Question about Waterpik Cordless Water Flosser, Model WP-360
Not working plug it it up for hours will not turn on
Sony bravia 65 inch won't turn off
There is one main thing you need to do before any thing you need to unplug the Tv leave off for 24 hours not plugged in do not temp to plug it in then after 24 hours off you need to plug in do not try the remote or press any buttons ok at all just plug in and leave it for 24 hours plugged in then you can unplug the Tv for 30 mins then plug back in and try to use the remote or press the buttons if it still don't work then the power board might be the problem but get back to me afthe 2 days ok to see how you got on
Jul 10, 2017 | Sony Televison & Video
I have an lectric Homelite blower/vac. It worked well for 1/2 hour. I turned it off and when I wanted to turn it back on, it started but stopped within a minute. I tried three different extension cords...
I could be a variety of things. Did you have a very long cord on it? did the cord loosen the plug? are you sure the outlet is still good, Also you may need to wait a few hours for a thermal reset to reset.
Aug 08, 2011 | Toro Electric Ultra Blower/Vac 12 Amp
Well when i plug it in the computer and wait for about 1 hour and un plug it and turn it on nothing happens
hmmmm, interesting
if it's a desktop system it won't work without the power being plugged in, if it's a laptop then it's a good guess to say the battery is dead.
the above comments are based on the assumption that the mains plug is plugged in to a fully working mains outlet and that it's turned on.
have you tried turning the computer on when it's plugged in and does it work?
Apr 20, 2011 | Computers & Internet
I cant look around in fallout 3 (right stick frozen), and my last save point was hours and hours ago. however the right stick works in pause menu and other games. what do i do?
What probably happened is your right stick was compressed when the remote turned on. Try turning the remote off and on, or un-plug and plug it back in. If that doesn't work simply save your game using the left thumb stick.
Mar 11, 2011 | Bethesda Softworks Fallout 3 for Xbox 360
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
My craig mp4 player shows an hour glass and will not work.
Turn on the MP4 player and let the battery go all the way dead. Plug it back into a computer and mine reset.
Dec 09, 2009 | Craig CMP168C MP3 Player
MP3 player won't turn on with or without plug in.
first toggle the hold switch, make sure it's not on.
then press and hold the menu button+ centre button, together at the same time for about 10 seconds.
if that doesn't work try pressing the middle button+the play button, for a few seconds. It should work.
If the thing still doesn't turn on just hook it up to a comp and leave it there for a few hours. mine actually took a week to recover.
Mar 04, 2008 | SanDisk Sansa E280 MP3 Player
Battery, phone
theres a problem with its flash memory, you need to hot air solder the board and the flash IC chip on it. theres no problem with your battery. there maybe a cold solder around the chip.
Feb 18, 2008 | Motorola Mobility RAZR V3
CD1000 won't turn on
I am not a techo but if your camera works when it's plugged into the charger but not when just relying solely on the battery, I'd reckon the battery is your problem. It doesn't seem to be holding charge.
Sep 13, 2005 | Sony Mavica MVC-CD1000 Digital Camera
Waterpik Cordless Water Flosser, Model WP-360 Logo
581 people viewed this question
Top Waterpik Health & Beauty Experts
Andrew Taylor
Andrew Taylor
Jay Plesset
Are you a Waterpik Health and Beauty Expert? Answer questions, earn points and help others
