Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
Blue parrot answer calls - VXI Corporation Blueparrott B250-XT Bluetooth Headset
Why is the parrot known as a Norwegian Blue?
Because Norway is unusual location to find a parrot! Spike Milligan did a version of the parrot sketch where he called it an Artic Grey.
Sep 04, 2016 | Monty Python's Flying Circus (1969)
My parrot handsfree kit keeps muting itself when i answer a call do you have a solution?
This will need a software update, you will need a laptop with Bluetooth and download the update manager from Parrot.com. otherwise you can also find all parrot engineers on the web site.
Oct 17, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
My hands free parrot in my car went out in the middle of a call and has not worked since. Don't have a clue where to start top find out whats wrong
Is there anything on the display or is it a dead Parrot?. Does it make any noises?. If there is not life at all them you will need to find the main blue box behind the dashboard and check the fuses, normally behind the radio. otherwise go to parrot web site and contact one of their certified installers.
Jan 10, 2011 | Parrot CAR PAICK3300 GPS Receiver
Blue parrot b250xt when making a call cant hear it ring on parrot . When reciving a call you have to divert to hands free.
Seems like you have an issue that is very common. I had the same issue and phoned tech support (1 800 742 8588). The solution is to reset the headset. It is not printed in the manual 1 switch phone on and pair with headset. 2 when paired (blue light flashing) put the charger on the headset for exactly 10 seconds. 3 remove the charger. 4 the lights should be starting to alternating between red and blue. this means it is resetting. 5 as soon as the light quits to alternate, the headset is reset, and the problem should be solved.
This also fixes the Windows 6.1 audio problem.
Jun 20, 2010 | Parrot CAR PAICK3300 GPS Receiver
Receiving calls on Parrot minikit
The crossing test with an other phone will give you the explanation.
Cause the software version of one or the other product can be the reason why.
Mar 02, 2010 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Wont audio to headset
The problem with the Blue Parrot headset not getting audio from the phone is a very frustrating one and it took several hours to diagnose the problem. (Especially the Samsung/ Windows side, in my case)
I have a Samsung I760 phone using Windows Mobile 6.1. After pairing, the headset is visible in the PHONE window, as it should. But upon dialling, the audio transfers from headset to phone.
While in a call, you can tap on the menu button and it should bring you to a menu that would allow you to transfer the audio from headset to phone and vice versa. But this action malfunctions in the Blue Parrot headset only. The Blue Eagle headset works fine.
MY SUGGESTIONS:
1) Chuck the hideously expensive blue parrot headset in the trashcan and buy yourself a blue eagle, available at truck stops everywhere
2) Pester the Blue parrot support staff for a replacement, or a solution at 1800 742 8588.
Make sure you understand the manual and especially point 13 dealing with the transfer of audio before you call them.
Other than this, the headset actually works fine.
adampotgieter@yahoo.com
Dec 15, 2009 | VXI Corporation Blueparrott B250-XT...
My Nokia will connect with Parrot CK3100. On
you can adjust the ringtone and volume in the sttings menu.
Oct 18, 2009 | Parrot Hands-Free Car Kit with LCD Display...
ANSWERING CALLS
Check to see that it isn't set to "call forwarding".
Feb 10, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
