Question about Frigidaire PLHS267ZA Side by Side Refrigerator
My refrigerator leaks water out the bottom when I use the water dispenser in the door.
    New Friend:
  • 46 Answers
Water line has a hole. probably from a mouse chewing on the plastic tube. Another possiblity the plastic tube was pulled on and pulled out of the compression nut / connector.
Posted on Feb 08, 2014
HVACRH20
  • 237 Answers
SOURCE: Water leaking from left side ice/water dispenser
If you describe a constant flow of water from the ice maker then the solenoid valve is either leaking by when it's upposed to be off or the motor module is stuck in the "fill" position. If it was stuck in fill you would be getting a LOT of water all the time so if you only have a trickle then the solenoid valve may be letting water leak by it. The diagram here shows the parts for a better idea of what you may need to look at (and where it's at). http://www.partselect.com/Schematics/Frigidaire/SZGBPCQH.gif
Posted on Jan 08, 2007
fridgetech
  • 473 Answers
SOURCE: when icemaker is filling water comes out door dispenser
I need the entire model # from the sticker inside the fridge section. My guess is this is the model that has a diode in the wiring harness that directs power to the valves and has gone bad letting power go to both valves. I would look and see if you also have water going into the icemaker when you press for water out of the dispenser. If there is no diode then the water valve is bad. I need the model # so I can look at a wiring diagram. You can look at the wiring to the water valve and see if it has a diode. It is black block and has two wires in one end and one out the other. If so the diode only can be bought and spliced in. Let me know so I can help.
Posted on Nov 03, 2007
SOURCE: My Frigidaire refrigerator water dispenser
lift up & out on the drip tray (it will come out) after removing it you will see 3 screw. unscrew the screws & lift the face plate of the despenser & it will come off. Be careful though. There is a ribbon wire connected to the back of the face plate. make sure to dissconect the ribbon wire from the control board not the back of the face plate (its alot harder to reconnect to the face plate & pretty simle to reconnect to the control board).
Posted on Jan 02, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
SOURCE: Water dispenser on refrigerator leaks inside the refrigerator
Check filter houseing and filter, Its either not installed correctly , has a line leaking or disconnected to filter or has frozen over the filter. Good Luck.. Hope your freezer is keeping cool enough.. AARS
Posted on Jul 02, 2010
Water leak on floor under refrigerator
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | GE Refrigerators
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
Tubes on the bottom of the refrigerator connected to water dispenser leaking every time I dispense water..help
The water valve for the dispenser is electric controlled and in the rear of the machine. Which is why there is no leak while it is off. There is a push in connector which can be purchased at most hardware stores that is most likely either cracked, or simply not connected tight which is why there is a leak when the water dispenser is turned on. Check that union. should be near the bottom door hinge. It is there so the door can be removed if necessary.
Mar 13, 2010 | Refrigerators
Maytag Wide by Side leaks from the refrigerator side
Hold the door switch in and you should be able to watch it leak.
Sep 10, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
The water and icecube dispenser constantly leaks water on floor
Needs new solinoid valve. Usually located on the back bottom of refrigerator
Jan 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Something leaking from dispenser frame
You can remove the frame around the dispenser by pulling it gently and then you access to the screws that hold the dispenser in place. Could be a spillage behind the frame. Good Luck.
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is not dispensing but icemaker is working...
damaged water feed pipe at the bottom of the freezer door
Oct 22, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Frigidaire PLHS267ZA Side by Side Refrigerator Logo
81 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
