Question about Garden
Massey axle 1808206m3 brake disc specs - Garden
What is the torque specs for brake calipers on a ford explorer sport front calipers
  1. Torque Specs For F250 Caliper Bolts - Diesel Forum - TheDieselStop.com
    www.thedieselstop.com > ... > 1999-2007 General Questions Jan 13, 2009 - 3 posts - ‎1 author
    Does any one know what the caliper bolts torque specs are? ... Disc brake caliper pin bolts - Excursion, F-250/F-350 with Ford and Dana axle ... Torque specs for front brakes
    Mar 12, 2009
    05 F250 brake torque specs please
    Aug 22, 2007
    Brake caliper torque specs
    Jul 14, 2007
    Front brake Caliper Bolt Torque
    Apr 25, 2005
    More results from www.thedieselstop.com
Jul 11, 2015 | 1998 Ford Explorer
Lookup serial numbers
Hi, here's a link to these specs. It looks like however that you did also find this info. Perhaps you'd comment if this was helpful. Thanks and good luck!
Just in case:
TractorData.com Massey Ferguson 362 tractor information
http://www.tractordata.com/farm-tractors/000/7/8/784-massey-ferguson-362.html
Aug 30, 2014 | Garden
NNeed torque specs for 2010 harley ultara classic, front axle nut, front brake calipers, axle nut holder
Front Axle = 60 to 65 foot pounds
Front caliper banjo bolts = 17 to 19 foot pounds
Front Brake disk screws = 16 to 29 foot pounds
Front caliper mounting bolts = 28 to 38 foot pounds
Front axle holder nuts = 132 to 180 inch pounds
Aug 23, 2014 | 2010 Harley Davidson FLHTCUTG Tri Glide...
What are the torque specs for 2010 harley ultra classic, front axle nut, front brake calipers
Front caliper -
Brake Pad Pin = 75-102 INCH lbs.
Caliper to Fork Bolts = 28-38 FOOT lbs.
2004 ultra classic torque spec's on front and rear axle nuts and front and rear rotors with front dual rotors
Tighten the rear axle nut to 60-65 ft.-lb. (81-88 N•m).
Front axle nut
FXST, FLSTC, FLSTF,
FXSTB and FXSTD 50-55ft/lbs - 68-75 NM
FLSTS and FXSTS 60-65ft/lbs- 81-88 NM
Brake disc bolts
Front wheel 16-24 ft/lbs- 22-32nm
Rear wheel 30-45 ft/lbs- 41-61nm
Aug 11, 2014 | 2004 Harley Davidson FLHTCUI Electra Glide...
Change front tire
Remove brake caliper mounting screws from where they mount on the front forks. Slide caliper off brake disc and secure caliper
out of the way. Do not operate the front brake lever with the front wheel
removed or the caliper pistons may be forced out. Reseating the pistons requires disassembly of the caliper. On models with dual disc brakes, remove both calipers.
Remove axle nut lockwasher and flat washer from axle on left side of vehicle.
On right side of vehicle, loosen nut on pinch screw. Pull axle out of hub while supporting wheel.
Remove spacer and front wheel assembly.
Keep track of where each of the different size spacer went so you can put the back in the same order when reassembling.
For reinstall, you should get a manual as you will need to get torc specs. and other spacing and assemble instructions.
Sep 04, 2013 | Harley Davidson XL 1200 C Sportster Custom...
1960 massey ferguson hydraulic filter location
Hello, I would say just go to a NAPA parts store and ask for a filter. If they have one they would show a part number for it. Usually the older tractors for Ford and Ferguson did not use filters or at best had metal filters that you cleaned in solvent and reused. There are Repair Manuals in soft-cover which are available at places like Tractor Supply or online.
The old tractor makers considered the transmission and differential sealed systems. This means like your new car today does not have a filter in the differential. The old tractors had manual transmissions and the filters are common in automatics.
Be careful not to overfill the trans because on old tractors the gear lube will go out the axle tubes and into the brakes. If operated on a slope, it is possible to tilt the axle tube and have the excess lube flow into the low side axle tube, ruining the brakes.
