Question about Electronics - Others
Emtec z1467 Hello,I have a problem with my flashdrive: When I Plug it in my computer the red led lights up but it doesen't work. The computer does not show me the removable partition... Can you please help meee?!?!?!
  • Razvan Sorin Dumitru
    Razvan Sorin Dumitru Feb 07, 2014
    Sorry,I didn't know that there was another topic open for a similar question.
    Sergeant:
  • 376 Answers
4 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: Flash Drive (Kingmax) cannot be read by the computer
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no
dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
Posted on Jul 09, 2012
SOURCE: heating up, light not coming on
cruzer micro 4GB, loaded with data. works perfectly in all systems except my xp. Problem didn't originate until after ghosting system to correct different problem. Now, error message states flashdrive not recognized. must then get behind pc, and gently work with it until i can hear the shift in the duo core processors and the orange light on the flashdrive comes on. Please help.
Posted on Mar 13, 2009
bronk50
  • 27725 Answers
SOURCE: My Emtec animal USB flash drive isn't showing up on my computer
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Posted on Jan 12, 2012
I have a Dukane Projector and each morning my power light is solid red (no other lights are on). I have to unplug it and plug it back in and then everything works fine until the next day when it happe
Hello Bucky
Red power LED without any other LEDs usually indicates a power issue with incoming power or with the projectors circuit power supply. You should try a different power source first.
Ernie
Dukane A/V Service dept.
Jan 14, 2015 | Dukane IMAGEPRO 8942 Multimedia Projector
hope this helps you
Jan 10, 2012 | Electronics - Others
How to rcover from my sandisk back to my library
1. Does the flash drive LED light up when you plug it into various computers? ( not just your own fortesting purposes).
2. Does it pop up in windows explorer at all? ( Should be labeled as Removable Disk by default)
Your flashdrive may have essentially died. Test this flashdrive on multiple computers to determine whether its your computer or the flash drive. If you are trying to recover information try out the app Recuva which can be found on google search. Your information may have been corrupted.
May 05, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Photos to computer samsung sway
Your samsung sway should of come with a flash-drive like thing. You can plug that into your phone, get a flash-drive and plug it into that thing and plug the flashdrive into a computer....
Basically
1. Get the flash-drive like thing (it will from now be refered to as "thing" lol)
2. Plug the thing into the phone
3. Plug a flash-drive into the thing
4. Take the flashdrive and thing out
5. Plug the flashdrive into a computer.
Apr 16, 2010 | Samsung Sway SCH-U650 Cell Phone
Blackberry Bold Won't turn on red LED light flashes
The four flashes may actually be a "2+2", indicating that there is no software installed on the device.
Oct 01, 2009 | RIM BlackBerry Bold Smartphone
Heating up, light not coming on
Mar 10, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sharp projector xr10xl standby light flashing and lamp light on what is wrong?
if it's blinking green, nothing is wrong. it's just cooling. if it's blinking red and the lamp is off, the lamp door is open.
Jan 13, 2009 | Sharp XR10XL DLP Projector
Problem
Hello!
Hopefully I can try to walk you through a process that I would use.  First check to see if the flashdrive is damaged.  Usually the cases don't break, but the USB connector itself takes a lot of hits/damage/wear.  You should be able to see 4 metallic contacts on the USB connector and they should be in good shape.  Blow out any dirt/garbage in the connector as well.
Next is to see when you plug it in if the LED on it lights up at all.  If there is no light whatsoever, it is one of two things, either the flashdrive is totally broken or you have a failled USB port.  Either one is possible.  If possible, take the flashdrive and test it on another system, or at least another USB port.  That will give you some important information.
Assuming that the LED lights, then it is a question of getting Windows to recognize the drive.  If there is nothing important on the drive, fdisk the drive in DOS, then format it, and then Windows should recognize it, allowing it to be used.
If you have no LED lighting on the flashdrive, after testing on another system as well, get another flashdrive (or return this one if under warranty), since there are no real parts to service/fix.
Hope this helps out!
Ken
Jan 06, 2009 | Computers & Internet
Emtec mp3 player won't turn on
This is a simple flash Mp3 player, I went on the manufacturers website..they do not have any firmware for either the C215 or the C210. So if you installed firmware to it, its possibly you installed the incorrect software on the unit. Most firmware restores the actual information such as the menu and playback options for your music. The biggest issue you have to look at is the device not turning on when its disconnected from the computer, I would check the battery..and then hold in the Play button for about 5 seconds, if nothing comes up, then your probably right, you just have a flash drive. You might contact the manufacturer and see if they can email you the firmware (if available).
Product details:
http://www.emtec-international.com/en/driver.php?categorie=AVNOM&gamme=LECTEURS%20MP3&ss_gamme=C210
Email Form for EMTEC (didnt see a phone number)
http://www.emtec-international.com/en/assistance.php?categorie=DEFAU
Oct 15, 2008 | EMTEC Magnetics Group C215 MP3 Player
Electronics - Others Logo
1,551 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
