
preciousprotection - Full armor
youwon'ttakemealive - Increase wanted level
leavemealone - Decrease wanted level
May 28, 2010 | Rockstar Games Grand Theft Auto
Wiring new motor
The L1 and L2 are the load terminals. Connect the black wires to the L1 and L2 and the green one to the green colored screw.
May 14, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
How do i clear the L1 L2 so on cells?
I do not understantd what you mean by the so on cells words.
1. To clear all lists
Press [2nd][CATALOG] to access the list of commands. Scroll down till the fat right arrow point to ClrAllLists. Press [ENTER][ENTER] to execute the command. Screen displays Done.
2. To clear the list L1 completely
Press [STAT][4:ClrList]; command echoe on main screen as ClrList . You must specify what list you want to clear. To clear L1, you insert at the place of the cursor L1 and press [ENTER]. But to insert L1, you press [2nd][1] (L1) and press [ENTER].
3. Clear L1 and L2 completely you do as in point 2.
Press [STAT][4:ClrList] [2nd][1] [,] [2nd] 2 (L2). On screen command appears as ClrList L1, L2. Press [ENTER] to execute it. Screen displays Done
4. To clear a number in a cell.
Press [STAT][1:Edit]. The list editor opens. Move cursor to the top of the list, say L1. and highlight the heading
The whole list appears on the commande/edit line.
Press [ENTER].
Cursor moves to the entry line where all elements on the list appear between { }.
Use the cursor to the value you want to remove and press [DEL]. Do not leave unneeded commas.
Hope it helps.
Oct 21, 2009 | Texas Instruments TI-83 Plus Calculator
I have bought Crabtree dimmer switch but it came without wiring instructions. There are 3 terminals, one marked L1, one L2 and the other with a wavy line with an arrow across it. Which one does the 'line'...
This is a 2way dimmer the wavy line is the common so your live supply will connect to this terminal .For 2way switching your strappers go in L1 L2 if you only require 1 way switching use either for your feed out to the fitting and disregard the spare terminal.
HTH
Oct 21, 2009 | Kitchen Appliances - Others
L1, 2 and L3 versus COMM
what kind of light switch are you replacing??? assuming house light switch???
one way or two way switch??
I have not come across the type of switch before.
L1, L2 is just label as line 1 and line 2, comm is usually refer to common (ground wire-white).
is the red wire-hot???
Oct 23, 2008 | Electrical Supplies
Defaults to Line 2
Do you have a second phone? Be sure that phone is not defaulting to line 1. With 2 lines and 2 phones, each phone defaults to one of the lines.
Unplug the phones. Plug in the phone you want to default to line 1 using the L1+L2 jack. Now plug in the second phone.
May 22, 2008 | RCA 25205RE1 Phone
Panasonic KX-TGA600B Cordless Expansion Handset Logo
42 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