Some of the parts for the Ferguson will interchange with the N Series Ford. Ferguson had some Industry innovations that later were stolen by other makers.
Oct 03, 2011 | RTO Massey-Ferguson Tractor TE20, TO20,...
I need to know how to replace the hub bearings on my grand am
The front wheel bearings on this car come as a sealed unit inside the wheel hub.
things you will need to replace them
-torque specs for your cars axle nut, hub retaining bolts, brake caliper mounting bracket bolts, and wheel lug nuts.
-a socket set
-a breaker bar
-a axle nut socket
-a c-clamp
-a jack
-two jack stands
To complete the job follow these steps
1) remove the hub cap/wheel center cap
2) remove the axle nut cap (use the tip of a small flat screwdriver to pry up one edge, pull it off)
3) remove the cotter pin from the end of the axle shaft
4) using a breaker bar style wrench (non-ratcheting socket wrench) with a helper pipe slid over the end to increase leverage use an axle nut socket to loosen the axle nut without removing it.(these are torqued pretty tight and can be stubborn, don't be afraid to use a generous amount of penetrating fluid).
5) once the nut is loose, loosen the wheel lug nuts
tip: doing steps 4 and 5 is made easier with the weight of the car on the ground to keep the wheel from spinning while you loosen the nuts.
6) jack up one corner of the car, and support it with a jack stand. lower the jack to rest the weight of the car on the jack stand, then lift the jack back up to contact the cars jacking point, without taking the weight off the jack stand. leave the jack in place as added support.
7) remove the wheel
8) remove the brake caliper from the hub (if you remove the caliper mounting bracket with the caliper still attached as a unit it's only two bolts to remove it together) hang it from the strut spring with some heavy wire or a metal clothes hanger being sure not to pinch or kink the brake line in the process.
9) remove the brake disc/rotor
10) locate the wheel speed sensor (a small electronic box located on the back side of the wheel hub) a small bolt secures it to the hub, remove the bolt and move the sensor to the side out of your way.
11) locate and remove the three hub retaining bolts (reachable from the rear of the hub)
12) remove the axle nut and use a jack stand to support the axle shaft
13) use a "soft blow" hammer (if possible) to tap on the back side at the outer edges of the hub working your way around in a circle so as to drive the hub out of its housing/steering knuckle evenly. As the hub comes out of the housing/steering knuckle the axle will want to slide with it, in turn pulling the axle out of the transmission. try not to let this happen. if necessary tap lightly on the end of the axle shaft to free it from the hub, once the hub comes loose remove it. this is where supporting the axle with a jack stand comes in handy. try not to allow the axle to scratch the hub mating surface.
14)clean the cavity that the hub came out of, remove the axle shaft support jack stand as you slide the new hub into place lining up the axle and the holes where the hub retaining bolts go (if you just shove it in, it can be impossible to turn it to line up the bolt holes) be sure that it is seated tightly against the steering knuckle, and that the axle is all the way into place. put the axle nut on but do not tighten it yet
14) replace the hub retaining bolts and torque to specs
15) replace the wheel speed sensor
16) replace the rotor/brake disc
17) replace the brake caliper and mounting bracket unit, this may require you to spread the brake pad pistons (this is easiest with a c-clamp slowly squeezing the piston open so as to not create too much pressure in the brake line or master cylinder). if a c-clamp is not available a large pair of channel lock pliers can do the job. once its in place, torque the caliper bracket mounting bolt to specs
18) raise the car off the jack stand, tighten the axle nut to snug and replace the wheel, remove the jack stand and lower the car to the ground.
19) torque the axle nut to specs
20) replace the axle shaft cotter pin and axle nut cap
21) torque the wheel lug nuts to specs
this should complete one side so switch your tools and equipment to the other side of the car and repeat the process. i hope this helps
Jan 05, 2011 | 1996 Pontiac Grand Am
Front Hub Bearing Torque specs to complete replacement
THE LUG NUT TORQUE SPEC - 140FT/LBS\
CALIPER MOUNT - 80FT/LBS
CALIPER BRACKET 129FT/LBS
AXLE NUT 177FT/LBS
Apr 24, 2009 | 2003 Chevrolet Silverado 1500
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
