How many times must I describe my problem????
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
Just once, if you provide enough details. In the case of your first question, since you didn't name the seller we can only suggest you contact the seller directly to arrange a return.
Posted on Feb 07, 2014
What means physical features
lots of times in describing humans this term is used to prompt the user into better describing the exact feature's or shape of the face and body , an example would be ( lite brown hair , tall /thin build , green eyes, scar on left cheek ) etc .
May 27, 2016 | Computers & Internet
Customer care service
Open monitor and look at power supply board for capacitors which are "balooning" or deformed in any way. These look like cylindars on the board. These tend to dry out and make what you are describing occur. Replacing them usually fixes about 80% of the problem you are describing. Those parts run about $0.25 to $0.75 each.. well worth trying, right?
Jan 30, 2014 | ViewSonic Computers & Internet
I have an pnkyp HTR-500 reciever that shuts of every time i try to turn it on part#2301381 is discolerd and melty looking inside what is this part and what is the problem
The chances are that the part you are describing is a Capacitor and is part of the power circuit. It can be replaced and they are commonly described like this when failed. The capacitor failure will give the symptoms you describe.
Jul 22, 2013 | Audio Players & Recorders
Describe how to replace a timing chain and align the timing marks also how to replace the front oil seal .
That is a lot to describe. You would be better off to either purchase a manual or go to your local library to look at a manual. Some libraries have online manuals that you can acess from home for free also.
May 02, 2011 | 2001 Chevrolet Cavalier
I have a1999 bmw il 740 how do you replace the timing chain
Removal of timing chain is described separately from installation. Assembly sequence for removal and installation is different.
Installation of timing chain is described separately from removal. Assembly sequence for removal and installation is different.
Check guide, reversing and tensioning rails, replace if necessary.
Mar 26, 2011 | BMW 750 Cars & Trucks
Iluv iMM153 please describe how I change the time from 24 hour
i have the exact same problem, i the picture of the product, it says pm on the side of the display, and its can say pm ont he display !!
Dec 11, 2009 | Audio Players & Recorders
Describe your how do i set the timing on a 2005
May I suggest a trip to your local library. Cycle repair books should be in 646 stacks of reference.
Oct 04, 2009 | 2005 kawasaki KLR 650
I need the diagram for the balance chain timing
Except Premier
Procedures applying to removal and installation of the auxiliary shaft drive chains are located under Auxiliary (Intermediate or Silent) Shafts Removal and Installation, later in this section.
2.5L Premier Engine (See Figures 1 through 5)
Fig. 1: To remove the timing chain, remove the timing chain case cover
Fig. 2: When removing and installing the timing chain the crankshaft and camshaft sprocket timing marks should be aligned as shown
Fig. 3: While holding the timing chain, camshaft sprocket and crankshaft sprocket aligned install them onto the engine
Fig. 4: Lock and unlock the timing chain tensioner by switching the tensioner lever, as shown
Fig. 5: To verify correct installation, turn the crankshaft until the camshaft sprocket timing mark is approximately at the one o'clock position, then count the number of chain link pins between the points shown
  1. Disconnect the negative battery cable.
  2. Remove the fan shroud and cooling fan, as described earlier in this section.
  3. Remove the accessory drive belts. For more information, refer to .
  4. Remove the water pump pulley and crankshaft vibration damper, as described earlier in this section.
  5. Remove the timing case cover, as described previously in this section.
It is a good practice to either remove or cover the radiator area when performing extensive repairs to the engine to prevent accidental damage to the radiator core.
  1. Rotate the crankshaft until the 0 timing mark on the crankshaft sprocket is closest to and on a center line with the timing mark on the camshaft sprocket.
  2. Remove the oil slinger from the crankshaft.
  3. Remove the camshaft retaining bolt and remove the sprockets and chain as an assembly.
  4. If the timing chain tensioner is to be replaced, the oil pan must also be removed.
To install:
  1. Turn the tensioner lever to the unlock (down) position and pull the tensioner block toward the tensioner lever to compress the spring. Hold the block and turn the tensioner lever to the lock (up) position.
  2. Install the crankshaft sprocket, camshaft sprocket and timing chain together. Make sure the timing marks are aligned as indicated in Step 6 and in the accompanying illustration.
  3. Install the camshaft sprocket retaining bolt and washer. Tighten the bolt to 80 ft. lbs. (108 Nm).
  4. To verify correct installation of the timing chain, rotate the crankshaft until the camshaft sprocket timing mark is approximately at the 1 o'clock position. Count the number of chain link pins between the camshaft timing mark and the crankshaft timing mark, there should be 20 pins (2 per link) between the marks.
  5. Make sure that the timing chain tensioner switches to the unlocked position. If the tensioner does not switch automatically unlock, switch it manually to the unlock position.
  6. Install the oil slinger.
  7. Install the timing case cover, as described earlier in this section.
  8. Install the water pump pulley and crankshaft vibration damper, as described earlier in this section.
  9. Install and properly tension the accessory drive belts. For more information, refer to .
  10. Install the fan shroud and cooling fan, as described earlier in this section.
  11. Connect the negative battery cable, start the engine and check for leaks.
Good luck... and remember rated this help.
Aug 14, 2009 | 1991 Dodge Spirit
Describe your Intermatic &
Is the time clock rotating through the off tripper? If so, and the pump stays on, it's not wired right. Check the wiring at the clock for the pump.
Jul 01, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Physics
When a body covers equal distances in equal intervals of time then the body is said to describe uniform motion.When a body moves unequal distances in equal intervals of time or vice-versa, then the body is said to describe non-uniform motion.
Apr 27, 2009 | Edu-Science Edu Science Microscope Set
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
