Question about KitchenAid 32 in. KECC508 Electric Cooktop
Cooktop electric. indicator lights going off and on in circle fashion. will reset to normal by flipping the breaker, but eventually will go in circular motion again
Intermittent issue. seems like it is fine, and then control lights flash off and on and go around in circular fashion.
4 Suggested Answers
  • 12 Answers
SOURCE: Kitchen Aid kecc508gbl3 Cooktop - Flashing Controls.
Held all off/on button for 5 seconds cleared the problem,
Posted on Dec 25, 2008
SOURCE: HOT SURFACE LIGHTS
Hold the button down 5-6 seconds and it will go off...then to cut on...press down again for 5-6 seconds and it will come back on.
Posted on Jan 15, 2009
techline
  • 39 Answers
SOURCE: The circuit breaker for out kitchenaid glass
Water probably did get into the switch(es). The best bet for a fast fix is to pull the knobs off and use an air can (like for blowing dust out electronics) to blow down into the holes. This will dry out any water in there and should allow you to use it again. To be extra sure, blow out the switches and leave the knobs off over night. In the morning the knobs can be replaced and the cook top should be good to use. Hope this helps!
Posted on Dec 11, 2009
Testimonial: "Thanks!"
Electrolux hybrid cooktop showing flashing 8
I appreciate your post, friend!
Based off what you are describing your Electrolux cooktop is flashing error code "8". Normally, an "8" error code stands for key sensor for cook place 3. This means you could have a problem with your center board or left board. I would recommend performing a reset on your cooktop which can be done by flipping off the household circuit breaker for ten minutes. If the issue remains I would consult with a professional technician for diagnosis and repair on the cooktop. I hope this helps to some degree. -Matt
Oct 20, 2014 | Cooktops
The indicator light for the stovetop remains on despite all the knobs for each element in the off position. One of the elements is still getting power and heating slightly despite all controls in the
Hello friend, thanks for your post!
I see that the indicator for your cooktop continues to remain on for your Frigidaire range. It sounds like it could be a potential issue with your switches or control panel. I would recommend a reset on your range which you can do by flipping the household circuit breaker off for ten minutes. I hope this is helpful. -Matt
Oct 11, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
Frigidaire electric cooktop locked
I noticed your question is labeled under Frigidaire cooktop model, FEC30S7E. I have located the Use and Care Guide for your cooktop and I was unable to locate a lock feature. You could perform a reset on your appliance and you can do that by unplugging the power cord or flipping the circuit breaker off for ten minutes.
If that does not correct your issue could you please provide me with your model number? Usually you can locate the serial tag (which lists your model number) inside your burner box or on the outside of the appliance base. With that information I can look further into your model. I look forward to assisting you. -Matt
Oct 09, 2014 | Frigidaire 31 in. FEC30S7E Electric...
Caps come on my cooktop but indicator light wont come on
Hi George - Thank you for your post! Let's try resetting the cook-top by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the EOC (electronic oven control) or a potential wiring failure. You may wish to reach out to an appliance expert who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Jul 13, 2013 | Frigidaire 31 in. FEC30S7E Electric...
Electrolux E 95 code
Hello Robert - Typically, error code E95 indicates a power voltage miscommunication to the main components of the unit. You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then I would recommend contacting a professional to proceed further.
Apr 25, 2013 | Electrolux 36" Electric Hybrid Induction...
Popping noise and red light
it could be a switch, element or a short somewhere else
Apr 29, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
The cooktop does not come on
It sounds like the circuit breaker is kicked or the fuse is blown.
look in your electrical panel for the breaker and in the fuse box to see if the fuse is blown.
Feb 12, 2009 | GE 30 in. JP340 Electric Cooktop
My ge ceramic cooktop hot indicator light won't go out
I know that some people have mentioned that it looks like it's on, even when it's off. Depending on how the light hits it, it can look like it's glowing a bit. This would be normal.
Dec 27, 2008 | GE 30 in. JP340 Electric Cooktop
Error code
Same thing happened to me. Reset your stove top by flipping your fuse off. The stove top will reset and the error code will go away.
Jan 21, 2008 | GE 30 in.JP950 Electric Cooktop
KitchenAid 32 in. KECC508 Electric Cooktop Logo
69 people viewed this question
Top KitchenAid Cooktops Experts
vince
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
