Question about Coal Minds Android Apps
Disadvantages of coal - Coal Minds Android Apps
What is a coal scuttle?
coal scuttle
noun
  1. a metal container with a sloping lid used to carry coal for a domestic fire.
Dec 09, 2016 | Computers & Internet
What are the disadvantages of coal?
Charcoal?
  • It takes time (25 - 30 minutes) to light and wait for the briquets to become ready to use.
  • Temperature control is more difficult.
  • Cleaning the ashes out can be a pain.
  • More smoke produced than gas grills.
There is a few.
Nov 01, 2016 | Grilling
What bolt size does a 98 Chrysler Town And Country LX 3.8l take for the coal pack. I have1 bolt on it need 3 more.
The 1998 Chrysler Town & Country does not operate on coal. It has a gasoline engine. There is no "coal pack."
Aug 24, 2014 | 1998 Chrysler Town & Country
I added coals to my Charbroil Deluxe 7000 grill, and then they disintegrated. Have I ruined the grill?
Is the grill that you are using gas? If so make sure it is compatible to use with coals. You might also be looking for briquets.
Jul 28, 2012 | Grilling
How do you condition a new grill?
Start some coals with the grate off the grill. As the coals are heating up, coat the grate in *vegetable* shortening using a paper towel. Place the grate back on the grill over the hot coals and cover. Allow the coals to burn off; this process will coat the grate with a protective layer of oil.
You might also consider running the grate through a burnoff process BEFORE curing to remove any coating the manufacturer used for protection during shipping. To do this, burn some coals for roughly 30 minutes under the grate with the lid down, let cool, then condition per previous instructions.
Jun 24, 2010 | Brinkmann Smoke 'n Grill Double-Grill...
Cooking info
You can print a new manual off of www.chargriller.com. But, the basics are:
1) Take cooking grates off of grill
2) Put enough charcoal on the grill to cover the desired cooking area two coal layers high
3) Pile up desired amount of charcoal (laid out in step 2)
4) Spray lighter fluid all over charcoal pile
5) Light the pile
6) Let the pile burn until the flames die out and most of the coal has turned white
7) Spread the coals back out (use tongs they will be hot). Put any coals that are still black on top of the white ones.
8) Put your cooking grates back on the grill and let the last black coals turn white and the grates heat up.
9) Now cook!
Apr 14, 2010 | Char-Griller Super Pro
Gas engineer wants to re-arrange coals correctly post service
yes he is right on that the postion off the coals have to be in the correct pstion to stop fire sooting and fumes coming from fire , if the coals are in postion you take them out and put them back the same as they came out , or there should be a picture of the coal lay out in the users book , or look on line for the make of fire , if the gas engneer cannot work this out then go to some one who can ,
this is basic gas fitting any gas fitter will know this if not walk away from them ,
hope this helps
Feb 05, 2009 | Cozy Heating & Cooling
Regarding gas Barbeque and charcoal Barbeque
It depends on your preferance
Charcoal most say it gives what your cooking better flavor but the disadvantage is waiting for the coals to get hot and longer cooking time due to less heat.
Gas quick cooking time, quick warmup time the disadvantages scrafice some of the flavor, unless you buy a gas grill set up to smoke it is almost impossible to use a conventional gas grill for smoking, and also you have to have enough gas to cook completly or have a second tank in case you run out.
Hope this helps Ya
please rate me
Jul 20, 2008 | Barbeques Galore Capt'n Cook 3-Burner...
Android Apps Logo
82 people viewed this question
Top Coal Minds Apps Experts
Are you a Coal Minds App Expert? Answer questions, earn points and help others
